[cgma-dev] Make check errors...
Iulian Grindeanu
iulian at mcs.anl.gov
Wed Sep 26 15:20:33 CDT 2012
----- Original Message -----
| On 09/26/2012 01:57 PM, Paul Wilson wrote:
| | Hi everyone,
| | Sorry if I've missed this discussed elsewhere (or forgotten the
| | answer
| | that once knew)....
| | I get the following errors when I try to "make check" on CGM built
| | against cubit 12.2:
| | | wilsonp at todlaw ~/UW/research/fathom/cgm/dagmc_bld/test >
| | | LD_LIBRARY_PATH=/opt/cubit/12.2/bin make check
| | | make init sheet webcut brick_acis merge_acis
| | | make[1]: Entering directory
| | | `/home/wilsonp/UW/research/fathom/cgm/dagmc_bld/test'
| | | make[1]: `init' is up to date.
| | | /bin/bash ../libtool --tag=CXX --mode=link g++ -Wall -pipe
| | | -pedantic
| | | -O2 -DNDEBUG -L/opt/cubit/12.2/bin -R/opt/cubit/12.2/bin -o sheet
| | | sheet.o ../libcgm.la -lm
| | | libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o
| | | .libs/sheet
| | | sheet.o -L/opt/cubit/12.2/bin ../.libs/libcgm.so -lm -Wl,-rpath
| | | -Wl,/home/wilsonp/opt/lib -Wl,-rpath -Wl,/opt/cubit/12.2/bin
| | | /usr/bin/ld: sheet.o: undefined reference to symbol
| | | 'Body::is_sheet_body()'
| | | /usr/bin/ld: note: 'Body::is_sheet_body()' is defined in DSO
| | | /opt/cubit/12.2/bin/libcubiti19.so so try adding it to the linker
| | | command line
| | | /opt/cubit/12.2/bin/libcubiti19.so: could not read symbols:
| | | Invalid
| | | operation
| | | collect2: ld returned 1 exit status
| | | make[1]: *** [sheet] Error 1
| | | make[1]: Leaving directory
| | | make: *** [check-am] Error 2
| | I've configured with: --enable-optimize --disable-debug
| | --enable-shared --with-cubit=/opt/cubit/12.2
| | --prefix=/home/wilsonp/opt
| | Should there be a -lcubit19 in the linker flags here?
| | Paul
| | Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:
| | http://bit.ly/pphw-cal
| | Associate Professor, Engineering Physics. ~
| | http://cnerg.engr.wisc.edu
| | Chair, Energy Analysis & Policy Program ~ http://nelson.wisc.edu/eap
| Hi Paul
| Try adding cubit to your LPATH as well as your LD_LIBRARY_PATH.
| Stuart
| Stuart Slattery
| Nuclear Regulatory Commission Fellow
| Computational Nuclear Engineering Research Group
| Department of Engineering Physics
| University of Wisconsin - Madison
| 434 Engineering Research Building
| 1500 Engineering Drive
| Madison, WI 53706
| email : sslattery at wisc.edu cell : 608.843.5871
| url : http://cnerg.engr.wisc.edu
hello,
This is my patch needed for cgm to pass make check on ubuntu 12 (shared build)
I didn't try setting LPATH.
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120926/caff422c/attachment-0001.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120926/caff422c/attachment-0001.bin>
More information about the cgma-dev
