[cgma-dev] CGMA with Cubit not reading ACIS files
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed Jul 31 17:21:55 CDT 2013
Hi David,
We are building usually on linux only;
http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
You can see some of the configurations we build/test every night
We have a 32 bit version build too, on a "jenkins" bot, linux machine.
Rajeev is building on 64 bit OSx, but only with occ.
Does it pass make check for you or not?
Iulian
----- Original Message -----
| Hi Iulian,
| > You cannot configure with cubit and occ at the same time.
| I did not.
| > What is your configuration ?
| CXX=clang++ CC=clang CXXFLAGS="-arch i386" CFLAGS="-arch i386"
| /path/to/cgm/configure --prefix=/path/to/cgm/x86_install
| --enable-shared
| --with-cubit=/Applications/Cubit-13.1/Cubit.app/Contents/MacOS
| Thanks,
| David
| > Hi all,
| > I have a version of CGMA working with OCC but when I build with
| > cubit support, some simple test programs I wrote don't work any
| > longer. Specifically, calling
| > const char* filename = "/path/to/cgm/test/model1.sat";
| > ModelImportOptions opts;
| > DLIList<RefEntity*> entities;
| > stat = GeometryQueryTool::instance()->import_solid_model(
| > filename, ACIS_SAT_TYPE, opts, entities);
| > returns CUBIT_SUCCESS and prints a non-zero number of "ACIS
| > Entities" have been read but then
| > 1. entities is an empty list and
| > 2. calling GeometryQueryTool::instance()->bodies() also returns an
| > empty list.
| > Has anyone else seen this problem?
| > Thanks,
| > David
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130731/c8dfad8b/attachment.html>
More information about the cgma-dev
