[cgma-dev] testgeom_occ
Rajeev Jain
jain at mcs.anl.gov
Mon May 21 13:44:33 CDT 2012
The error is sure OS related, it works on Linux flawlessly. copy_body seems to do something, not sure if it's right, below is the print of *blank_copy and *this_blank after copy_body operation:
(gdb) r
Starting program: /Users/rajeevjain/cgm/itaps/testgeom_occ
Reading symbols for shared libraries ++++++++++++++++++++++++++++++..................................... done
Using default input file: ./../test/LeverArm.brep
Geometry engine set to: OpenCascade 6.5
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
tags: Tags defined on model: GLOBAL_ID, NAME
Success
gentity sets: Success
topology adjacencies: Success
construct: Created swept volume 4
Updated volume 3
Success
primitives: Success
transforms: Success
Breakpoint 2, iGeom_subtractEnts (instance=0x10085e8c0, blank=0x104e7fe50, tool=0x104e7ef40, geom_entity=0x7fff5fbff8b0, err=0x7fff5fbff8cc) at iGeom_CGMA.cc:6234
6234 if (NULL == blank_copy) {
(gdb) p *blank_copy
$1 = {
<GroupingEntity> = {
<TopologyEntity> = {
<ModelEntity> = {
_vptr$ModelEntity = 0x10085a470,
deactivatedStatus_ = 0 '\0',
encountered_ = 0 '\0'
members of TopologyEntity:
bridgeMan = {
<TBOwner> = {
_vptr$TBOwner = 0x10085a790
members of BridgeManager:
topologyEntity = 0x104e7d380,
mergeList = {
<std::_Vector_base<TopologyBridge*, std::allocator<TopologyBridge*> >> = {
_M_impl = {
<std::allocator<TopologyBridge*>> = {
<__gnu_cxx::new_allocator<TopologyBridge*>> = {<No data fields>}, <No data fields>},
members of std::_Vector_base<TopologyBridge*, std::allocator<TopologyBridge*> >::_Vector_impl:
_M_start = 0x104e8ba70,
_M_finish = 0x104e8ba78,
_M_end_of_storage = 0x104e8ba78
members of GroupingEntity:
myParent = 0x0,
nextInParent = 0x0,
prevInParent = 0x0,
firstSenseEntity = 0x104e809b0,
lastSenseEntity = 0x104e809b0
<RefEntity> = {
<CubitEntity> = {
_vptr$CubitEntity = 0x10085a520,
entityId = 11
<CubitObservable> = {
_vptr$CubitObservable = 0x10085a618,
observerList = 0x0
<ToolDataUser> = {
_vptr$ToolDataUser = 0x10085a648,
toolData = 0x0
<CubitAttribUser> = {
_vptr$CubitAttribUser = 0x10085a6b0,
headAttrib = 0x0
members of RefEntity:
autoMergeStatus = 3,
markedFlag = 0,
listFlag = 0,
mColor = -1
(gdb) p *this_blank
$2 = {
<ModelEntity> = {
bridgeMan = {
<TBOwner> = {
topologyEntity = 0x104e7fdf0,
mergeList = {
_M_impl = {
_M_start = 0x104e7fbf0,
_M_finish = 0x104e7fbf8,
_M_end_of_storage = 0x104e7fbf8
myParent = 0x0,
nextInParent = 0x0,
prevInParent = 0x0,
firstSenseEntity = 0x104e7f500,
lastSenseEntity = 0x104e7f500
<RefEntity> = {
<CubitEntity> = {
entityId = 9
observerList = 0x0
<ToolDataUser> = {
toolData = 0x0
headAttrib = 0x104e836d0
markedFlag = 0,
listFlag = 0,
mColor = -1
Rajeev
>________________________________
> From: Jane Hu <janejhu at gmail.com>
>To: Rajeev Jain <jain at mcs.anl.gov>
>Cc: CGMA Development <cgma-dev at mcs.anl.gov>
>Sent: Monday, May 21, 2012 1:16 PM
>Subject: Re: testgeom_occ
>You may try merge_cubit13.1 branch, this has some minor function signature's changes, it shouldn't affect the result of running testcases in occ.
>Can you double check if a new_body is created in the copy_body process? I suspect that the problem is still in the copy_body place, where it didn't find underlining TopoDS_Shape. Then it could be just related to the OS, which may be a bug there.
>Jane
>On Mon, May 21, 2012 at 12:22 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
>Thanks Jane for looking into this, we made some progress, I made the changes you made to cgm repo version, I'm using CGM repo version with OCC-6.5 not the merge-cubit13.1 branch - should I use this branch instead?
>>We made some progress with the change you made the error is now on line 6249 instead of 6233 in file iGeom_CGMA.cc, which is the subtract operation, the copy operation seems to have gone through, please see debugger o/p below:
>>(gdb) r
>> gLoad:
>>Model contents:
>>vertices: 99
>>edges: 159
>>faces: 63
>>regions: 1
>>Success
>>Success
>>Updated volume 3
>>Success
>> primitives: Success
>> transforms: Success
>>Program received signal EXC_BAD_ACCESS, Could not access memory.
>>Reason: 13 at address: 0x0000000000000000
>>0x00000001041f8edf in Handle_Standard_Transient::Assign ()
>>(gdb) bt
>>#0 0x00000001041f8edf in Handle_Standard_Transient::Assign ()
>>#1 0x00000001031ee1e4 in BRepBuilderAPI_ModifyShape::DoModif ()
>>#2 0x00000001031e46c0 in BRepBuilderAPI_Copy::BRepBuilderAPI_Copy ()
>>#3 0x00000001000b286d in OCCModifyEngine::get_shape_list (this=0x104e04b70, BodySM_list=@0x7fff5fbff4f0, shape_list=@0x7fff5fbff318, is_volume=@0x7fff5fbff2f8, keep_old=true, b_boxes=0x104e8d3f0) at OCCModifyEngine.cpp:3535
>>#4 0x000000010007e792 in OCCModifyEngine::subtract (this=0x104e04b70, tool_body_list=@0x7fff5fbff4f0, from_bodies=@0x7fff5fbff4d8, new_bodies=@0x7fff5fbff480, imprint=false, keep_old=false) at OCCModifyEngine.cpp:2212
>>#5 0x00000001004a4cec in GeometryModifyTool::subtract (this=0x104e03280, tool_body_list=@0x7fff5fbff608, from_bodies=@0x7fff5fbff6f0, new_bodies=@0x7fff5fbff6d8, imprint=false, keep_old=false) at GeometryModifyTool.cpp:6368
>>#6 0x00000001004a51de in GeometryModifyTool::subtract (this=0x104e03280, tool_body=0x104e8cb30, from_bodies=@0x7fff5fbff6f0, new_bodies=@0x7fff5fbff6d8, imprint=false, keep_old=false) at GeometryModifyTool.cpp:6305
>>#7 0x0000000100028f21 in iGeom_subtractEnts (instance=0x10085e8c0, blank=0x104e7fe50, tool=0x104e7ef40, geom_entity=0x7fff5fbff8b0, err=0x7fff5fbff8cc) at iGeom_CGMA.cc:6249
>>#8 0x0000000100006231 in booleans_test (geom=0x10085e8c0) at testgeom.cc:1136
>>#9 0x000000010000e878 in main (argc=1, argv=0x7fff5fbffb78) at testgeom.cc:239
>>(gdb) list
>>129}
>>130
>>131int main( int argc, char *argv[] )
>>132{
>>133 // Check command line arg
>>134 #ifdef FORCE_OCC
>>135 #ifndef HAVE_OCC
>>136 #error "Cannot force use of OCC w/out OCC support"
>>137 #endif
>>138 std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep";
>>Rajeev
>>>Sent: Monday, May 21, 2012 10:11 AM
>>>Hi, Rajeev:
>>>I don't know exactly what's wrong with the Mac OS, I double checked that if the new_body is null, theCS pointer should not be null. However, I added a safety check on it just now. Can you double check to see if it works this time?
>>>Jane
>>>On Fri, May 18, 2012 at 3:34 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
>>>testgeom_occ on Mac OSX fails, when in copy_body routine, the call to IsBound fails:
>>>> if(!new_body && OCCQueryEngine::instance()->OCCMap->IsBound(*theCS))
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120521/d2f0e2d6/attachment-0001.html>
More information about the cgma-dev
