[cgma-dev] CGMA with Cubit not reading ACIS files
David Thompson
david.thompson at kitware.com
Thu Aug 1 15:32:43 CDT 2013
Hi Rajeev,
> Good to know that --with-cubit option is working on OSX.
> What exactly did you do to get around DYLD_LIBRARY_PATH problem for OSX?
I build the application (let's call it CGM2VTK) and place it inside a ".app" directory like so:
mkdir -p CGM2VTK.app/Contents/MacOS
mv CGM2VTK CGM2VTK.app/Contents/MacOS
cd CGM2VTK.app/Contents/MacOS
ln -s /Applications/Cubit-13.1/Cubit.app/Contents/MacOS/*dylib .
cd ../../../
./CGM2VTK.app/Contents/MacOS/CGM2VTK file.sat file.vtp
The links to the cubit libraries have to be in the same location (relative to the ".app" directory) as in Cubit.app. Alternately you can run the program like so:
DYLD_LIBRARY_PATH=/Applications/Cubit-13.1/Cubit.app/Contents/MacOS ./CGM2VTK file.sat file.vtp
I've hit related issues with the OCC backend: the libraries in my build of OpenCascade don't appear to have any paths embedded in them. I've used install_name_tool to modify binaries, but have found cases where install_name_tool complains that there isn't any space left. (Perhaps it's not getting build with "-headerpad_max_install_names"?)
David
> From: David Thompson <david.thompson at kitware.com>
> To: Iulian Grindeanu <iulian at mcs.anl.gov>
> Cc: cgma-dev at mcs.anl.gov
> Sent: Wednesday, July 31, 2013 5:39 PM
> Subject: Re: [cgma-dev] CGMA with Cubit not reading ACIS files
> Hi Iulian,
> > We are building usually on linux only; ...
> The software we're working on needs to support the big 3 (Linux, OS X, Windows).
> > Rajeev is building on 64 bit OSx, but only with occ.
> > Does it pass make check for you or not?
> Yes. I have to fiddle with DYLD_LIBRARY_PATH because of the way Cubit is prepared on OS X, but make check passes.
> Thanks,
> David
> > > You cannot configure with cubit and occ at the same time.
> > I did not.
> > > What is your configuration ?
> > CXX=clang++ CC=clang CXXFLAGS="-arch i386" CFLAGS="-arch i386" /path/to/cgm/configure --prefix=/path/to/cgm/x86_install --enable-shared --with-cubit=/Applications/Cubit-13.1/Cubit.app/Contents/MacOS
> > Thanks,
> > David
> > > Hi all,
> > > I have a version of CGMA working with OCC but when I build with cubit support, some simple test programs I wrote don't work any longer. Specifically, calling
> > > const char* filename = "/path/to/cgm/test/model1.sat";
> > > ModelImportOptions opts;
> > > DLIList<RefEntity*> entities;
> > > stat = GeometryQueryTool::instance()->import_solid_model(
> > > filename, ACIS_SAT_TYPE, opts, entities);
> > > returns CUBIT_SUCCESS and prints a non-zero number of "ACIS Entities" have been read but then
> > > 1. entities is an empty list and
> > > 2. calling GeometryQueryTool::instance()->bodies() also returns an empty list.
> > > Has anyone else seen this problem?
> > > Thanks,
> > > David
More information about the cgma-dev
