[cgma-dev] r5796 - cgm/trunk
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Oct 15 11:15:52 CDT 2012
We shouldn't need to do a make install before a make check.  My guess is there are missing search directories in the
Makefile.am's for the test dir.
- tim
On 10/15/2012 11:09 AM, janehu at mcs.anl.gov wrote:
> Author: janehu
> Date: 2012-10-15 11:09:50 -0500 (Mon, 15 Oct 2012)
> New Revision: 5796
> Modified:
>     cgm/trunk/configure.ac
> Log:
> Fixed the build issue. Still need to do 'make install' first before 'make check'.
> Modified: cgm/trunk/configure.ac
> --- cgm/trunk/configure.ac	2012-10-15 15:54:33 UTC (rev 5795)
> +++ cgm/trunk/configure.ac	2012-10-15 16:09:50 UTC (rev 5796)
> @@ -42,8 +42,8 @@
>   #                              Extract libtool config
> -ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [CGM_CXX_LINKFLAGS])
> -ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
> +FATHOM_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [CGM_CXX_LINKFLAGS])
> +FATHOM_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
>   AC_SUBST(CGM_CXX_LINKFLAGS)
>   AC_SUBST(CGM_CXX_LIBS)
> @@ -608,6 +608,7 @@
>              geom/facetbool/Makefile
>              geom/OCC/Makefile
>              geom/parallel/Makefile
> +           test/TestConfig.h
>              geom/virtual/Makefile
>              init/Makefile
>              compat/Makefile
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
