[cgma-dev] get_graphics for OpenCascade?
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Aug 15 10:10:37 CDT 2013
On 08/15/2013 09:55 AM, David Thompson wrote:
>> ... As for watertight triangulations from the faceter, for single volumes, from ACIS, the faceting is generally watertight (though the facets from separate surfaces don't share points).  But for multiple volumes sharing surfaces, the faceting often won't be watertight.
> That all sounds OK.
>> ... There's a tool in MeshKit that does make facet models coming from CAD watertight, and has shown good robustness even for huge models.  ...
> If it's fast, that would be great. If it's slow and generating a high-quality mesh, that's probably not what we're looking for here (but would be using elsewhere).
IIRC, it's fast enough even for large models.  See http://www.imr.sandia.gov/papers/imr19/Smith2B.3.pdf.
- tim
> 	Thanks,
> 	David
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
