[cgma-dev] r5037 - in cgm/trunk: . geom/parallel itaps
    Hong-Jun Kim
    hongjun at mcs.anl.gov
    Tue Jun 28 16:11:14 CDT 2011
Sorry about my typo in the commit statement.
I meant the option was "READ_DELETE".
It is a typo only in the commit statement.
Hong-Jun
----- Original Message -----
> From: "Tim Tautges" <tautges at mcs.anl.gov>
> To: cgma-dev at mcs.anl.gov
> Sent: Tuesday, June 28, 2011 3:48:51 PM
> Subject: Re: [cgma-dev] r5037 - in cgm/trunk: . geom/parallel itaps
> On 06/24/2011 05:36 PM, hongjun at mcs.anl.gov wrote:
> > Author: hongjun
> > Date: 2011-06-24 17:36:43 -0500 (Fri, 24 Jun 2011)
> > New Revision: 5037
> > Modified:
> >     cgm/trunk/Makefile.am
> >     cgm/trunk/configure.ac
> >     cgm/trunk/geom/parallel/CGMParallelComm.cpp
> >     cgm/trunk/geom/parallel/CGMReadParallel.cpp
> >     cgm/trunk/geom/parallel/Makefile.am
> >     cgm/trunk/itaps/iGeom_CGMA.cc
> > Log:
> > o Parallel CGM is also supported for ACIS geometry kernel only with
> > "READ_PARALLEL" option
> Shouldn't this be read_delete, not read_parallel? Also, these options
> should be the same as what we use for MOAB...
> - tim
> > o Parallel codes are built when "parallel_build" is defined (also
> > cubit library is used)
> > o GeometryQueryTool::import(export)_solid_model" functions are
> > changed to CubitCompat functions
> > o Passes make check
> > Modified: cgm/trunk/Makefile.am
> > --- cgm/trunk/Makefile.am 2011-06-24 19:11:43 UTC (rev 5036)
> > +++ cgm/trunk/Makefile.am 2011-06-24 22:36:43 UTC (rev 5037)
> > @@ -45,7 +45,7 @@
> >                     geom/libcubit_geom.la \
> >                     util/libcubit_util.la
> >   else
> > - CORE_CGM_LIBS = geom/libcubit_geom.la
> > + CORE_CGM_LIBS = geom/libcubit_geom.la $(CGM_ll_LIB)
> >   endif
> >   SUBDIRS = compat util geom init . $(igeom_DIR) test cgm_apps
> >   geom/testing
> > Modified: cgm/trunk/configure.ac
> > --- cgm/trunk/configure.ac 2011-06-24 19:11:43 UTC (rev 5036)
> > +++ cgm/trunk/configure.ac 2011-06-24 22:36:43 UTC (rev 5037)
> > @@ -104,12 +104,6 @@
> >                [CUBIT_DIR="$withval"
> >                 DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS
> >                 --with-cubit=\"${withval}\""])
> > -if test "x$CUBIT_DIR" != "xno"; then
> > - if test "x$WITH_MPI" != "xno"; then
> > - AC_MSG_ERROR("CGM from CUBIT shared library dosn't support
> > parallel build. Use serial build.")
> > - fi
> > -fi
> >   if test "x$CUBIT_DIR" == "xyes"; then
> >     AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit
> >     directory.])
> >   elif test "x$CUBIT_DIR" != "xno"; then
> > Modified: cgm/trunk/geom/parallel/CGMParallelComm.cpp
> > --- cgm/trunk/geom/parallel/CGMParallelComm.cpp 2011-06-24 19:11:43
> > UTC (rev 5036)
> > +++ cgm/trunk/geom/parallel/CGMParallelComm.cpp 2011-06-24 22:36:43
> > UTC (rev 5037)
> > @@ -267,9 +267,11 @@
> >       return CUBIT_SUCCESS;
> > +#ifdef HAVE_OCC
> >     CubitStatus result =
> >     GeometryQueryTool::instance()->export_solid_model(ref_entity_list,
> >     pBuffer,
> >   									 n_buffer_size, b_write_buffer);
> >     RRA("Failed to write ref entities to buffer.");
> > +#endif
> >     if (b_write_buffer) m_currentPosition += n_buffer_size;
> > @@ -285,9 +287,11 @@
> >   #else
> >     if (n_buffer_size == 0) return CUBIT_SUCCESS;
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
