[cgma-dev] Make check errors...
Iulian Grindeanu
iulian at mcs.anl.gov
Wed Sep 26 14:06:29 CDT 2012
If you are on ubuntu 12.04, the current cgm will not build fine with --enable-shared
try static, I would say.
Or, specify lcubit..., as you suggest.
I didn't commit my version, because I still hope that libtool will be able to figure out that the new "golden" link rules are needed.
Iulian
----- Original Message -----
| Hi everyone,
| Sorry if I've missed this discussed elsewhere (or forgotten the answer
| that once knew)....
| I get the following errors when I try to "make check" on CGM built
| against cubit 12.2:
| | wilsonp at todlaw ~/UW/research/fathom/cgm/dagmc_bld/test >
| | LD_LIBRARY_PATH=/opt/cubit/12.2/bin make check
| | make init sheet webcut brick_acis merge_acis
| | make[1]: Entering directory
| | `/home/wilsonp/UW/research/fathom/cgm/dagmc_bld/test'
| | make[1]: `init' is up to date.
| | /bin/bash ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic
| | -O2 -DNDEBUG -L/opt/cubit/12.2/bin -R/opt/cubit/12.2/bin -o sheet
| | sheet.o ../libcgm.la -lm
| | libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/sheet
| | sheet.o -L/opt/cubit/12.2/bin ../.libs/libcgm.so -lm -Wl,-rpath
| | -Wl,/home/wilsonp/opt/lib -Wl,-rpath -Wl,/opt/cubit/12.2/bin
| | /usr/bin/ld: sheet.o: undefined reference to symbol
| | 'Body::is_sheet_body()'
| | /usr/bin/ld: note: 'Body::is_sheet_body()' is defined in DSO
| | /opt/cubit/12.2/bin/libcubiti19.so so try adding it to the linker
| | command line
| | /opt/cubit/12.2/bin/libcubiti19.so: could not read symbols: Invalid
| | operation
| | collect2: ld returned 1 exit status
| | make[1]: *** [sheet] Error 1
| | make[1]: Leaving directory
| | make: *** [check-am] Error 2
| I've configured with: --enable-optimize --disable-debug
| --enable-shared --with-cubit=/opt/cubit/12.2
| --prefix=/home/wilsonp/opt
| Should there be a -lcubit19 in the linker flags here?
| Paul
| Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
| Associate Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
| Chair, Energy Analysis & Policy Program ~ http://nelson.wisc.edu/eap
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120926/89663894/attachment.html>
More information about the cgma-dev
