[cgma-dev] make dist doesn't work
    Tim Tautges
    tautges at mcs.anl.gov
    Wed May 22 17:58:33 CDT 2013
Hi Jane/Iulian,
   'make dist' in CGM doesn't work, something about not knowing how to make target mergechk_merge in
cgm_apps/examples/driverc++.  This needs to work, and should be the way the buildbot builds distribution tarballs.  The
tarfile for CGM 12.2 on the ftp site is missing CubitFileSimModel.[c,h]pp, which I'm guessing is caused by this problem
(and not using make dist to build that tarball).  Comments?
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
