[cgma-dev] Make check errors...
Paul Wilson
wilsonp at engr.wisc.edu
Thu Sep 27 10:58:53 CDT 2012
On 09/26/2012 03:20 PM, Iulian Grindeanu wrote:
> On 09/26/2012 01:57 PM, Paul Wilson wrote:
> Hi everyone,
> Sorry if I've missed this discussed elsewhere (or forgotten
> the answer that once knew)....
> I get the following errors when I try to "make check" on CGM
> built against cubit 12.2:
> wilsonp at todlaw ~/UW/research/fathom/cgm/dagmc_bld/test >
> LD_LIBRARY_PATH=/opt/cubit/12.2/bin make check
> make init sheet webcut brick_acis merge_acis
> make[1]: Entering directory
> `/home/wilsonp/UW/research/fathom/cgm/dagmc_bld/test'
> make[1]: `init' is up to date.
> /bin/bash ../libtool --tag=CXX --mode=link g++ -Wall
> -pipe -pedantic -O2 -DNDEBUG -L/opt/cubit/12.2/bin
> -R/opt/cubit/12.2/bin -o sheet sheet.o ../libcgm.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o
> .libs/sheet sheet.o -L/opt/cubit/12.2/bin
> ../.libs/libcgm.so -lm -Wl,-rpath
> -Wl,/home/wilsonp/opt/lib -Wl,-rpath -Wl,/opt/cubit/12.2/bin
> /usr/bin/ld: sheet.o: undefined reference to symbol
> 'Body::is_sheet_body()'
> /usr/bin/ld: note: 'Body::is_sheet_body()' is defined in
> DSO /opt/cubit/12.2/bin/libcubiti19.so so try adding it to
> the linker command line
> /opt/cubit/12.2/bin/libcubiti19.so: could not read
> symbols: Invalid operation
> collect2: ld returned 1 exit status
> make[1]: *** [sheet] Error 1
> make[1]: Leaving directory
> make: *** [check-am] Error 2
> I've configured with: --enable-optimize --disable-debug
> --enable-shared --with-cubit=/opt/cubit/12.2
> --prefix=/home/wilsonp/opt
> Should there be a -lcubit19 in the linker flags here?
> Hi Paul
> Try adding cubit to your LPATH as well as your LD_LIBRARY_PATH.
> Stuart
> hello,
> This is my patch needed for cgm to pass make check on ubuntu 12
> (shared build)
> I didn't try setting LPATH.
Hello all,
LPATH didn't seem to work. Stuart - have you had success with that? A
related question is: what do we expect developers to do when writing
their own apps? Is it sufficient to just include cgm,make? Shouldn't we
just be able to do the same thing in our tests?
Paul
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Associate Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Chair, Energy Analysis & Policy Program ~ http://nelson.wisc.edu/eap
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120927/23bc6b91/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120927/23bc6b91/attachment.bin>
More information about the cgma-dev
