[cgma-dev] CGMA 12.2.0b2pre bugs
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Mon Jun 27 09:02:07 CDT 2011
On 06/24/2011 05:33 PM, Carl Ollivier-Gooch wrote:
> 2. GeometryQueryTool.cpp:332: error: prototype for âCubitStatus
> GeometryQueryTool::export_solid_model(DLIList<RefEntity*>&, const char*,
> const char*, int&, const CubitString&, const char*)â does not match
> any in class âGeometryQueryToolâ
> GeometryQueryTool.hpp:378: error: candidates are: CubitStatus
> GeometryQueryTool::export_solid_model(DLIList<RefEntity*>&, char*&,
> int&, bool)
> GeometryQueryTool.hpp:367: error: CubitStatus
> Model_File_Type, int&, const CubitString&, const char*)
> 3. GeometryQueryTool.cpp:959: error: prototype for âCubitStatus
> GeometryQueryTool::import_solid_model(const char*, const char*, const
> char*, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean,
> CubitBoolean, CubitBoolean, DLIList<RefEntity*>*)â does not match any
> GeometryQueryTool.hpp:432: error: candidates are: CubitStatus
> GeometryQueryTool::import_solid_model(DLIList<RefEntity*>*, const char*,
> int)
> GeometryQueryTool.hpp:412: error: CubitStatus
> GeometryQueryTool::import_solid_model(const char*, Model_File_Type,
> ModelImportOptions&, DLIList<RefEntity*>*)
The above two errors indicate some kind of configuration problem.  What
configure command did you use?  Would you mind sending a copy of
geom/CubitCompat.h and config.log?
- jason
More information about the cgma-dev
