[cgma-dev] testgeom_occ
    Rajeev Jain
    jain at mcs.anl.gov
    Mon May 21 12:22:35 CDT 2012
Thanks Jane for looking into this, we made some progress, I made the changes you made to cgm repo version, I'm using CGM repo version with OCC-6.5 not the merge-cubit13.1 branch - should I use this branch instead?
We made some progress with the change you made the error is now on line 6249 instead of 6233 in file iGeom_CGMA.cc, which is the subtract operation, the copy operation seems to have gone through, please see debugger o/p below:
(gdb) r
Starting program: /Users/rajeevjain/cgm/itaps/testgeom_occ
Reading symbols for shared libraries ++++++++++++++++++++++++++++++..................................... done
Using default input file: ./../test/LeverArm.brep
Geometry engine set to: OpenCascade 6.5
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 4
Updated volume 3
Success
   primitives: Success
   transforms: Success
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: 13 at address: 0x0000000000000000
0x00000001041f8edf in Handle_Standard_Transient::Assign ()
(gdb) bt
#0  0x00000001041f8edf in Handle_Standard_Transient::Assign ()
#1  0x00000001031ee1e4 in BRepBuilderAPI_ModifyShape::DoModif ()
#2  0x00000001031e46c0 in BRepBuilderAPI_Copy::BRepBuilderAPI_Copy ()
#3  0x00000001000b286d in OCCModifyEngine::get_shape_list (this=0x104e04b70, BodySM_list=@0x7fff5fbff4f0, shape_list=@0x7fff5fbff318, is_volume=@0x7fff5fbff2f8, keep_old=true, b_boxes=0x104e8d3f0) at OCCModifyEngine.cpp:3535
#4  0x000000010007e792 in OCCModifyEngine::subtract (this=0x104e04b70, tool_body_list=@0x7fff5fbff4f0, from_bodies=@0x7fff5fbff4d8, new_bodies=@0x7fff5fbff480, imprint=false, keep_old=false) at OCCModifyEngine.cpp:2212
#5  0x00000001004a4cec in GeometryModifyTool::subtract (this=0x104e03280, tool_body_list=@0x7fff5fbff608, from_bodies=@0x7fff5fbff6f0, new_bodies=@0x7fff5fbff6d8, imprint=false, keep_old=false) at GeometryModifyTool.cpp:6368
#6  0x00000001004a51de in GeometryModifyTool::subtract (this=0x104e03280, tool_body=0x104e8cb30, from_bodies=@0x7fff5fbff6f0, new_bodies=@0x7fff5fbff6d8, imprint=false, keep_old=false) at GeometryModifyTool.cpp:6305
#7  0x0000000100028f21 in iGeom_subtractEnts (instance=0x10085e8c0, blank=0x104e7fe50, tool=0x104e7ef40, geom_entity=0x7fff5fbff8b0, err=0x7fff5fbff8cc) at iGeom_CGMA.cc:6249
#8  0x0000000100006231 in booleans_test (geom=0x10085e8c0) at testgeom.cc:1136
#9  0x000000010000e878 in main (argc=1, argv=0x7fff5fbffb78) at testgeom.cc:239
(gdb) list
129}
130
131int main( int argc, char *argv[] )
132{
133    // Check command line arg
134  #ifdef FORCE_OCC
135    #ifndef HAVE_OCC
136      #error "Cannot force use of OCC w/out OCC support"
137    #endif
138  std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep";
Rajeev
>________________________________
> From: Jane Hu <janejhu at gmail.com>
>To: Rajeev Jain <jain at mcs.anl.gov>
>Cc: CGMA Development <cgma-dev at mcs.anl.gov>
>Sent: Monday, May 21, 2012 10:11 AM
>Subject: Re: testgeom_occ
>Hi, Rajeev:
>I don't know exactly what's wrong with the Mac OS, I double checked that if the new_body is null, theCS pointer should not be null. However, I added a safety check on it just now. Can you double check to see if it works this time?
>Jane
>On Fri, May 18, 2012 at 3:34 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
>testgeom_occ on Mac OSX fails, when in copy_body routine, the call to IsBound fails:
>> if(!new_body && OCCQueryEngine::instance()->OCCMap->IsBound(*theCS))
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120521/3dcf50b5/attachment.html>
More information about the cgma-dev
