[cgma-dev] CGMA with Cubit not reading ACIS files
    David Thompson
    david.thompson at kitware.com
    Fri Aug  2 18:27:35 CDT 2013
Hi Iulian (et al.),
I wanted to thank you all for your help and follow up on one comment. You said
> You cannot configure with cubit and occ at the same time.
and I was curious: what causes the limitation? I understood from the CGM paper that models from multiple geometric kernels could be loaded at once in order to perform joint modeling; is it just the combination of cubit and OCC/OCE that cause trouble?
	David
More information about the cgma-dev
