[cgma-dev] Link Mesquite and CGMA (and Lasso)
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Tue Dec  6 11:22:46 CST 2011
Hello, I have some corrections for my previous post; The configure command I am using for mesquite is like this: $ ./configure --prefix=/sandbox/lib/serial/mesquite --with-igeom=/sandbox/lib/serial/cgm/lib/iGeom-Defs.inc --with-imesh=/sandbox/lib/serial/moab/lib/iMesh-Defs.inc --with-irel=/sandbox/lib/serial/Lasso/lib/iRel-Defs.inc I didn't realize Dan is using "--with-imesh IMESH_DEFS=/home/dan/moab-4.1.0/itaps/imesh/iMesh-Defs.inc" ... I didn't try it, it might work. The part about the need of a successful cgma build ( and moab, Lasso) is, of course, still valid; Iulian ----- Original Message -----
| Also, your configure need to give the directory of your cgm build, for
| example, my configure has this one:
| --with-igeom=/mnt/disk2b/jhu/new_build.
| Hope it helps.
| Jane
| On Tue, Dec 6, 2011 at 8:41 AM, Iulian Grindeanu < iulian at mcs.anl.gov
| > wrote:
| | Hi Dan,
| | It seems that your CGMA build is not successful.
| | What geometry engine did you use? I mean, how did you configure
| | CGMA?
| | There are some building instructions on
| | http://trac.mcs.anl.gov/projects/ITAPS/wiki/CGM
| | First of all, what kind of geometry do you plan to support?
| | OpenCascade is open source, otherwise you need licenses for ACIS or
| | Cubit.
| | For OpenCascade, you need to configure and build it on your system.
| | Follow the instructions from here:
| | http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
| | You also need to patch OCC 6.5, follow the instructions in
| | <cgm>/README.OCC, README.OpenCascade
| | Did "make check" succeed on your CGM build?
| | Iulian
| | | Hello,
| | | I'm Le, Dan , student from TU-Darmstadt Germany. I'm working at a
| | | project for the Uni,
| | | which should optimize the mesh while still obtain the object
| | | geometry.
| | | From Mesquite [1] documentation,
| | | I'm trying to link Mesquite with the iGeom implementation (CGMA)
| | | and
| | | iRel (Lasso [2]).
| | | When I try to link CGMA and Lasso (and MOAB [3]) with:
| | | ./configure --with-imesh
| | | --with-igeom
| | | IGEOM_DEFS=/home/dan/cgma-12.2.0b1/itaps/iGeom-Defs.inc
| | | --with-irel
| | | IREL_DEFS=/home/dan/lasso-3.0pre/iRel-Defs.inc
| | | then:
| | | checking for iGeom.h... yes
| | | checking for iGeom_dtor in iGeom library... no
| | | checking for iGeom_destroy in iGeom library... no
| | | configure: error: iGeom library unsuable:
| | | the hole terminal output is in the log file. What can I do to link
| | | those
| | | implementations?
| | | Since the installation is not easy for me, any help (Tutorial) is
| | | appreciated.
| | | Sincerely
| | | Le, Dan
| | | PS: [1] ,[2],[3] are all from
| | | http://www.itaps.org/software/download_interfaces.html
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20111206/bb7fe300/attachment.htm>
More information about the cgma-dev
