[cgma-dev] CGMA with Cubit not reading ACIS files
David Thompson david.thompson at kitware.com
Wed Jul 31 17:08:35 CDT 2013
Hi Iulian,
> You cannot configure with cubit and occ at the same time.
I did not.
> What is your configuration ?
CXX=clang++ CC=clang CXXFLAGS="-arch i386" CFLAGS="-arch i386" /path/to/cgm/configure  --prefix=/path/to/cgm/x86_install --enable-shared --with-cubit=/Applications/Cubit-13.1/Cubit.app/Contents/MacOS
	David
> Hi all,
> I have a version of CGMA working with OCC but when I build with cubit support, some simple test programs I wrote don't work any longer. Specifically, calling
>     const char* filename = "/path/to/cgm/test/model1.sat";
>     ModelImportOptions opts;
>     DLIList<RefEntity*> entities;
>     stat = GeometryQueryTool::instance()->import_solid_model(
>       filename, ACIS_SAT_TYPE, opts, entities);
> returns CUBIT_SUCCESS and prints a non-zero number of "ACIS Entities" have been read but then
> 1. entities is an empty list and
> 2. calling GeometryQueryTool::instance()->bodies() also returns an empty list.
> Has anyone else seen this problem?
>         Thanks,
>         David
More information about the cgma-dev mailing list
