[cgma-dev] Make check errors...
Paul Wilson
wilsonp at engr.wisc.edu
Wed Sep 26 13:57:39 CDT 2012
Hi everyone,
Sorry if I've missed this discussed elsewhere (or forgotten the answer
that once knew)....
I get the following errors when I try to "make check" on CGM built
against cubit 12.2:
wilsonp at todlaw ~/UW/research/fathom/cgm/dagmc_bld/test >
LD_LIBRARY_PATH=/opt/cubit/12.2/bin make check
make init sheet webcut brick_acis merge_acis
make[1]: Entering directory
`/home/wilsonp/UW/research/fathom/cgm/dagmc_bld/test'
make[1]: `init' is up to date.
/bin/bash ../libtool --tag=CXX --mode=link g++ -Wall -pipe
-pedantic -O2 -DNDEBUG -L/opt/cubit/12.2/bin -R/opt/cubit/12.2/bin
-o sheet sheet.o ../libcgm.la -lm
libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/sheet
sheet.o -L/opt/cubit/12.2/bin ../.libs/libcgm.so -lm -Wl,-rpath
-Wl,/home/wilsonp/opt/lib -Wl,-rpath -Wl,/opt/cubit/12.2/bin
/usr/bin/ld: sheet.o: undefined reference to symbol
'Body::is_sheet_body()'
/usr/bin/ld: note: 'Body::is_sheet_body()' is defined in DSO
/opt/cubit/12.2/bin/libcubiti19.so so try adding it to the linker
command line
/opt/cubit/12.2/bin/libcubiti19.so: could not read symbols: Invalid
operation
collect2: ld returned 1 exit status
make[1]: *** [sheet] Error 1
make[1]: Leaving directory
make: *** [check-am] Error 2
I've configured with: --enable-optimize --disable-debug --enable-shared
--with-cubit=/opt/cubit/12.2 --prefix=/home/wilsonp/opt
Should there be a -lcubit19 in the linker flags here?
Paul
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Associate Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Chair, Energy Analysis & Policy Program ~ http://nelson.wisc.edu/eap
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120926/4cd86c0d/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120926/4cd86c0d/attachment.bin>
More information about the cgma-dev
