[cgma-dev] r4775 - in cgm/trunk: .	cgm_apps/ccapi/geom	cgm_apps/cgm_cubit_acis	cgm_apps/examples/driverc++	cgm_apps/examples/gomadrive geom	geom/ACIS_SRC geom/ACIS_SRC/gtcAttrib	geom/ACIS_SRC/gtcAttrib/incl	geom/Cholla geom/OCC	geom/SolidWorks geom/facet	geom/facetbool geom/parallel	geom/testing geom/testing/data geom/virtual init itaps test	util util/OtherFiles
    Steve Jackson
    sjackson at cae.wisc.edu
    Tue Apr 26 15:00:49 CDT 2011
I think support for 10.2 is gone-- I tried a 10.2-based compile, but it fails in make check.
~S
On Apr 26, 2011, at 14:39 , Tim Tautges wrote:
> No, 10.2 should still be supported (Jane, can you check that too?)
> - tim
> On 04/26/2011 02:30 PM, Rajeev Jain wrote:
>> Would this change mean that Cubit-10.2 is no longer supported?
>> Rajeev
>>    *From:* "jiangtao_ma at yahoo.com" <jiangtao_ma at yahoo.com>
>>    *To:* cgma-dev at mcs.anl.gov
>>    *Sent:* Tuesday, April 26, 2011 12:54 PM
>>    *Subject:* [cgma-dev] r4775 - in cgm/trunk: . cgm_apps/ccapi/geom
>>    util/OtherFiles
>>    Author: janehu
>>    Date: 2011-04-26 12:54:11 -0500 (Tue, 26 Apr 2011)
>>    New Revision: 4775
>>    Added:
>>    cgm/trunk/KNOWN_ISSUES
>>    cgm/trunk/geom/ACIS_SRC/AcisHistory.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisHistory.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.hpp
>>    cgm/trunk/geom/ACIS_SRC/attrib_history.cpp
>>    cgm/trunk/geom/ACIS_SRC/attrib_history.hpp
>>    cgm/trunk/geom/AutoMidsurfaceTool.cpp
>>    cgm/trunk/geom/AutoMidsurfaceTool.hpp
>>    cgm/trunk/geom/CGMHistory.cpp
>>    cgm/trunk/geom/CGMHistory.hpp
>>    cgm/trunk/geom/Cholla/ChollaVolume.cpp
>>    cgm/trunk/geom/Cholla/ChollaVolume.hpp
>>    cgm/trunk/geom/Cholla/FacetorUtil.cpp
>>    cgm/trunk/geom/Cholla/FacetorUtil.hpp
>>    cgm/trunk/geom/CubitCompat.cpp
>>    cgm/trunk/geom/CubitCompat.h.in
>>    cgm/trunk/geom/CubitCompat.hpp
>>    cgm/trunk/geom/OCC/OCCHistory.cpp
>>    cgm/trunk/geom/OCC/OCCHistory.hpp
>>    cgm/trunk/geom/OCC/occ_attrib_history.hpp
>>    cgm/trunk/geom/OCC/occ_patches_6.5
>>    cgm/trunk/geom/PeriodicParamTool.cpp
>>    cgm/trunk/geom/PeriodicParamTool.hpp
>>    cgm/trunk/geom/testing/
>>    cgm/trunk/geom/testing/AngleCalc.cpp
>>    cgm/trunk/geom/testing/CMakeLists.txt
>>    cgm/trunk/geom/testing/CreateGeometry.cpp
>>    cgm/trunk/geom/testing/GraphicsData.cpp
>>    cgm/trunk/geom/testing/Makefile.am
>>    cgm/trunk/geom/testing/ReadIgesFile.cpp
>>    cgm/trunk/geom/testing/TestConfig.h.in
>>    cgm/trunk/geom/testing/TestUtilities.cpp
>>    cgm/trunk/geom/testing/TestUtilities.hpp
>>    cgm/trunk/geom/testing/cgm_test.cpp
>>    cgm/trunk/geom/testing/cgm_test.hpp
>>    cgm/trunk/geom/testing/cgm_test_script
>>    cgm/trunk/geom/testing/data/
>>    cgm/trunk/geom/testing/data/brick.iges
>>    cgm/trunk/geom/testing/main.cpp
>>    cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.cpp
>>    cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.hpp
>>    cgm/trunk/test/Cylinder_1.brep
>>    cgm/trunk/test/Cylinder_2.brep
>>    cgm/trunk/util/CommandFeedback.hpp
>>    cgm/trunk/util/CubitUndo.cpp
>>    cgm/trunk/util/CubitUndo.hpp
>>    cgm/trunk/util/ExternalCoordinateSystem.hpp
>>    cgm/trunk/util/GlobalCommandFeedback.cpp
>>    cgm/trunk/util/GlobalCommandFeedback.hpp
>>    cgm/trunk/util/ManagedPtrVector.hpp
>>    cgm/trunk/util/OrderedMap.hpp
>>    cgm/trunk/util/OrderedSet.hpp
>>    Removed:
>>    Modified:
>>    cgm/trunk/
>>    cgm/trunk/Makefile.am
>>    cgm/trunk/cgm_apps/ccapi/geom/GeometryTool_ccapi.cpp
>>    cgm/trunk/cgm_apps/cgm_cubit_acis/main_cubit_acis.cpp
>>    cgm/trunk/cgm_apps/examples/driverc++/mergechk.cpp
>>    cgm/trunk/cgm_apps/examples/gomadrive/gm_cgm_c_interface.C
>>    cgm/trunk/configure.ac
>>    cgm/trunk/geom/
>>    cgm/trunk/geom/ACIS_SRC/AcisBridge.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisDrawTool.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisEdgeTool.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisFacetManager.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisFacetManager.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisHealerTool.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisHealerTool.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisToolUtil.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisToolUtil.hpp
>>    cgm/trunk/geom/ACIS_SRC/AcisTweakTool.cpp
>>    cgm/trunk/geom/ACIS_SRC/AcisTweakTool.hpp
>>    cgm/trunk/geom/ACIS_SRC/BodyACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/BodyACIS.hpp
>>    cgm/trunk/geom/ACIS_SRC/CMakeLists.txt
>>    cgm/trunk/geom/ACIS_SRC/CoEdgeACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/CurveACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/CurveACIS.hpp
>>    cgm/trunk/geom/ACIS_SRC/LoopACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/LoopACIS.hpp
>>    cgm/trunk/geom/ACIS_SRC/LumpACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/LumpACIS.hpp
>>    cgm/trunk/geom/ACIS_SRC/Makefile.am
>>    cgm/trunk/geom/ACIS_SRC/PointACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/ShellACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/SurfaceACIS.cpp
>>    cgm/trunk/geom/ACIS_SRC/SurfaceACIS.hpp
>>    cgm/trunk/geom/ACIS_SRC/UseACIS.cmake
>>    cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.cpp
>>    cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.hpp
>>    cgm/trunk/geom/ACIS_SRC/attrib_snl.cpp
>>    cgm/trunk/geom/ACIS_SRC/attrib_snl.hpp
>>    cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.cpp
>>    cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.hpp
>>    cgm/trunk/geom/ACIS_SRC/decl_none.h
>>    cgm/trunk/geom/ACIS_SRC/gtcAttrib/CMakeLists.txt
>>    cgm/trunk/geom/ACIS_SRC/gtcAttrib/Makefile
>>    cgm/trunk/geom/ACIS_SRC/gtcAttrib/incl/attrib_gtc_export.h
>>    cgm/trunk/geom/AllocMemManagersGeom.cpp
>>    cgm/trunk/geom/AnalyticGeometryTool.cpp
>>    cgm/trunk/geom/AnalyticGeometryTool.hpp
>>    cgm/trunk/geom/BasicTopologyEntity.cpp
>>    cgm/trunk/geom/BasicTopologyEntity.hpp
>>    cgm/trunk/geom/Body.cpp
>>    cgm/trunk/geom/Body.hpp
>>    cgm/trunk/geom/BodySM.cpp
>>    cgm/trunk/geom/BodySM.hpp
>>    cgm/trunk/geom/BoundingBoxTool.cpp
>>    cgm/trunk/geom/BoundingBoxTool.hpp
>>    cgm/trunk/geom/BridgeManager.cpp
>>    cgm/trunk/geom/BridgeManager.hpp
>>    cgm/trunk/geom/CAActuateSet.cpp
>>    cgm/trunk/geom/CAActuateSet.hpp
>>    cgm/trunk/geom/CADeferredAttrib.cpp
>>    cgm/trunk/geom/CADeferredAttrib.hpp
>>    cgm/trunk/geom/CADefines.hpp
>>    cgm/trunk/geom/CAEntityColor.cpp
>>    cgm/trunk/geom/CAEntityColor.hpp
>>    cgm/trunk/geom/CAEntityId.cpp
>>    cgm/trunk/geom/CAEntityId.hpp
>>    cgm/trunk/geom/CAEntityName.cpp
>>    cgm/trunk/geom/CAEntityName.hpp
>>    cgm/trunk/geom/CAGroup.cpp
>>    cgm/trunk/geom/CAGroup.hpp
>>    cgm/trunk/geom/CAMergePartner.cpp
>>    cgm/trunk/geom/CAMergePartner.hpp
>>    cgm/trunk/geom/CAMergeStatus.cpp
>>    cgm/trunk/geom/CAMergeStatus.hpp
>>    cgm/trunk/geom/CASourceFeature.cpp
>>    cgm/trunk/geom/CASourceFeature.hpp
>>    cgm/trunk/geom/CAUniqueId.cpp
>>    cgm/trunk/geom/CAUniqueId.hpp
>>    cgm/trunk/geom/CGMApp.cpp
>>    cgm/trunk/geom/CGMApp.hpp
>>    cgm/trunk/geom/CGMEngineDynamicLoader.cpp
>>    cgm/trunk/geom/CGMEngineDynamicLoader.hpp
>>    cgm/trunk/geom/CMakeLists.txt
>>    cgm/trunk/geom/Chain.cpp
>>    cgm/trunk/geom/Chain.hpp
>>    cgm/trunk/geom/Cholla/CMakeLists.txt
>>    cgm/trunk/geom/Cholla/Cholla.cpp
>>    cgm/trunk/geom/Cholla/ChollaCurve.cpp
>>    cgm/trunk/geom/Cholla/ChollaCurve.hpp
>>    cgm/trunk/geom/Cholla/ChollaEngine.cpp
>>    cgm/trunk/geom/Cholla/ChollaEngine.hpp
>>    cgm/trunk/geom/Cholla/ChollaPoint.cpp
>>    cgm/trunk/geom/Cholla/ChollaPoint.hpp
>>    cgm/trunk/geom/Cholla/ChollaSurface.cpp
>>    cgm/trunk/geom/Cholla/ChollaSurface.hpp
>>    cgm/trunk/geom/Cholla/CubitFacet.cpp
>>    cgm/trunk/geom/Cholla/CubitFacet.hpp
>>    cgm/trunk/geom/Cholla/CubitFacetData.cpp
>>    cgm/trunk/geom/Cholla/CubitFacetData.hpp
>>    cgm/trunk/geom/Cholla/CubitFacetEdge.hpp
>>    cgm/trunk/geom/Cholla/CurveFacetEvalTool.cpp
>>    cgm/trunk/geom/Cholla/CurveFacetEvalTool.hpp
>>    cgm/trunk/geom/Cholla/FacetDataUtil.cpp
>>    cgm/trunk/geom/Cholla/FacetDataUtil.hpp
>>    cgm/trunk/geom/Cholla/FacetEvalTool.cpp
>>    cgm/trunk/geom/Cholla/FacetEvalTool.hpp
>>    cgm/trunk/geom/Cholla/FacetorTool.cpp
>>    cgm/trunk/geom/Cholla/FacetorTool.hpp
>>    cgm/trunk/geom/Cholla/LoopParamTool.cpp
>>    cgm/trunk/geom/Cholla/LoopParamTool.hpp
>>    cgm/trunk/geom/Cholla/Makefile.am
>>    cgm/trunk/geom/Cholla/TDGeomFacet.cpp
>>    cgm/trunk/geom/Cholla/TDGeomFacet.hpp
>>    cgm/trunk/geom/Cholla/debug.cpp
>>    cgm/trunk/geom/Cholla/debug.hpp
>>    cgm/trunk/geom/CoEdge.cpp
>>    cgm/trunk/geom/CoEdge.hpp
>>    cgm/trunk/geom/CoEdgeSM.cpp
>>    cgm/trunk/geom/CoEdgeSM.hpp
>>    cgm/trunk/geom/CoFace.cpp
>>    cgm/trunk/geom/CoFace.hpp
>>    cgm/trunk/geom/CoVertex.cpp
>>    cgm/trunk/geom/CoVertex.hpp
>>    cgm/trunk/geom/CoVolume.cpp
>>    cgm/trunk/geom/CoVolume.hpp
>>    cgm/trunk/geom/CollectionEntity.cpp
>>    cgm/trunk/geom/CollectionEntity.hpp
>>    cgm/trunk/geom/CompositeCombineEvent.hpp
>>    cgm/trunk/geom/CubitAttrib.cpp
>>    cgm/trunk/geom/CubitAttrib.hpp
>>    cgm/trunk/geom/CubitAttribManager.cpp
>>    cgm/trunk/geom/CubitAttribManager.hpp
>>    cgm/trunk/geom/CubitAttribUser.cpp
>>    cgm/trunk/geom/CubitAttribUser.hpp
>>    cgm/trunk/geom/CubitEvaluator.hpp
>>    cgm/trunk/geom/CubitGeomConfigure.h
>>    cgm/trunk/geom/CubitGeomConfigure.h.in
>>    cgm/trunk/geom/CubitPolygon.cpp
>>    cgm/trunk/geom/CubitPolygon.hpp
>>    cgm/trunk/geom/CubitSimpleAttrib.cpp
>>    cgm/trunk/geom/CubitSimpleAttrib.hpp
>>    cgm/trunk/geom/Curve.cpp
>>    cgm/trunk/geom/Curve.hpp
>>    cgm/trunk/geom/CurveOverlapFacet.cpp
>>    cgm/trunk/geom/CurveOverlapFacet.hpp
>>    cgm/trunk/geom/CurveSM.cpp
>>    cgm/trunk/geom/CurveSM.hpp
>>    cgm/trunk/geom/CylinderEvaluator.cpp
>>    cgm/trunk/geom/CylinderEvaluator.hpp
>>    cgm/trunk/geom/DAG.cpp
>>    cgm/trunk/geom/DAG.hpp
>>    cgm/trunk/geom/DagDrawingTool.cpp
>>    cgm/trunk/geom/DagDrawingTool.hpp
>>    cgm/trunk/geom/DagType.hpp
>>    cgm/trunk/geom/GSaveOpen.cpp
>>    cgm/trunk/geom/GSaveOpen.hpp
>>    cgm/trunk/geom/GeomDataObserver.cpp
>>    cgm/trunk/geom/GeomDataObserver.hpp
>>    cgm/trunk/geom/GeomMeasureTool.cpp
>>    cgm/trunk/geom/GeomMeasureTool.hpp
>>    cgm/trunk/geom/GeomPoint.hpp
>>    cgm/trunk/geom/GeomSeg.hpp
>>    cgm/trunk/geom/GeometryEntity.cpp
>>    cgm/trunk/geom/GeometryEntity.hpp
>>    cgm/trunk/geom/GeometryFeatureEngine.cpp
>>    cgm/trunk/geom/GeometryFeatureEngine.hpp
>>    cgm/trunk/geom/GeometryFeatureTool.cpp
>>    cgm/trunk/geom/GeometryFeatureTool.hpp
>>    cgm/trunk/geom/GeometryHealerEngine.cpp
>>    cgm/trunk/geom/GeometryHealerEngine.hpp
>>    cgm/trunk/geom/GeometryHealerTool.cpp
>>    cgm/trunk/geom/GeometryHealerTool.hpp
>>    cgm/trunk/geom/GeometryModifyEngine.cpp
>>    cgm/trunk/geom/GeometryModifyEngine.hpp
>>    cgm/trunk/geom/GeometryModifyTool.cpp
>>    cgm/trunk/geom/GeometryModifyTool.hpp
>>    cgm/trunk/geom/GeometryQueryEngine.cpp
>>    cgm/trunk/geom/GeometryQueryEngine.hpp
>>    cgm/trunk/geom/GeometryQueryTool.cpp
>>    cgm/trunk/geom/GeometryQueryTool.hpp
>>    cgm/trunk/geom/GeometryUtil.cpp
>>    cgm/trunk/geom/GeometryUtil.hpp
>>    cgm/trunk/geom/GfxPreview.cpp
>>    cgm/trunk/geom/GfxPreview.hpp
>>    cgm/trunk/geom/GroupingEntity.cpp
>>    cgm/trunk/geom/GroupingEntity.hpp
>>    cgm/trunk/geom/IntermediateGeomEngine.hpp
>>    cgm/trunk/geom/Loop.cpp
>>    cgm/trunk/geom/Loop.hpp
>>    cgm/trunk/geom/LoopSM.cpp
>>    cgm/trunk/geom/LoopSM.hpp
>>    cgm/trunk/geom/Lump.cpp
>>    cgm/trunk/geom/Lump.hpp
>>    cgm/trunk/geom/LumpSM.cpp
>>    cgm/trunk/geom/LumpSM.hpp
>>    cgm/trunk/geom/Makefile.am
>>    cgm/trunk/geom/MedialTool2D.cpp
>>    cgm/trunk/geom/MedialTool2D.hpp
>>    cgm/trunk/geom/MedialTool3D.cpp
>>    cgm/trunk/geom/MedialTool3D.hpp
>>    cgm/trunk/geom/MergeTool.cpp
>>    cgm/trunk/geom/MergeTool.hpp
>>    cgm/trunk/geom/MergeToolAssistant.cpp
>>    cgm/trunk/geom/MergeToolAssistant.hpp
>>    cgm/trunk/geom/MidPlaneTool.cpp
>>    cgm/trunk/geom/MidPlaneTool.hpp
>>    cgm/trunk/geom/ModelEntity.cpp
>>    cgm/trunk/geom/ModelEntity.hpp
>>    cgm/trunk/geom/ModelQueryEngine.cpp
>>    cgm/trunk/geom/ModelQueryEngine.hpp
>>    cgm/trunk/geom/OCC/
>>    cgm/trunk/geom/OCC/Makefile.am
>>    cgm/trunk/geom/OCC/OCCAttribSet.cpp
>>    cgm/trunk/geom/OCC/OCCBody.cpp
>>    cgm/trunk/geom/OCC/OCCCurve.cpp
>>    cgm/trunk/geom/OCC/OCCDrawTool.cpp
>>    cgm/trunk/geom/OCC/OCCLoop.cpp
>>    cgm/trunk/geom/OCC/OCCLoop.hpp
>>    cgm/trunk/geom/OCC/OCCLump.cpp
>>    cgm/trunk/geom/OCC/OCCLump.hpp
>>    cgm/trunk/geom/OCC/OCCModifyEngine.cpp
>>    cgm/trunk/geom/OCC/OCCModifyEngine.hpp
>>    cgm/trunk/geom/OCC/OCCPoint.cpp
>>    cgm/trunk/geom/OCC/OCCQueryEngine.cpp
>>    cgm/trunk/geom/OCC/OCCQueryEngine.hpp
>>    cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
>>    cgm/trunk/geom/OCC/OCCShell.cpp
>>    cgm/trunk/geom/OCC/OCCSurface.cpp
>>    cgm/trunk/geom/OCC/OCCSurface.hpp
>>    cgm/trunk/geom/OffsetSplitTool.cpp
>>    cgm/trunk/geom/OffsetSplitTool.hpp
>>    cgm/trunk/geom/OldUnmergeCode.cpp
>>    cgm/trunk/geom/OldUnmergeCode.hpp
>>    cgm/trunk/geom/Point.cpp
>>    cgm/trunk/geom/Point.hpp
>>    cgm/trunk/geom/PointSM.cpp
>>    cgm/trunk/geom/PointSM.hpp
>>    cgm/trunk/geom/RefCollection.cpp
>>    cgm/trunk/geom/RefCollection.hpp
>>    cgm/trunk/geom/RefEdge.cpp
>>    cgm/trunk/geom/RefEdge.hpp
>>    cgm/trunk/geom/RefEntity.cpp
>>    cgm/trunk/geom/RefEntity.hpp
>>    cgm/trunk/geom/RefEntityFactory.cpp
>>    cgm/trunk/geom/RefEntityFactory.hpp
>>    cgm/trunk/geom/RefEntityName.cpp
>>    cgm/trunk/geom/RefEntityName.hpp
>>    cgm/trunk/geom/RefEntityNameMap.hpp
>>    cgm/trunk/geom/RefFace.cpp
>>    cgm/trunk/geom/RefFace.hpp
>>    cgm/trunk/geom/RefGroup.cpp
>>    cgm/trunk/geom/RefGroup.hpp
>>    cgm/trunk/geom/RefVertex.cpp
>>    cgm/trunk/geom/RefVertex.hpp
>>    cgm/trunk/geom/RefVolume.cpp
>>    cgm/trunk/geom/RefVolume.hpp
>>    cgm/trunk/geom/SenseEntity.cpp
>>    cgm/trunk/geom/SenseEntity.hpp
>>    cgm/trunk/geom/Shell.cpp
>>    cgm/trunk/geom/Shell.hpp
>>    cgm/trunk/geom/ShellSM.cpp
>>    cgm/trunk/geom/ShellSM.hpp
>>    cgm/trunk/geom/SolidWorks/
>>    cgm/trunk/geom/SphereEvaluator.cpp
>>    cgm/trunk/geom/SphereEvaluator.hpp
>>    cgm/trunk/geom/SplitSurfaceTool.cpp
>>    cgm/trunk/geom/SplitSurfaceTool.hpp
>>    cgm/trunk/geom/SurfParamTool.cpp
>>    cgm/trunk/geom/SurfParamTool.hpp
>>    cgm/trunk/geom/Surface.cpp
>>    cgm/trunk/geom/Surface.hpp
>>    cgm/trunk/geom/SurfaceOverlapFacet.cpp
>>    cgm/trunk/geom/SurfaceOverlapFacet.hpp
>>    cgm/trunk/geom/SurfaceOverlapTool.cpp
>>    cgm/trunk/geom/SurfaceOverlapTool.hpp
>>    cgm/trunk/geom/SurfaceSM.cpp
>>    cgm/trunk/geom/SurfaceSM.hpp
>>    cgm/trunk/geom/TBOwner.hpp
>>    cgm/trunk/geom/TBOwnerSet.hpp
>>    cgm/trunk/geom/TDCAGE.cpp
>>    cgm/trunk/geom/TDCAGE.hpp
>>    cgm/trunk/geom/TDCompare.hpp
>>    cgm/trunk/geom/TDSourceFeature.cpp
>>    cgm/trunk/geom/TDSourceFeature.hpp
>>    cgm/trunk/geom/TDSplitSurface.cpp
>>    cgm/trunk/geom/TDSplitSurface.hpp
>>    cgm/trunk/geom/TDSurfaceOverlap.cpp
>>    cgm/trunk/geom/TDSurfaceOverlap.hpp
>>    cgm/trunk/geom/TDUniqueId.cpp
>>    cgm/trunk/geom/TDUniqueId.hpp
>>    cgm/trunk/geom/TopologyBridge.cpp
>>    cgm/trunk/geom/TopologyBridge.hpp
>>    cgm/trunk/geom/TopologyEntity.cpp
>>    cgm/trunk/geom/TopologyEntity.hpp
>>    cgm/trunk/geom/UnMergeEvent.hpp
>>    cgm/trunk/geom/facet/
>>    cgm/trunk/geom/facet/FacetCurve.cpp
>>    cgm/trunk/geom/facet/FacetLoop.cpp
>>    cgm/trunk/geom/facet/FacetLoop.hpp
>>    cgm/trunk/geom/facet/FacetModifyEngine.cpp
>>    cgm/trunk/geom/facet/FacetModifyEngine.hpp
>>    cgm/trunk/geom/facet/FacetParamTool.cpp
>>    cgm/trunk/geom/facet/FacetParamTool.hpp
>>    cgm/trunk/geom/facet/FacetQueryEngine.cpp
>>    cgm/trunk/geom/facet/FacetQueryEngine.hpp
>>    cgm/trunk/geom/facet/FacetboolInterface.cpp
>>    cgm/trunk/geom/facetbool/
>>    cgm/trunk/geom/facetbool/FBRetriangulate.cpp
>>    cgm/trunk/geom/libcubit_geom.dsp
>>    cgm/trunk/geom/parallel/
>>    cgm/trunk/geom/parallel/CGMmpi.h
>>    cgm/trunk/geom/parallel/CGMmpi_config.h.in
>>    cgm/trunk/geom/virtual/CMakeLists.txt
>>    cgm/trunk/geom/virtual/CollapseCurveTool.cpp
>>    cgm/trunk/geom/virtual/CollapseCurveTool.hpp
>>    cgm/trunk/geom/virtual/CompSurfFacets.cpp
>>    cgm/trunk/geom/virtual/CompositeEngine.cpp
>>    cgm/trunk/geom/virtual/CompositeEngine.hpp
>>    cgm/trunk/geom/virtual/CompositeGeom.cpp
>>    cgm/trunk/geom/virtual/CompositeGeom.hpp
>>    cgm/trunk/geom/virtual/CompositeLoop.cpp
>>    cgm/trunk/geom/virtual/CompositeLoop.hpp
>>    cgm/trunk/geom/virtual/CompositeSurface.cpp
>>    cgm/trunk/geom/virtual/CompositeSurface.hpp
>>    cgm/trunk/geom/virtual/CompositeTool.cpp
>>    cgm/trunk/geom/virtual/FacetProjectTool.cpp
>>    cgm/trunk/geom/virtual/FacetProjectTool.hpp
>>    cgm/trunk/geom/virtual/Faceter.cpp
>>    cgm/trunk/geom/virtual/ImprintBoundaryTool.cpp
>>    cgm/trunk/geom/virtual/Makefile.am
>>    cgm/trunk/geom/virtual/PartSurfFacetTool.cpp
>>    cgm/trunk/geom/virtual/PartitionEngine.cpp
>>    cgm/trunk/geom/virtual/PartitionEngine.hpp
>>    cgm/trunk/geom/virtual/PartitionLoop.cpp
>>    cgm/trunk/geom/virtual/PartitionLoop.hpp
>>    cgm/trunk/geom/virtual/PartitionSurface.cpp
>>    cgm/trunk/geom/virtual/PartitionTool.cpp
>>    cgm/trunk/geom/virtual/RemoveBlends.cpp
>>    cgm/trunk/geom/virtual/SimplifyTool.cpp
>>    cgm/trunk/geom/virtual/SimplifyTool.hpp
>>    cgm/trunk/geom/virtual/SubCurve.cpp
>>    cgm/trunk/geom/virtual/SubSurface.cpp
>>    cgm/trunk/geom/virtual/VGLoopTool.cpp
>>    cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
>>    cgm/trunk/geom/virtual/VirtualQueryEngine.hpp
>>    cgm/trunk/init/InitCGMA.cpp
>>    cgm/trunk/itaps/iGeom_CGMA.cc
>>    cgm/trunk/itaps/testgeom.cc
>>    cgm/trunk/test/makept.cpp
>>    cgm/trunk/test/merge_test.cpp
>>    cgm/trunk/test/modify.cpp
>>    cgm/trunk/test/operation.cpp
>>    cgm/trunk/test/r_w.cpp
>>    cgm/trunk/test/test_occ.cpp
>>    cgm/trunk/test/webcut.cpp
>>    cgm/trunk/util/AppUtil.cpp
>>    cgm/trunk/util/AppUtil.hpp
>>    cgm/trunk/util/ArrayBasedContainer.cpp
>>    cgm/trunk/util/CMakeLists.txt
>>    cgm/trunk/util/CastTo.hpp
>>    cgm/trunk/util/CpuTimer.cpp
>>    cgm/trunk/util/CpuTimer.hpp
>>    cgm/trunk/util/CubitBox.cpp
>>    cgm/trunk/util/CubitBox.hpp
>>    cgm/trunk/util/CubitColorConstants.hpp
>>    cgm/trunk/util/CubitCoordinateSystem.cpp
>>    cgm/trunk/util/CubitDefines.h
>>    cgm/trunk/util/CubitDynamicLoader.cpp
>>    cgm/trunk/util/CubitEntity.cpp
>>    cgm/trunk/util/CubitEventDefines.h
>>    cgm/trunk/util/CubitFile.cpp
>>    cgm/trunk/util/CubitFile.hpp
>>    cgm/trunk/util/CubitFileFEModel.cpp
>>    cgm/trunk/util/CubitFileFEModel.hpp
>>    cgm/trunk/util/CubitFileIOWrapper.cpp
>>    cgm/trunk/util/CubitFileIOWrapper.hpp
>>    cgm/trunk/util/CubitFileMetaData.cpp
>>    cgm/trunk/util/CubitFileUtil.cpp
>>    cgm/trunk/util/CubitInputFile.hpp
>>    cgm/trunk/util/CubitMatrix.cpp
>>    cgm/trunk/util/CubitMessage.cpp
>>    cgm/trunk/util/CubitMessage.hpp
>>    cgm/trunk/util/CubitPlane.cpp
>>    cgm/trunk/util/CubitPlane.hpp
>>    cgm/trunk/util/CubitStack.cpp
>>    cgm/trunk/util/CubitString.cpp
>>    cgm/trunk/util/CubitString.hpp
>>    cgm/trunk/util/CubitTransformMatrix.cpp
>>    cgm/trunk/util/CubitTransformMatrix.hpp
>>    cgm/trunk/util/CubitUtil.cpp
>>    cgm/trunk/util/CubitUtil.hpp
>>    cgm/trunk/util/CubitUtilConfigure.h.in
>>    cgm/trunk/util/CubitVector.cpp
>>    cgm/trunk/util/CubitVector.hpp
>>    cgm/trunk/util/DIntArray.cpp
>>    cgm/trunk/util/DLIList.cpp
>>    cgm/trunk/util/DLIList.hpp
>>    cgm/trunk/util/DLList.hpp
>>    cgm/trunk/util/DynamicArray.cpp
>>    cgm/trunk/util/DynamicArray.hpp
>>    cgm/trunk/util/ElementType.h
>>    cgm/trunk/util/GMem.cpp
>>    cgm/trunk/util/GeometryDefines.h
>>    cgm/trunk/util/GetLongOpt.hpp
>>    cgm/trunk/util/GfxDebug.cpp
>>    cgm/trunk/util/GfxDebug.hpp
>>    cgm/trunk/util/IntersectionTool.cpp
>>    cgm/trunk/util/IntersectionTool.hpp
>>    cgm/trunk/util/KDDTree.cpp
>>    cgm/trunk/util/Makefile.am
>>    cgm/trunk/util/MemoryBlock.hpp
>>    cgm/trunk/util/MemoryManager.cpp
>>    cgm/trunk/util/MemoryManager.hpp
>>    cgm/trunk/util/OctTree.cpp
>>    cgm/trunk/util/OtherFiles/make.client
>>    cgm/trunk/util/ParamTool.hpp
>>    cgm/trunk/util/PlanarParamTool.cpp
>>    cgm/trunk/util/PlanarParamTool.hpp
>>    cgm/trunk/util/PriorityQueue.cpp
>>    cgm/trunk/util/RTree.cpp
>>    cgm/trunk/util/RTree.hpp
>>    cgm/trunk/util/RandomMersenne.cpp
>>    cgm/trunk/util/SDLList.cpp
>>    cgm/trunk/util/SDLList.hpp
>>    cgm/trunk/util/SettingHandler.cpp
>>    cgm/trunk/util/SettingHandler.hpp
>>    cgm/trunk/util/TextProgressTool.cpp
>>    cgm/trunk/util/ToolData.cpp
>>    cgm/trunk/util/ToolData.hpp
>>    cgm/trunk/util/ToolDataUser.cpp
>>    cgm/trunk/util/ToolDataUser.hpp
>>    cgm/trunk/util/TtyProgressTool.cpp
>>    Log:
>>    Merge branch/merge-cubit12 to trunk, passed all testcases for
>>    OCC6.3(build with /geom/OCC/occ_patches), OCC6.5(build with
>>    /geom/OCC/occ_patches_6.5), acis17 as well as cubit12 builds.
>>    Special note: When building with cubit12, current test code doesn't
>>    do anything for geom/testing directory. Status is <All 0 tests passed>.
>>    Property changes on: cgm/trunk
>>    ___________________________________________________________________
>>    Added: svn:mergeinfo
>>    + /cgm/branches/cubit:1041-3427
>>    /cgm/branches/merge-cubit12:3424-4774
>>    Deleted: cgm/trunk/KNOWN_ISSUES
>>    --- cgm/trunk/KNOWN_ISSUES 2011-04-23 05:15:17 UTC (rev 4774)
>>    +++ cgm/trunk/KNOWN_ISSUES 2011-04-26 17:54:11 UTC (rev 4775)
>>    @@ -1,27 +0,0 @@
>>    -This is a list of the known issues with CGM on OCC.For more details
>>    please see
>>    -the online ticket system at the MOAB website:
>>    - https://trac.mcs.anl.gov/projects/ITAPS/wiki
>>    -ID Severity Summary/Details
>>    -175 critical imprint special cases fail with crash.
>>    -176 minor CGM memory leak
>>    -178 major Unite function doesn't unite smoothly connected surfaces.
>>    -179 major mcnp2cad test suite lat1-7 not working, needs debugging.
>>    -180 major There are lots new functions or added functions to exsisting
>>    - functions requirements to port OCC to cubit12.
>>    -181 minor Lack of good cases for testing purpose.
>>    -182 minor Dirty geometry/imported geometry is not tested for
>>    read/repair yet
>>    -183 minor Don't have proper tool to visualize the TopoDS_Shapes,
>>    debugging
>>    - process is long preparing for graphics to understand the issue
>>    -185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2
>>    spline
>>    - surfaces.
>>    Added: cgm/trunk/KNOWN_ISSUES
>>    --- cgm/trunk/KNOWN_ISSUES (rev 0)
>>    @@ -0,0 +1,27 @@
>>    +This is a list of the known issues with CGM on OCC.For more details
>>    please see
>>    +the online ticket system at the MOAB website:
>>    + https://trac.mcs.anl.gov/projects/ITAPS/wiki
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>         phone: (608) 263-8485      1500 Engineering Dr.
>           fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
