[cgma-dev] r5796 - cgm/trunk
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Mon Oct 15 11:32:02 CDT 2012
What is geom/CubitCompat.h needed for ? It shows cubit 12 in it.
I removed it from the repo, but it keeps showing up, I think I made an error when I deleted/removed it.
Iulian
----- Original Message -----
| We shouldn't need to do a make install before a make check. My guess
| is there are missing search directories in the
| Makefile.am's for the test dir.
| - tim
| On 10/15/2012 11:09 AM, janehu at mcs.anl.gov wrote:
| > Author: janehu
| > Date: 2012-10-15 11:09:50 -0500 (Mon, 15 Oct 2012)
| > New Revision: 5796
| > Modified:
| > cgm/trunk/configure.ac
| > Log:
| > Fixed the build issue. Still need to do 'make install' first before
| > 'make check'.
| > Modified: cgm/trunk/configure.ac
| > --- cgm/trunk/configure.ac 2012-10-15 15:54:33 UTC (rev 5795)
| > +++ cgm/trunk/configure.ac 2012-10-15 16:09:50 UTC (rev 5796)
| > @@ -42,8 +42,8 @@
| > # Extract libtool config
| > -ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path],
| > [CGM_CXX_LINKFLAGS])
| > -ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
| > +FATHOM_LIBTOOL_VAR( [CXX], [compiler_lib_search_path],
| > +FATHOM_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
| > AC_SUBST(CGM_CXX_LINKFLAGS)
| > AC_SUBST(CGM_CXX_LIBS)
| > @@ -608,6 +608,7 @@
| > geom/facetbool/Makefile
| > geom/OCC/Makefile
| > geom/parallel/Makefile
| > + test/TestConfig.h
| > geom/virtual/Makefile
| > init/Makefile
| > compat/Makefile
| "You will keep in perfect peace him whose mind is
| steadfast, because he trusts in you." Isaiah 26:3
| Tim Tautges Argonne National Laboratory
| (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121015/98cc7ef9/attachment.html>
More information about the cgma-dev
