[cgma-dev] testgeom_occ
Jane Hu
janejhu at gmail.com
Mon May 21 13:16:58 CDT 2012
You may try merge_cubit13.1 branch, this has some minor function
signature's changes, it shouldn't affect the result of running testcases in
occ.
Can you double check if a new_body is created in the copy_body process? I
suspect that the problem is still in the copy_body place, where it didn't
find underlining TopoDS_Shape. Then it could be just related to the OS,
which may be a bug there.
Jane
On Mon, May 21, 2012 at 12:22 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
> Thanks Jane for looking into this, we made some progress, I made the
> changes you made to cgm repo version, I'm using CGM repo version with
> OCC-6.5 not the merge-cubit13.1 branch - should I use this branch instead?
> We made some progress with the change you made the error is now on line
> 6249 instead of 6233 in file iGeom_CGMA.cc, which is the subtract
> operation, the copy operation seems to have gone through, please see
> debugger o/p below:
> (gdb) r
> Starting program: /Users/rajeevjain/cgm/itaps/testgeom_occ
> Reading symbols for shared libraries
> ++++++++++++++++++++++++++++++..................................... done
> Using default input file: ./../test/LeverArm.brep
> Geometry engine set to: OpenCascade 6.5
> ITAPS GEOMETRY INTERFACE TEST PROGRAM:
> gLoad:
> Constructed 1 Volume: 1
> Model contents:
> vertices: 99
> edges: 159
> faces: 63
> regions: 1
> Success
> tags: Tags defined on model: GLOBAL_ID, NAME
> Success
> gentity sets: Success
> topology adjacencies: Success
> construct: Created swept volume 4
> Updated volume 3
> Success
> primitives: Success
> transforms: Success
> Program received signal EXC_BAD_ACCESS, Could not access memory.
> Reason: 13 at address: 0x0000000000000000
> 0x00000001041f8edf in Handle_Standard_Transient::Assign ()
> (gdb) bt
> #0 0x00000001041f8edf in Handle_Standard_Transient::Assign ()
> #1 0x00000001031ee1e4 in BRepBuilderAPI_ModifyShape::DoModif ()
> #2 0x00000001031e46c0 in BRepBuilderAPI_Copy::BRepBuilderAPI_Copy ()
> #3 0x00000001000b286d in OCCModifyEngine::get_shape_list
> (this=0x104e04b70, BodySM_list=@0x7fff5fbff4f0, shape_list=@0x7fff5fbff318,
> is_volume=@0x7fff5fbff2f8, keep_old=true, b_boxes=0x104e8d3f0) at
> OCCModifyEngine.cpp:3535
> #4 0x000000010007e792 in OCCModifyEngine::subtract (this=0x104e04b70,
> tool_body_list=@0x7fff5fbff4f0, from_bodies=@0x7fff5fbff4d8,
> new_bodies=@0x7fff5fbff480, imprint=false, keep_old=false) at
> OCCModifyEngine.cpp:2212
> #5 0x00000001004a4cec in GeometryModifyTool::subtract (this=0x104e03280,
> tool_body_list=@0x7fff5fbff608, from_bodies=@0x7fff5fbff6f0,
> new_bodies=@0x7fff5fbff6d8, imprint=false, keep_old=false) at
> GeometryModifyTool.cpp:6368
> #6 0x00000001004a51de in GeometryModifyTool::subtract (this=0x104e03280,
> tool_body=0x104e8cb30, from_bodies=@0x7fff5fbff6f0,
> GeometryModifyTool.cpp:6305
> #7 0x0000000100028f21 in iGeom_subtractEnts (instance=0x10085e8c0,
> blank=0x104e7fe50, tool=0x104e7ef40, geom_entity=0x7fff5fbff8b0,
> err=0x7fff5fbff8cc) at iGeom_CGMA.cc:6249
> #8 0x0000000100006231 in booleans_test (geom=0x10085e8c0) at
> testgeom.cc:1136
> #9 0x000000010000e878 in main (argc=1, argv=0x7fff5fbffb78) at
> testgeom.cc:239
> (gdb) list
> 129 }
> 130
> 131 int main( int argc, char *argv[] )
> 132 {
> 133 // Check command line arg
> 134 #ifdef FORCE_OCC
> 135 #ifndef HAVE_OCC
> 136 #error "Cannot force use of OCC w/out OCC support"
> 137 #endif
> 138 std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep";
> Rajeev
> *From:* Jane Hu <janejhu at gmail.com>
> *To:* Rajeev Jain <jain at mcs.anl.gov>
> *Cc:* CGMA Development <cgma-dev at mcs.anl.gov>
> *Sent:* Monday, May 21, 2012 10:11 AM
> *Subject:* Re: testgeom_occ
> Hi, Rajeev:
> I don't know exactly what's wrong with the Mac OS, I double checked that
> if the new_body is null, theCS pointer should not be null. However, I added
> a safety check on it just now. Can you double check to see if it works this
> time?
> Jane
> On Fri, May 18, 2012 at 3:34 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
> testgeom_occ on Mac OSX fails, when in copy_body routine, the call to
> IsBound fails:
> if(!new_body && OCCQueryEngine::instance()->OCCMap->IsBound(*theCS))
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120521/26a3f232/attachment.html>
More information about the cgma-dev
