[cgma-dev] Opencascade directory missing from link line
    Jane Hu
    janejhu at gmail.com
    Mon Dec  2 10:35:26 CST 2013
Iulian, Jed
I double checked my build of occ on CGM trunk, it's working fine. I found
that my LD_LIBRARY_PATH has /home/jhu/occ660/build/lib which is the library
path. That's why I didn't see this error.
CGM_EXT_LDFLAGS is the correct one to add occ library path as well as other
libraries, I will check in the patch soon, it should solve Jed's problem.
Please let us know if it still bother you.
Jane
On Sun, Dec 1, 2013 at 12:05 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> Thanks Jed,
> Jane, please review this patch. Did you compile cgm trunk against
> OpenCascade ?
> On my laptop (ubuntu 12.04), I need something like this. Maybe I am adding
> too much, maybe only occ lib path should be added, we have a variable
> OCC_LIB_FLAG, that usually is defined with -L/path/to/occ/lib, after
> configuration.
> Thanks,
> Iulian
> Iulian Grindeanu <iulian at mcs.anl.gov> writes:
> > We recommend using the LD_LIBRARY_PATH;
> LD_LIBRARY_PATH is irrelevant at build time.  It is an alternative to
> setting RPATH in the build (-Wl,-rpath,/path/to/opencascade/lib with a
> gcc-style toolchain), but not an alternative to a library path
> (-L/path/to/opencascade/lib).  LIBRARY_PATH is formally an alternative
> to -L, but it is almost never used.  Depending on environment variables
> to locate libraries is fragile as hell, and totally non-standard for
> autotools builds.
> > (I know many hate it, especially because of interaction with
> > autotools). Do you recommend a better solution?
> Pass -L/path/to/opencascade/lib.
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131202/e99a2df2/attachment.html>
More information about the cgma-dev
