[cgma-dev] Link Mesquite and CGMA (and Lasso)
    Jane Hu
    janejhu at gmail.com
    Tue Dec  6 10:03:57 CST 2011
Also, your configure need to give the directory of your cgm build, for
example, my configure has this one:
--with-igeom=/mnt/disk2b/jhu/new_build.
Hope it helps.
Jane
On Tue, Dec 6, 2011 at 8:41 AM, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
> Hi Dan,
> It seems that your CGMA build is not successful.
> What geometry engine did you use? I mean, how did you configure CGMA?
> There are some building instructions on
> http://trac.mcs.anl.gov/projects/ITAPS/wiki/CGM
> First of all, what kind of geometry do you plan to support?
> OpenCascade is open source, otherwise you need licenses for ACIS or Cubit.
> For OpenCascade, you need to  configure and build it on your system.
> Follow the instructions from here:
> http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
> You also need to patch OCC 6.5, follow the instructions in
> <cgm>/README.OCC, README.OpenCascade
> Did "make check" succeed on your CGM build?
> Iulian
> Hello,
> I'm Le, Dan , student from TU-Darmstadt Germany. I'm working at a
> project for the Uni,
>    which should optimize the mesh while still obtain the object geometry.
>  From Mesquite [1] documentation,
> I'm trying to link Mesquite with the iGeom implementation (CGMA) and
> iRel (Lasso [2]).
> When I try to link CGMA and Lasso (and MOAB [3]) with:
>    ./configure --with-imesh
> IMESH_DEFS=/home/dan/moab-4.1.0/itaps/imesh/iMesh-Defs.inc --with-igeom
> IGEOM_DEFS=/home/dan/cgma-12.2.0b1/itaps/iGeom-Defs.inc --with-irel
> IREL_DEFS=/home/dan/lasso-3.0pre/iRel-Defs.inc
> then:
> checking for iGeom.h... yes
> checking for iGeom_dtor in iGeom library... no
> checking for iGeom_destroy in iGeom library... no
> configure: error: iGeom library unsuable:
> the hole terminal output is in the log file. What can I do to link those
> implementations?
> Since the installation is not easy for me, any help (Tutorial) is
> appreciated.
> Sincerely
> Le, Dan
> PS: [1] ,[2],[3] are all from
> http://www.itaps.org/software/download_interfaces.html
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20111206/2fc089f1/attachment.htm>
More information about the cgma-dev
