[cgma-dev] Make check errors...
    Stuart Slattery
    sslattery at wisc.edu
    Wed Sep 26 14:25:32 CDT 2012
On 09/26/2012 01:57 PM, Paul Wilson wrote:
> Hi everyone,
> Sorry if I've missed this discussed elsewhere (or forgotten the answer
> that once knew)....
> I get the following errors when I try to "make check" on CGM built
> against cubit 12.2:
>     wilsonp at todlaw ~/UW/research/fathom/cgm/dagmc_bld/test >
>     LD_LIBRARY_PATH=/opt/cubit/12.2/bin make check
>     make  init sheet  webcut brick_acis merge_acis
>     make[1]: Entering directory
>     `/home/wilsonp/UW/research/fathom/cgm/dagmc_bld/test'
>     make[1]: `init' is up to date.
>     /bin/bash ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe
>     -pedantic -O2 -DNDEBUG -L/opt/cubit/12.2/bin
>     -R/opt/cubit/12.2/bin  -o sheet sheet.o ../libcgm.la -lm
>     libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o
>     .libs/sheet sheet.o  -L/opt/cubit/12.2/bin ../.libs/libcgm.so -lm
>     -Wl,-rpath -Wl,/home/wilsonp/opt/lib -Wl,-rpath
>     -Wl,/opt/cubit/12.2/bin
>     /usr/bin/ld: sheet.o: undefined reference to symbol
>     'Body::is_sheet_body()'
>     /usr/bin/ld: note: 'Body::is_sheet_body()' is defined in DSO
>     /opt/cubit/12.2/bin/libcubiti19.so so try adding it to the linker
>     command line
>     /opt/cubit/12.2/bin/libcubiti19.so: could not read symbols:
>     Invalid operation
>     collect2: ld returned 1 exit status
>     make[1]: *** [sheet] Error 1
>     make[1]: Leaving directory
>     make: *** [check-am] Error 2
> I've configured with: --enable-optimize --disable-debug
> --enable-shared --with-cubit=/opt/cubit/12.2 --prefix=/home/wilsonp/opt
> Should there be a -lcubit19 in the linker flags here?
> Paul
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
> Associate Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
> Chair, Energy Analysis & Policy Program ~http://nelson.wisc.edu/eap
Hi Paul
Try adding cubit to your LPATH as well as your LD_LIBRARY_PATH.
Stuart
Stuart Slattery
Nuclear Regulatory Commission Fellow
Computational Nuclear Engineering Research Group
Department of Engineering Physics
University of Wisconsin - Madison
434 Engineering Research Building
1500 Engineering Drive
Madison, WI 53706
email : sslattery at wisc.edu
cell  : 608.843.5871
url   : http://cnerg.engr.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120926/0de245b0/attachment.html>
More information about the cgma-dev
