[cgma-dev] r4775 : Getting CAMergePartner attribute info ?
    Hong-Jun Kim
    hongjun at mcs.anl.gov
    Fri May 13 12:50:00 CDT 2011
After importing merged geometry, I am using "CAMergePartner" attribute to find merged entities for my parallel meshing.
For example, I use "get_cubit_attrib" as follows and if "att" is not NULL pointer, I decided that the entity is merged.
CubitAttrib* att = entity->get_cubit_attrib(CA_MERGE_PARTNER, CUBIT_FALSE);
if (att != NULL) { // entity is merged }
However, by this revision change, CAMergePartner actuate process is removed because "GeometryQueryTool::check_mergeable_refentity" handles this.
So, I am wondering how I can know which entities are merged in this revision, then can anybody tell me about it?
Thanks.
Hong-Jun
----- Original Message -----
> From: "jiangtao ma" <jiangtao_ma at yahoo.com>
> To: cgma-dev at mcs.anl.gov
> Sent: Tuesday, April 26, 2011 12:54:15 PM
> Subject: [cgma-dev] r4775 - in cgm/trunk: . cgm_apps/ccapi/geom cgm_apps/cgm_cubit_acis cgm_apps/examples/driverc++
> cgm_apps/examples/gomadrive geom geom/ACIS_SRC geom/ACIS_SRC/gtcAttrib geom/ACIS_SRC/gtcAttrib/incl geom/Cholla
> geom/OCC geom/SolidWorks geom/facet geom/facetbool geom/parallel geom/testing geom/testing/data geom/virtual init
> itaps test util util/OtherFiles
> Author: janehu
> Date: 2011-04-26 12:54:11 -0500 (Tue, 26 Apr 2011)
> New Revision: 4775
> Added:
> cgm/trunk/KNOWN_ISSUES
> cgm/trunk/geom/ACIS_SRC/AcisHistory.cpp
> cgm/trunk/geom/ACIS_SRC/AcisHistory.hpp
> cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.cpp
> cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.hpp
> cgm/trunk/geom/ACIS_SRC/attrib_history.cpp
> cgm/trunk/geom/ACIS_SRC/attrib_history.hpp
> cgm/trunk/geom/AutoMidsurfaceTool.cpp
> cgm/trunk/geom/AutoMidsurfaceTool.hpp
> cgm/trunk/geom/CGMHistory.cpp
> cgm/trunk/geom/CGMHistory.hpp
> cgm/trunk/geom/Cholla/ChollaVolume.cpp
> cgm/trunk/geom/Cholla/ChollaVolume.hpp
> cgm/trunk/geom/Cholla/FacetorUtil.cpp
> cgm/trunk/geom/Cholla/FacetorUtil.hpp
> cgm/trunk/geom/CubitCompat.cpp
> cgm/trunk/geom/CubitCompat.h.in
> cgm/trunk/geom/CubitCompat.hpp
> cgm/trunk/geom/OCC/OCCHistory.cpp
> cgm/trunk/geom/OCC/OCCHistory.hpp
> cgm/trunk/geom/OCC/occ_attrib_history.hpp
> cgm/trunk/geom/OCC/occ_patches_6.5
> cgm/trunk/geom/PeriodicParamTool.cpp
> cgm/trunk/geom/PeriodicParamTool.hpp
> cgm/trunk/geom/testing/
> cgm/trunk/geom/testing/AngleCalc.cpp
> cgm/trunk/geom/testing/CMakeLists.txt
> cgm/trunk/geom/testing/CreateGeometry.cpp
> cgm/trunk/geom/testing/GraphicsData.cpp
> cgm/trunk/geom/testing/Makefile.am
> cgm/trunk/geom/testing/ReadIgesFile.cpp
> cgm/trunk/geom/testing/TestConfig.h.in
> cgm/trunk/geom/testing/TestUtilities.cpp
> cgm/trunk/geom/testing/TestUtilities.hpp
> cgm/trunk/geom/testing/cgm_test.cpp
> cgm/trunk/geom/testing/cgm_test.hpp
> cgm/trunk/geom/testing/cgm_test_script
> cgm/trunk/geom/testing/data/
> cgm/trunk/geom/testing/data/brick.iges
> cgm/trunk/geom/testing/main.cpp
> cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.cpp
> cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.hpp
> cgm/trunk/test/Cylinder_1.brep
> cgm/trunk/test/Cylinder_2.brep
> cgm/trunk/util/CommandFeedback.hpp
> cgm/trunk/util/CubitUndo.cpp
> cgm/trunk/util/CubitUndo.hpp
> cgm/trunk/util/ExternalCoordinateSystem.hpp
> cgm/trunk/util/GlobalCommandFeedback.cpp
> cgm/trunk/util/GlobalCommandFeedback.hpp
> cgm/trunk/util/ManagedPtrVector.hpp
> cgm/trunk/util/OrderedMap.hpp
> cgm/trunk/util/OrderedSet.hpp
> Removed:
> Modified:
> cgm/trunk/
> cgm/trunk/Makefile.am
> cgm/trunk/cgm_apps/ccapi/geom/GeometryTool_ccapi.cpp
> cgm/trunk/cgm_apps/cgm_cubit_acis/main_cubit_acis.cpp
> cgm/trunk/cgm_apps/examples/driverc++/mergechk.cpp
> cgm/trunk/cgm_apps/examples/gomadrive/gm_cgm_c_interface.C
> cgm/trunk/configure.ac
> cgm/trunk/geom/
> cgm/trunk/geom/ACIS_SRC/AcisBridge.cpp
> cgm/trunk/geom/ACIS_SRC/AcisDrawTool.cpp
> cgm/trunk/geom/ACIS_SRC/AcisEdgeTool.cpp
> cgm/trunk/geom/ACIS_SRC/AcisFacetManager.cpp
> cgm/trunk/geom/ACIS_SRC/AcisFacetManager.hpp
> cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.cpp
> cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.hpp
> cgm/trunk/geom/ACIS_SRC/AcisHealerTool.cpp
> cgm/trunk/geom/ACIS_SRC/AcisHealerTool.hpp
> cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
> cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
> cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp
> cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp
> cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.cpp
> cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.hpp
> cgm/trunk/geom/ACIS_SRC/AcisToolUtil.cpp
> cgm/trunk/geom/ACIS_SRC/AcisToolUtil.hpp
> cgm/trunk/geom/ACIS_SRC/AcisTweakTool.cpp
> cgm/trunk/geom/ACIS_SRC/AcisTweakTool.hpp
> cgm/trunk/geom/ACIS_SRC/BodyACIS.cpp
> cgm/trunk/geom/ACIS_SRC/BodyACIS.hpp
> cgm/trunk/geom/ACIS_SRC/CMakeLists.txt
> cgm/trunk/geom/ACIS_SRC/CoEdgeACIS.cpp
> cgm/trunk/geom/ACIS_SRC/CurveACIS.cpp
> cgm/trunk/geom/ACIS_SRC/CurveACIS.hpp
> cgm/trunk/geom/ACIS_SRC/LoopACIS.cpp
> cgm/trunk/geom/ACIS_SRC/LoopACIS.hpp
> cgm/trunk/geom/ACIS_SRC/LumpACIS.cpp
> cgm/trunk/geom/ACIS_SRC/LumpACIS.hpp
> cgm/trunk/geom/ACIS_SRC/Makefile.am
> cgm/trunk/geom/ACIS_SRC/PointACIS.cpp
> cgm/trunk/geom/ACIS_SRC/ShellACIS.cpp
> cgm/trunk/geom/ACIS_SRC/SurfaceACIS.cpp
> cgm/trunk/geom/ACIS_SRC/SurfaceACIS.hpp
> cgm/trunk/geom/ACIS_SRC/UseACIS.cmake
> cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.cpp
> cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.hpp
> cgm/trunk/geom/ACIS_SRC/attrib_snl.cpp
> cgm/trunk/geom/ACIS_SRC/attrib_snl.hpp
> cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.cpp
> cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.hpp
> cgm/trunk/geom/ACIS_SRC/decl_none.h
> cgm/trunk/geom/ACIS_SRC/gtcAttrib/CMakeLists.txt
> cgm/trunk/geom/ACIS_SRC/gtcAttrib/Makefile
> cgm/trunk/geom/ACIS_SRC/gtcAttrib/incl/attrib_gtc_export.h
> cgm/trunk/geom/AllocMemManagersGeom.cpp
> cgm/trunk/geom/AnalyticGeometryTool.cpp
> cgm/trunk/geom/AnalyticGeometryTool.hpp
> cgm/trunk/geom/BasicTopologyEntity.cpp
> cgm/trunk/geom/BasicTopologyEntity.hpp
> cgm/trunk/geom/Body.cpp
> cgm/trunk/geom/Body.hpp
> cgm/trunk/geom/BodySM.cpp
> cgm/trunk/geom/BodySM.hpp
> cgm/trunk/geom/BoundingBoxTool.cpp
> cgm/trunk/geom/BoundingBoxTool.hpp
> cgm/trunk/geom/BridgeManager.cpp
> cgm/trunk/geom/BridgeManager.hpp
> cgm/trunk/geom/CAActuateSet.cpp
> cgm/trunk/geom/CAActuateSet.hpp
> cgm/trunk/geom/CADeferredAttrib.cpp
> cgm/trunk/geom/CADeferredAttrib.hpp
> cgm/trunk/geom/CADefines.hpp
> cgm/trunk/geom/CAEntityColor.cpp
> cgm/trunk/geom/CAEntityColor.hpp
> cgm/trunk/geom/CAEntityId.cpp
> cgm/trunk/geom/CAEntityId.hpp
> cgm/trunk/geom/CAEntityName.cpp
> cgm/trunk/geom/CAEntityName.hpp
> cgm/trunk/geom/CAGroup.cpp
> cgm/trunk/geom/CAGroup.hpp
> cgm/trunk/geom/CAMergePartner.cpp
> cgm/trunk/geom/CAMergePartner.hpp
> cgm/trunk/geom/CAMergeStatus.cpp
> cgm/trunk/geom/CAMergeStatus.hpp
> cgm/trunk/geom/CASourceFeature.cpp
> cgm/trunk/geom/CASourceFeature.hpp
> cgm/trunk/geom/CAUniqueId.cpp
> cgm/trunk/geom/CAUniqueId.hpp
> cgm/trunk/geom/CGMApp.cpp
> cgm/trunk/geom/CGMApp.hpp
> cgm/trunk/geom/CGMEngineDynamicLoader.cpp
> cgm/trunk/geom/CGMEngineDynamicLoader.hpp
> cgm/trunk/geom/CMakeLists.txt
> cgm/trunk/geom/Chain.cpp
> cgm/trunk/geom/Chain.hpp
> cgm/trunk/geom/Cholla/CMakeLists.txt
> cgm/trunk/geom/Cholla/Cholla.cpp
> cgm/trunk/geom/Cholla/ChollaCurve.cpp
> cgm/trunk/geom/Cholla/ChollaCurve.hpp
> cgm/trunk/geom/Cholla/ChollaEngine.cpp
> cgm/trunk/geom/Cholla/ChollaEngine.hpp
> cgm/trunk/geom/Cholla/ChollaPoint.cpp
> cgm/trunk/geom/Cholla/ChollaPoint.hpp
> cgm/trunk/geom/Cholla/ChollaSurface.cpp
> cgm/trunk/geom/Cholla/ChollaSurface.hpp
> cgm/trunk/geom/Cholla/CubitFacet.cpp
> cgm/trunk/geom/Cholla/CubitFacet.hpp
> cgm/trunk/geom/Cholla/CubitFacetData.cpp
> cgm/trunk/geom/Cholla/CubitFacetData.hpp
> cgm/trunk/geom/Cholla/CubitFacetEdge.hpp
> cgm/trunk/geom/Cholla/CurveFacetEvalTool.cpp
> cgm/trunk/geom/Cholla/CurveFacetEvalTool.hpp
> cgm/trunk/geom/Cholla/FacetDataUtil.cpp
> cgm/trunk/geom/Cholla/FacetDataUtil.hpp
> cgm/trunk/geom/Cholla/FacetEvalTool.cpp
> cgm/trunk/geom/Cholla/FacetEvalTool.hpp
> cgm/trunk/geom/Cholla/FacetorTool.cpp
> cgm/trunk/geom/Cholla/FacetorTool.hpp
> cgm/trunk/geom/Cholla/LoopParamTool.cpp
> cgm/trunk/geom/Cholla/LoopParamTool.hpp
> cgm/trunk/geom/Cholla/Makefile.am
> cgm/trunk/geom/Cholla/TDGeomFacet.cpp
> cgm/trunk/geom/Cholla/TDGeomFacet.hpp
> cgm/trunk/geom/Cholla/debug.cpp
> cgm/trunk/geom/Cholla/debug.hpp
> cgm/trunk/geom/CoEdge.cpp
> cgm/trunk/geom/CoEdge.hpp
> cgm/trunk/geom/CoEdgeSM.cpp
> cgm/trunk/geom/CoEdgeSM.hpp
> cgm/trunk/geom/CoFace.cpp
> cgm/trunk/geom/CoFace.hpp
> cgm/trunk/geom/CoVertex.cpp
> cgm/trunk/geom/CoVertex.hpp
> cgm/trunk/geom/CoVolume.cpp
> cgm/trunk/geom/CoVolume.hpp
> cgm/trunk/geom/CollectionEntity.cpp
> cgm/trunk/geom/CollectionEntity.hpp
> cgm/trunk/geom/CompositeCombineEvent.hpp
> cgm/trunk/geom/CubitAttrib.cpp
> cgm/trunk/geom/CubitAttrib.hpp
> cgm/trunk/geom/CubitAttribManager.cpp
> cgm/trunk/geom/CubitAttribManager.hpp
> cgm/trunk/geom/CubitAttribUser.cpp
> cgm/trunk/geom/CubitAttribUser.hpp
> cgm/trunk/geom/CubitEvaluator.hpp
> cgm/trunk/geom/CubitGeomConfigure.h
> cgm/trunk/geom/CubitGeomConfigure.h.in
> cgm/trunk/geom/CubitPolygon.cpp
> cgm/trunk/geom/CubitPolygon.hpp
> cgm/trunk/geom/CubitSimpleAttrib.cpp
> cgm/trunk/geom/CubitSimpleAttrib.hpp
> cgm/trunk/geom/Curve.cpp
> cgm/trunk/geom/Curve.hpp
> cgm/trunk/geom/CurveOverlapFacet.cpp
> cgm/trunk/geom/CurveOverlapFacet.hpp
> cgm/trunk/geom/CurveSM.cpp
> cgm/trunk/geom/CurveSM.hpp
> cgm/trunk/geom/CylinderEvaluator.cpp
> cgm/trunk/geom/CylinderEvaluator.hpp
> cgm/trunk/geom/DAG.cpp
> cgm/trunk/geom/DAG.hpp
> cgm/trunk/geom/DagDrawingTool.cpp
> cgm/trunk/geom/DagDrawingTool.hpp
> cgm/trunk/geom/DagType.hpp
> cgm/trunk/geom/GSaveOpen.cpp
> cgm/trunk/geom/GSaveOpen.hpp
> cgm/trunk/geom/GeomDataObserver.cpp
> cgm/trunk/geom/GeomDataObserver.hpp
> cgm/trunk/geom/GeomMeasureTool.cpp
> cgm/trunk/geom/GeomMeasureTool.hpp
> cgm/trunk/geom/GeomPoint.hpp
> cgm/trunk/geom/GeomSeg.hpp
> cgm/trunk/geom/GeometryEntity.cpp
> cgm/trunk/geom/GeometryEntity.hpp
> cgm/trunk/geom/GeometryFeatureEngine.cpp
> cgm/trunk/geom/GeometryFeatureEngine.hpp
> cgm/trunk/geom/GeometryFeatureTool.cpp
> cgm/trunk/geom/GeometryFeatureTool.hpp
> cgm/trunk/geom/GeometryHealerEngine.cpp
> cgm/trunk/geom/GeometryHealerEngine.hpp
> cgm/trunk/geom/GeometryHealerTool.cpp
> cgm/trunk/geom/GeometryHealerTool.hpp
> cgm/trunk/geom/GeometryModifyEngine.cpp
> cgm/trunk/geom/GeometryModifyEngine.hpp
> cgm/trunk/geom/GeometryModifyTool.cpp
> cgm/trunk/geom/GeometryModifyTool.hpp
> cgm/trunk/geom/GeometryQueryEngine.cpp
> cgm/trunk/geom/GeometryQueryEngine.hpp
> cgm/trunk/geom/GeometryQueryTool.cpp
> cgm/trunk/geom/GeometryQueryTool.hpp
> cgm/trunk/geom/GeometryUtil.cpp
> cgm/trunk/geom/GeometryUtil.hpp
> cgm/trunk/geom/GfxPreview.cpp
> cgm/trunk/geom/GfxPreview.hpp
> cgm/trunk/geom/GroupingEntity.cpp
> cgm/trunk/geom/GroupingEntity.hpp
> cgm/trunk/geom/IntermediateGeomEngine.hpp
> cgm/trunk/geom/Loop.cpp
> cgm/trunk/geom/Loop.hpp
> cgm/trunk/geom/LoopSM.cpp
> cgm/trunk/geom/LoopSM.hpp
> cgm/trunk/geom/Lump.cpp
> cgm/trunk/geom/Lump.hpp
> cgm/trunk/geom/LumpSM.cpp
> cgm/trunk/geom/LumpSM.hpp
> cgm/trunk/geom/Makefile.am
> cgm/trunk/geom/MedialTool2D.cpp
> cgm/trunk/geom/MedialTool2D.hpp
> cgm/trunk/geom/MedialTool3D.cpp
> cgm/trunk/geom/MedialTool3D.hpp
> cgm/trunk/geom/MergeTool.cpp
> cgm/trunk/geom/MergeTool.hpp
> cgm/trunk/geom/MergeToolAssistant.cpp
> cgm/trunk/geom/MergeToolAssistant.hpp
> cgm/trunk/geom/MidPlaneTool.cpp
> cgm/trunk/geom/MidPlaneTool.hpp
> cgm/trunk/geom/ModelEntity.cpp
> cgm/trunk/geom/ModelEntity.hpp
> cgm/trunk/geom/ModelQueryEngine.cpp
> cgm/trunk/geom/ModelQueryEngine.hpp
> cgm/trunk/geom/OCC/
> cgm/trunk/geom/OCC/Makefile.am
> cgm/trunk/geom/OCC/OCCAttribSet.cpp
> cgm/trunk/geom/OCC/OCCBody.cpp
> cgm/trunk/geom/OCC/OCCCurve.cpp
> cgm/trunk/geom/OCC/OCCDrawTool.cpp
> cgm/trunk/geom/OCC/OCCLoop.cpp
> cgm/trunk/geom/OCC/OCCLoop.hpp
> cgm/trunk/geom/OCC/OCCLump.cpp
> cgm/trunk/geom/OCC/OCCLump.hpp
> cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> cgm/trunk/geom/OCC/OCCModifyEngine.hpp
> cgm/trunk/geom/OCC/OCCPoint.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.hpp
> cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
> cgm/trunk/geom/OCC/OCCShell.cpp
> cgm/trunk/geom/OCC/OCCSurface.cpp
> cgm/trunk/geom/OCC/OCCSurface.hpp
> cgm/trunk/geom/OffsetSplitTool.cpp
> cgm/trunk/geom/OffsetSplitTool.hpp
> cgm/trunk/geom/OldUnmergeCode.cpp
> cgm/trunk/geom/OldUnmergeCode.hpp
> cgm/trunk/geom/Point.cpp
> cgm/trunk/geom/Point.hpp
> cgm/trunk/geom/PointSM.cpp
> cgm/trunk/geom/PointSM.hpp
> cgm/trunk/geom/RefCollection.cpp
> cgm/trunk/geom/RefCollection.hpp
> cgm/trunk/geom/RefEdge.cpp
> cgm/trunk/geom/RefEdge.hpp
> cgm/trunk/geom/RefEntity.cpp
> cgm/trunk/geom/RefEntity.hpp
> cgm/trunk/geom/RefEntityFactory.cpp
> cgm/trunk/geom/RefEntityFactory.hpp
> cgm/trunk/geom/RefEntityName.cpp
> cgm/trunk/geom/RefEntityName.hpp
> cgm/trunk/geom/RefEntityNameMap.hpp
> cgm/trunk/geom/RefFace.cpp
> cgm/trunk/geom/RefFace.hpp
> cgm/trunk/geom/RefGroup.cpp
> cgm/trunk/geom/RefGroup.hpp
> cgm/trunk/geom/RefVertex.cpp
> cgm/trunk/geom/RefVertex.hpp
> cgm/trunk/geom/RefVolume.cpp
> cgm/trunk/geom/RefVolume.hpp
> cgm/trunk/geom/SenseEntity.cpp
> cgm/trunk/geom/SenseEntity.hpp
> cgm/trunk/geom/Shell.cpp
> cgm/trunk/geom/Shell.hpp
> cgm/trunk/geom/ShellSM.cpp
> cgm/trunk/geom/ShellSM.hpp
> cgm/trunk/geom/SolidWorks/
> cgm/trunk/geom/SphereEvaluator.cpp
> cgm/trunk/geom/SphereEvaluator.hpp
> cgm/trunk/geom/SplitSurfaceTool.cpp
> cgm/trunk/geom/SplitSurfaceTool.hpp
> cgm/trunk/geom/SurfParamTool.cpp
> cgm/trunk/geom/SurfParamTool.hpp
> cgm/trunk/geom/Surface.cpp
> cgm/trunk/geom/Surface.hpp
> cgm/trunk/geom/SurfaceOverlapFacet.cpp
> cgm/trunk/geom/SurfaceOverlapFacet.hpp
> cgm/trunk/geom/SurfaceOverlapTool.cpp
> cgm/trunk/geom/SurfaceOverlapTool.hpp
> cgm/trunk/geom/SurfaceSM.cpp
> cgm/trunk/geom/SurfaceSM.hpp
> cgm/trunk/geom/TBOwner.hpp
> cgm/trunk/geom/TBOwnerSet.hpp
> cgm/trunk/geom/TDCAGE.cpp
> cgm/trunk/geom/TDCAGE.hpp
> cgm/trunk/geom/TDCompare.hpp
> cgm/trunk/geom/TDSourceFeature.cpp
> cgm/trunk/geom/TDSourceFeature.hpp
> cgm/trunk/geom/TDSplitSurface.cpp
> cgm/trunk/geom/TDSplitSurface.hpp
> cgm/trunk/geom/TDSurfaceOverlap.cpp
> cgm/trunk/geom/TDSurfaceOverlap.hpp
> cgm/trunk/geom/TDUniqueId.cpp
> cgm/trunk/geom/TDUniqueId.hpp
> cgm/trunk/geom/TopologyBridge.cpp
> cgm/trunk/geom/TopologyBridge.hpp
> cgm/trunk/geom/TopologyEntity.cpp
> cgm/trunk/geom/TopologyEntity.hpp
> cgm/trunk/geom/UnMergeEvent.hpp
> cgm/trunk/geom/facet/
> cgm/trunk/geom/facet/FacetCurve.cpp
> cgm/trunk/geom/facet/FacetLoop.cpp
> cgm/trunk/geom/facet/FacetLoop.hpp
> cgm/trunk/geom/facet/FacetModifyEngine.cpp
> cgm/trunk/geom/facet/FacetModifyEngine.hpp
> cgm/trunk/geom/facet/FacetParamTool.cpp
> cgm/trunk/geom/facet/FacetParamTool.hpp
> cgm/trunk/geom/facet/FacetQueryEngine.cpp
> cgm/trunk/geom/facet/FacetQueryEngine.hpp
> cgm/trunk/geom/facet/FacetboolInterface.cpp
> cgm/trunk/geom/facetbool/
> cgm/trunk/geom/facetbool/FBRetriangulate.cpp
> cgm/trunk/geom/libcubit_geom.dsp
> cgm/trunk/geom/parallel/
> cgm/trunk/geom/parallel/CGMmpi.h
> cgm/trunk/geom/parallel/CGMmpi_config.h.in
> cgm/trunk/geom/virtual/CMakeLists.txt
> cgm/trunk/geom/virtual/CollapseCurveTool.cpp
> cgm/trunk/geom/virtual/CollapseCurveTool.hpp
> cgm/trunk/geom/virtual/CompSurfFacets.cpp
> cgm/trunk/geom/virtual/CompositeEngine.cpp
> cgm/trunk/geom/virtual/CompositeEngine.hpp
> cgm/trunk/geom/virtual/CompositeGeom.cpp
> cgm/trunk/geom/virtual/CompositeGeom.hpp
> cgm/trunk/geom/virtual/CompositeLoop.cpp
> cgm/trunk/geom/virtual/CompositeLoop.hpp
> cgm/trunk/geom/virtual/CompositeSurface.cpp
> cgm/trunk/geom/virtual/CompositeSurface.hpp
> cgm/trunk/geom/virtual/CompositeTool.cpp
> cgm/trunk/geom/virtual/FacetProjectTool.cpp
> cgm/trunk/geom/virtual/FacetProjectTool.hpp
> cgm/trunk/geom/virtual/Faceter.cpp
> cgm/trunk/geom/virtual/ImprintBoundaryTool.cpp
> cgm/trunk/geom/virtual/Makefile.am
> cgm/trunk/geom/virtual/PartSurfFacetTool.cpp
> cgm/trunk/geom/virtual/PartitionEngine.cpp
> cgm/trunk/geom/virtual/PartitionEngine.hpp
> cgm/trunk/geom/virtual/PartitionLoop.cpp
> cgm/trunk/geom/virtual/PartitionLoop.hpp
> cgm/trunk/geom/virtual/PartitionSurface.cpp
> cgm/trunk/geom/virtual/PartitionTool.cpp
> cgm/trunk/geom/virtual/RemoveBlends.cpp
> cgm/trunk/geom/virtual/SimplifyTool.cpp
> cgm/trunk/geom/virtual/SimplifyTool.hpp
> cgm/trunk/geom/virtual/SubCurve.cpp
> cgm/trunk/geom/virtual/SubSurface.cpp
> cgm/trunk/geom/virtual/VGLoopTool.cpp
> cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
> cgm/trunk/geom/virtual/VirtualQueryEngine.hpp
> cgm/trunk/init/InitCGMA.cpp
> cgm/trunk/itaps/iGeom_CGMA.cc
> cgm/trunk/itaps/testgeom.cc
> cgm/trunk/test/makept.cpp
> cgm/trunk/test/merge_test.cpp
> cgm/trunk/test/modify.cpp
> cgm/trunk/test/operation.cpp
> cgm/trunk/test/r_w.cpp
> cgm/trunk/test/test_occ.cpp
> cgm/trunk/test/webcut.cpp
> cgm/trunk/util/AppUtil.cpp
> cgm/trunk/util/AppUtil.hpp
> cgm/trunk/util/ArrayBasedContainer.cpp
> cgm/trunk/util/CMakeLists.txt
> cgm/trunk/util/CastTo.hpp
> cgm/trunk/util/CpuTimer.cpp
> cgm/trunk/util/CpuTimer.hpp
> cgm/trunk/util/CubitBox.cpp
> cgm/trunk/util/CubitBox.hpp
> cgm/trunk/util/CubitColorConstants.hpp
> cgm/trunk/util/CubitCoordinateSystem.cpp
> cgm/trunk/util/CubitDefines.h
> cgm/trunk/util/CubitDynamicLoader.cpp
> cgm/trunk/util/CubitEntity.cpp
> cgm/trunk/util/CubitEventDefines.h
> cgm/trunk/util/CubitFile.cpp
> cgm/trunk/util/CubitFile.hpp
> cgm/trunk/util/CubitFileFEModel.cpp
> cgm/trunk/util/CubitFileFEModel.hpp
> cgm/trunk/util/CubitFileIOWrapper.cpp
> cgm/trunk/util/CubitFileIOWrapper.hpp
> cgm/trunk/util/CubitFileMetaData.cpp
> cgm/trunk/util/CubitFileUtil.cpp
> cgm/trunk/util/CubitInputFile.hpp
> cgm/trunk/util/CubitMatrix.cpp
> cgm/trunk/util/CubitMessage.cpp
> cgm/trunk/util/CubitMessage.hpp
> cgm/trunk/util/CubitPlane.cpp
> cgm/trunk/util/CubitPlane.hpp
> cgm/trunk/util/CubitStack.cpp
> cgm/trunk/util/CubitString.cpp
> cgm/trunk/util/CubitString.hpp
> cgm/trunk/util/CubitTransformMatrix.cpp
> cgm/trunk/util/CubitTransformMatrix.hpp
> cgm/trunk/util/CubitUtil.cpp
> cgm/trunk/util/CubitUtil.hpp
> cgm/trunk/util/CubitUtilConfigure.h.in
> cgm/trunk/util/CubitVector.cpp
> cgm/trunk/util/CubitVector.hpp
> cgm/trunk/util/DIntArray.cpp
> cgm/trunk/util/DLIList.cpp
> cgm/trunk/util/DLIList.hpp
> cgm/trunk/util/DLList.hpp
> cgm/trunk/util/DynamicArray.cpp
> cgm/trunk/util/DynamicArray.hpp
> cgm/trunk/util/ElementType.h
> cgm/trunk/util/GMem.cpp
> cgm/trunk/util/GeometryDefines.h
> cgm/trunk/util/GetLongOpt.hpp
> cgm/trunk/util/GfxDebug.cpp
> cgm/trunk/util/GfxDebug.hpp
> cgm/trunk/util/IntersectionTool.cpp
> cgm/trunk/util/IntersectionTool.hpp
> cgm/trunk/util/KDDTree.cpp
> cgm/trunk/util/Makefile.am
> cgm/trunk/util/MemoryBlock.hpp
> cgm/trunk/util/MemoryManager.cpp
> cgm/trunk/util/MemoryManager.hpp
> cgm/trunk/util/OctTree.cpp
> cgm/trunk/util/OtherFiles/make.client
> cgm/trunk/util/ParamTool.hpp
> cgm/trunk/util/PlanarParamTool.cpp
> cgm/trunk/util/PlanarParamTool.hpp
> cgm/trunk/util/PriorityQueue.cpp
> cgm/trunk/util/RTree.cpp
> cgm/trunk/util/RTree.hpp
> cgm/trunk/util/RandomMersenne.cpp
> cgm/trunk/util/SDLList.cpp
> cgm/trunk/util/SDLList.hpp
> cgm/trunk/util/SettingHandler.cpp
> cgm/trunk/util/SettingHandler.hpp
> cgm/trunk/util/TextProgressTool.cpp
> cgm/trunk/util/ToolData.cpp
> cgm/trunk/util/ToolData.hpp
> cgm/trunk/util/ToolDataUser.cpp
> cgm/trunk/util/ToolDataUser.hpp
> cgm/trunk/util/TtyProgressTool.cpp
> Log:
> Merge branch/merge-cubit12 to trunk, passed all testcases for
> OCC6.3(build with /geom/OCC/occ_patches), OCC6.5(build with
> /geom/OCC/occ_patches_6.5), acis17 as well as cubit12 builds. Special
> note: When building with cubit12, current test code doesn't do
> anything for geom/testing directory. Status is <All 0 tests passed>.
> Property changes on: cgm/trunk
> ___________________________________________________________________
> Added: svn:mergeinfo
> + /cgm/branches/cubit:1041-3427
> /cgm/branches/merge-cubit12:3424-4774
> Deleted: cgm/trunk/KNOWN_ISSUES
> --- cgm/trunk/KNOWN_ISSUES 2011-04-23 05:15:17 UTC (rev 4774)
> +++ cgm/trunk/KNOWN_ISSUES 2011-04-26 17:54:11 UTC (rev 4775)
> @@ -1,27 +0,0 @@
> -This is a list of the known issues with CGM on OCC.For more details
> please see
> -the online ticket system at the MOAB website:
> - https://trac.mcs.anl.gov/projects/ITAPS/wiki
> -ID Severity Summary/Details
> -175 critical imprint special cases fail with crash.
> -176 minor CGM memory leak
> -178 major Unite function doesn't unite smoothly connected surfaces.
> -179 major mcnp2cad test suite lat1-7 not working, needs debugging.
> -180 major There are lots new functions or added functions to
> exsisting
> - functions requirements to port OCC to cubit12.
> -181 minor Lack of good cases for testing purpose.
> -182 minor Dirty geometry/imported geometry is not tested for
> read/repair yet
> -183 minor Don't have proper tool to visualize the TopoDS_Shapes,
> debugging
> - process is long preparing for graphics to understand the issue
> -185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2
> spline
> - surfaces.
> Added: cgm/trunk/KNOWN_ISSUES
> --- cgm/trunk/KNOWN_ISSUES (rev 0)
> @@ -0,0 +1,27 @@
> +This is a list of the known issues with CGM on OCC.For more details
> please see
> +the online ticket system at the MOAB website:
> + https://trac.mcs.anl.gov/projects/ITAPS/wiki
More information about the cgma-dev
