[cgma-dev] CGMA with Cubit not reading ACIS files
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed Jul 31 16:49:20 CDT 2013
You cannot configure with cubit and occ at the same time.
What is your configuration ?
Iulian
----- Original Message -----
| Hi all,
| I have a version of CGMA working with OCC but when I build with cubit
| support, some simple test programs I wrote don't work any longer.
| Specifically, calling
| const char* filename = "/path/to/cgm/test/model1.sat";
| ModelImportOptions opts;
| DLIList<RefEntity*> entities;
| stat = GeometryQueryTool::instance()->import_solid_model(
| filename, ACIS_SAT_TYPE, opts, entities);
| returns CUBIT_SUCCESS and prints a non-zero number of "ACIS Entities"
| have been read but then
| 1. entities is an empty list and
| 2. calling GeometryQueryTool::instance()->bodies() also returns an
| empty list.
| Has anyone else seen this problem?
| Thanks,
| David
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130731/1234055c/attachment.html>
More information about the cgma-dev
