[cgma-dev] r5796 - cgm/trunk
    Jane Hu
    janejhu at gmail.com
    Mon Oct 15 11:48:35 CDT 2012
It's generated by CubitCompat.h.in when doing configure. Shouldn't be
needed in the repo.
Jane
On Mon, Oct 15, 2012 at 11:32 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> What is geom/CubitCompat.h needed for ? It shows cubit 12 in it.
> I removed it from the repo, but it keeps showing up, I think I made an
> error when I deleted/removed it.
> Iulian
> We shouldn't need to do a make install before a make check.  My guess is
> there are missing search directories in the
> Makefile.am's for the test dir.
> - tim
> On 10/15/2012 11:09 AM, janehu at mcs.anl.gov wrote:
> > Author: janehu
> > Date: 2012-10-15 11:09:50 -0500 (Mon, 15 Oct 2012)
> > New Revision: 5796
> > Modified:
> >     cgm/trunk/configure.ac
> > Log:
> > Fixed the build issue. Still need to do 'make install' first before
> 'make check'.
> > Modified: cgm/trunk/configure.ac
> > --- cgm/trunk/configure.ac        2012-10-15 15:54:33 UTC (rev 5795)
> > +++ cgm/trunk/configure.ac        2012-10-15 16:09:50 UTC (rev 5796)
> > @@ -42,8 +42,8 @@
> >   #                              Extract libtool config
> > -ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path],
> [CGM_CXX_LINKFLAGS])
> > -ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
> > +FATHOM_LIBTOOL_VAR( [CXX], [compiler_lib_search_path],
> > +FATHOM_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
> >   AC_SUBST(CGM_CXX_LINKFLAGS)
> >   AC_SUBST(CGM_CXX_LIBS)
> > @@ -608,6 +608,7 @@
> >              geom/facetbool/Makefile
> >              geom/OCC/Makefile
> >              geom/parallel/Makefile
> > +           test/TestConfig.h
> >              geom/virtual/Makefile
> >              init/Makefile
> >              compat/Makefile
> "You will keep in perfect peace him whose mind is
>    steadfast, because he trusts in you."               Isaiah 26:3
>               Tim Tautges            Argonne National Laboratory
>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>   phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>              fax: (608) 263-4499      Madison, WI 53706
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121015/84a4067b/attachment.html>
More information about the cgma-dev
