[cgma-dev] CGMA with Cubit not reading ACIS files
Rajeev Jain
jain at mcs.anl.gov
Thu Aug 1 15:07:31 CDT 2013
Hi David,
Good to know that --with-cubit option is working on OSX.
What exactly did you do to get around DYLD_LIBRARY_PATH problem for OSX?
Rajeev
>________________________________
> From: David Thompson <david.thompson at kitware.com>
>To: Iulian Grindeanu <iulian at mcs.anl.gov>
>Cc: cgma-dev at mcs.anl.gov
>Sent: Wednesday, July 31, 2013 5:39 PM
>Subject: Re: [cgma-dev] CGMA with Cubit not reading ACIS files
>Hi Iulian,
>> We are building usually on linux only; ...
>The software we're working on needs to support the big 3 (Linux, OS X, Windows).
>> Rajeev is building on 64 bit OSx, but only with occ.
>> Does it pass make check for you or not?
>Yes. I have to fiddle with DYLD_LIBRARY_PATH because of the way Cubit is prepared on OS X, but make check passes.
> Thanks,
> David
>> > You cannot configure with cubit and occ at the same time.
>> I did not.
>> > What is your configuration ?
>> CXX=clang++ CC=clang CXXFLAGS="-arch i386" CFLAGS="-arch i386" /path/to/cgm/configure --prefix=/path/to/cgm/x86_install --enable-shared --with-cubit=/Applications/Cubit-13.1/Cubit.app/Contents/MacOS
>> Thanks,
>> David
>> > Hi all,
>> > I have a version of CGMA working with OCC but when I build with cubit support, some simple test programs I wrote don't work any longer. Specifically, calling
>> > const char* filename = "/path/to/cgm/test/model1.sat";
>> > ModelImportOptions opts;
>> > DLIList<RefEntity*> entities;
>> > stat = GeometryQueryTool::instance()->import_solid_model(
>> > filename, ACIS_SAT_TYPE, opts, entities);
>> > returns CUBIT_SUCCESS and prints a non-zero number of "ACIS Entities" have been read but then
>> > 1. entities is an empty list and
>> > 2. calling GeometryQueryTool::instance()->bodies() also returns an empty list.
>> > Has anyone else seen this problem?
>> > Thanks,
>> > David
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130801/302c617c/attachment.html>
More information about the cgma-dev
