[cgma-dev] get_graphics for OpenCascade?
    Jane Hu
    janejhu at gmail.com
    Thu Aug 15 11:05:54 CDT 2013
Sorry I didn't see the last two post before I sent out mine. David, is the
meshing code fast enough for you?
Jane
On Thu, Aug 15, 2013 at 10:10 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> On 08/15/2013 09:55 AM, David Thompson wrote:
>> ... As for watertight triangulations from the faceter, for single
>>> volumes, from ACIS, the faceting is generally watertight (though the facets
>>> from separate surfaces don't share points).  But for multiple volumes
>>> sharing surfaces, the faceting often won't be watertight.
>> That all sounds OK.
>>  ... There's a tool in MeshKit that does make facet models coming from
>>> CAD watertight, and has shown good robustness even for huge models.  ...
>> If it's fast, that would be great. If it's slow and generating a
>> high-quality mesh, that's probably not what we're looking for here (but
>> would be using elsewhere).
> IIRC, it's fast enough even for large models.  See
> http://www.imr.sandia.gov/**papers/imr19/Smith2B.3.pdf<http://www.imr.sandia.gov/papers/imr19/Smith2B.3.pdf>
> - tim
>          Thanks,
>>         David
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130815/f7b759ef/attachment-0001.html>
More information about the cgma-dev
