[cgma-dev] Make check errors...
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Thu Sep 27 11:13:40 CDT 2012
| Hello all,
| LPATH didn't seem to work. Stuart - have you had success with that? A
| related question is: what do we expect developers to do when writing
| their own apps? Is it sufficient to just include cgm,make? Shouldn't
| we just be able to do the same thing in our tests?
| Paul
I think that is the idea. But cgm.make is part of the install, in a way, while make check should be part of the build test, before you do the install.
What I still don't understand in libtool, is that moab and meshkit "make check"s are fine in ubuntu 12, shared build, while cgm and lasso need the changes that I sent earlier.
Somebody who knows more about autotools should be able to figure the right solution. (mine I consider a hack :( )
Iulian
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120927/93cacbea/attachment.html>
More information about the cgma-dev
