[cgma-dev] make dist doesn't work
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed May 22 20:19:01 CDT 2013
I could have sworn it works, because we have this
http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck
It's good I didn't swear, because cgm-distcheck is not doing make distcheck :(
As it should.
I am looking at it.
Iulian
----- Original Message -----
| Hi Jane/Iulian,
| 'make dist' in CGM doesn't work, something about not knowing how to
| make target mergechk_merge in
| cgm_apps/examples/driverc++. This needs to work, and should be the
| way the buildbot builds distribution tarballs. The
| tarfile for CGM 12.2 on the ftp site is missing
| CubitFileSimModel.[c,h]pp, which I'm guessing is caused by this
| problem
| (and not using make dist to build that tarball). Comments?
| - tim
| "You will keep in perfect peace him whose mind is
| steadfast, because he trusts in you." Isaiah 26:3
| Tim Tautges Argonne National Laboratory
| (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130522/a1e64b80/attachment.html>
More information about the cgma-dev
