[cgma-dev] r5037 - in cgm/trunk: . geom/parallel itaps
Tim Tautges tautges at mcs.anl.gov
Tue Jun 28 15:48:51 CDT 2011
On 06/24/2011 05:36 PM, hongjun at mcs.anl.gov wrote:
> Author: hongjun
> Date: 2011-06-24 17:36:43 -0500 (Fri, 24 Jun 2011)
> New Revision: 5037
> Modified:
>     cgm/trunk/Makefile.am
>     cgm/trunk/configure.ac
>     cgm/trunk/geom/parallel/CGMParallelComm.cpp
>     cgm/trunk/geom/parallel/CGMReadParallel.cpp
>     cgm/trunk/geom/parallel/Makefile.am
>     cgm/trunk/itaps/iGeom_CGMA.cc
> Log:
> o Parallel CGM is also supported for ACIS geometry kernel only with "READ_PARALLEL" option
Shouldn't this be read_delete, not read_parallel?  Also, these options should be the same as what we use for MOAB...
- tim
> o Parallel codes are built when "parallel_build" is defined (also cubit library is used)
> o GeometryQueryTool::import(export)_solid_model" functions are changed to CubitCompat functions
> o Passes make check
> Modified: cgm/trunk/Makefile.am
> --- cgm/trunk/Makefile.am	2011-06-24 19:11:43 UTC (rev 5036)
> +++ cgm/trunk/Makefile.am	2011-06-24 22:36:43 UTC (rev 5037)
> @@ -45,7 +45,7 @@
>                     geom/libcubit_geom.la \
>                     util/libcubit_util.la
>   else
> -  CORE_CGM_LIBS = geom/libcubit_geom.la
> +  CORE_CGM_LIBS = geom/libcubit_geom.la $(CGM_ll_LIB)
>   endif
>   SUBDIRS = compat util geom init . $(igeom_DIR) test cgm_apps geom/testing
> Modified: cgm/trunk/configure.ac
> --- cgm/trunk/configure.ac	2011-06-24 19:11:43 UTC (rev 5036)
> +++ cgm/trunk/configure.ac	2011-06-24 22:36:43 UTC (rev 5037)
> @@ -104,12 +104,6 @@
>                [CUBIT_DIR="$withval"
>                 DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""])
> -if test "x$CUBIT_DIR" != "xno"; then
> -  if test "x$WITH_MPI" != "xno"; then
> -    AC_MSG_ERROR("CGM from CUBIT shared library dosn't support parallel build. Use serial build.")
> -  fi
> -fi
>   if test "x$CUBIT_DIR" == "xyes"; then
>     AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit directory.])
>   elif test "x$CUBIT_DIR" != "xno"; then
> Modified: cgm/trunk/geom/parallel/CGMParallelComm.cpp
> --- cgm/trunk/geom/parallel/CGMParallelComm.cpp	2011-06-24 19:11:43 UTC (rev 5036)
> +++ cgm/trunk/geom/parallel/CGMParallelComm.cpp	2011-06-24 22:36:43 UTC (rev 5037)
> @@ -267,9 +267,11 @@
>       return CUBIT_SUCCESS;
> +#ifdef HAVE_OCC
>     CubitStatus result = GeometryQueryTool::instance()->export_solid_model(ref_entity_list, pBuffer,
>   									 n_buffer_size, b_write_buffer);
>     RRA("Failed to write ref entities to buffer.");
> +#endif
>     if (b_write_buffer) m_currentPosition += n_buffer_size;
> @@ -285,9 +287,11 @@
>   #else
>     if (n_buffer_size == 0) return CUBIT_SUCCESS;
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
