[cgma-dev] CGMA with Cubit not reading ACIS files
David Thompson david.thompson at kitware.com
Wed Jul 31 17:39:08 CDT 2013
Hi Iulian,
> We are building usually on linux only; ...
The software we're working on needs to support the big 3 (Linux, OS X, Windows).
> Rajeev is building on 64 bit OSx, but only with occ.
> Does it pass make check for you or not?
Yes. I have to fiddle with DYLD_LIBRARY_PATH because of the way Cubit is prepared on OS X, but make check passes.
	David
> > You cannot configure with cubit and occ at the same time.
> I did not.
> > What is your configuration ?
> CXX=clang++ CC=clang CXXFLAGS="-arch i386" CFLAGS="-arch i386" /path/to/cgm/configure  --prefix=/path/to/cgm/x86_install --enable-shared --with-cubit=/Applications/Cubit-13.1/Cubit.app/Contents/MacOS
>         Thanks,
>         David
> > Hi all,
> > I have a version of CGMA working with OCC but when I build with cubit support, some simple test programs I wrote don't work any longer. Specifically, calling
> >     const char* filename = "/path/to/cgm/test/model1.sat";
> >     ModelImportOptions opts;
> >     DLIList<RefEntity*> entities;
> >     stat = GeometryQueryTool::instance()->import_solid_model(
> >       filename, ACIS_SAT_TYPE, opts, entities);
> > returns CUBIT_SUCCESS and prints a non-zero number of "ACIS Entities" have been read but then
> > 1. entities is an empty list and
> > 2. calling GeometryQueryTool::instance()->bodies() also returns an empty list.
> > Has anyone else seen this problem?
> >         Thanks,
> >         David
More information about the cgma-dev mailing list
