[cgma-dev] make dist doesn't work
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed May 22 20:24:39 CDT 2013
----- Original Message -----
| I could have sworn it works, because we have this
| http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck
| It's good I didn't swear, because cgm-distcheck is not doing make
| distcheck :(
| As it should.
take that back
cgm-distcheck has no errors, but it is on merge-cubit12.2 branch.
make distcheck is not tested on cgm trunk .
| I am looking at it.
| Iulian
| | Hi Jane/Iulian,
| | 'make dist' in CGM doesn't work, something about not knowing how to
| | make target mergechk_merge in
| | cgm_apps/examples/driverc++. This needs to work, and should be the
| | way the buildbot builds distribution tarballs. The
| | tarfile for CGM 12.2 on the ftp site is missing
| | CubitFileSimModel.[c,h]pp, which I'm guessing is caused by this
| | problem
| | (and not using make dist to build that tarball). Comments?
| | - tim
| | "You will keep in perfect peace him whose mind is
| | steadfast, because he trusts in you." Isaiah 26:3
| | Tim Tautges Argonne National Laboratory
| | (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| | phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| | fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130522/2a1eb567/attachment.html>
More information about the cgma-dev
