[cgma-dev] r4775 : Getting CAMergePartner attribute info ?
Tim Tautges
tautges at mcs.anl.gov
Fri May 13 13:01:56 CDT 2011
I thought you had been using CABody for that...
- tim
On 05/13/2011 12:50 PM, Hong-Jun Kim wrote:
> Hi,
> After importing merged geometry, I am using "CAMergePartner" attribute to find merged entities for my parallel meshing.
> For example, I use "get_cubit_attrib" as follows and if "att" is not NULL pointer, I decided that the entity is merged.
> CubitAttrib* att = entity->get_cubit_attrib(CA_MERGE_PARTNER, CUBIT_FALSE);
> if (att != NULL) { // entity is merged }
> However, by this revision change, CAMergePartner actuate process is removed because "GeometryQueryTool::check_mergeable_refentity" handles this.
> So, I am wondering how I can know which entities are merged in this revision, then can anybody tell me about it?
> Thanks.
> Hong-Jun
>> From: "jiangtao ma"<jiangtao_ma at yahoo.com>
>> To: cgma-dev at mcs.anl.gov
>> Sent: Tuesday, April 26, 2011 12:54:15 PM
>> Subject: [cgma-dev] r4775 - in cgm/trunk: . cgm_apps/ccapi/geom cgm_apps/cgm_cubit_acis cgm_apps/examples/driverc++
>> cgm_apps/examples/gomadrive geom geom/ACIS_SRC geom/ACIS_SRC/gtcAttrib geom/ACIS_SRC/gtcAttrib/incl geom/Cholla
>> geom/OCC geom/SolidWorks geom/facet geom/facetbool geom/parallel geom/testing geom/testing/data geom/virtual init
>> itaps test util util/OtherFiles
>> Author: janehu
>> Date: 2011-04-26 12:54:11 -0500 (Tue, 26 Apr 2011)
>> New Revision: 4775
>> Added:
>> cgm/trunk/KNOWN_ISSUES
>> cgm/trunk/geom/ACIS_SRC/AcisHistory.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisHistory.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.hpp
>> cgm/trunk/geom/ACIS_SRC/attrib_history.cpp
>> cgm/trunk/geom/ACIS_SRC/attrib_history.hpp
>> cgm/trunk/geom/AutoMidsurfaceTool.cpp
>> cgm/trunk/geom/AutoMidsurfaceTool.hpp
>> cgm/trunk/geom/CGMHistory.cpp
>> cgm/trunk/geom/CGMHistory.hpp
>> cgm/trunk/geom/Cholla/ChollaVolume.cpp
>> cgm/trunk/geom/Cholla/ChollaVolume.hpp
>> cgm/trunk/geom/Cholla/FacetorUtil.cpp
>> cgm/trunk/geom/Cholla/FacetorUtil.hpp
>> cgm/trunk/geom/CubitCompat.cpp
>> cgm/trunk/geom/CubitCompat.h.in
>> cgm/trunk/geom/CubitCompat.hpp
>> cgm/trunk/geom/OCC/OCCHistory.cpp
>> cgm/trunk/geom/OCC/OCCHistory.hpp
>> cgm/trunk/geom/OCC/occ_attrib_history.hpp
>> cgm/trunk/geom/OCC/occ_patches_6.5
>> cgm/trunk/geom/PeriodicParamTool.cpp
>> cgm/trunk/geom/PeriodicParamTool.hpp
>> cgm/trunk/geom/testing/
>> cgm/trunk/geom/testing/AngleCalc.cpp
>> cgm/trunk/geom/testing/CMakeLists.txt
>> cgm/trunk/geom/testing/CreateGeometry.cpp
>> cgm/trunk/geom/testing/GraphicsData.cpp
>> cgm/trunk/geom/testing/Makefile.am
>> cgm/trunk/geom/testing/ReadIgesFile.cpp
>> cgm/trunk/geom/testing/TestConfig.h.in
>> cgm/trunk/geom/testing/TestUtilities.cpp
>> cgm/trunk/geom/testing/TestUtilities.hpp
>> cgm/trunk/geom/testing/cgm_test.cpp
>> cgm/trunk/geom/testing/cgm_test.hpp
>> cgm/trunk/geom/testing/cgm_test_script
>> cgm/trunk/geom/testing/data/
>> cgm/trunk/geom/testing/data/brick.iges
>> cgm/trunk/geom/testing/main.cpp
>> cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.cpp
>> cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.hpp
>> cgm/trunk/test/Cylinder_1.brep
>> cgm/trunk/test/Cylinder_2.brep
>> cgm/trunk/util/CommandFeedback.hpp
>> cgm/trunk/util/CubitUndo.cpp
>> cgm/trunk/util/CubitUndo.hpp
>> cgm/trunk/util/ExternalCoordinateSystem.hpp
>> cgm/trunk/util/GlobalCommandFeedback.cpp
>> cgm/trunk/util/GlobalCommandFeedback.hpp
>> cgm/trunk/util/ManagedPtrVector.hpp
>> cgm/trunk/util/OrderedMap.hpp
>> cgm/trunk/util/OrderedSet.hpp
>> Removed:
>> Modified:
>> cgm/trunk/
>> cgm/trunk/Makefile.am
>> cgm/trunk/cgm_apps/ccapi/geom/GeometryTool_ccapi.cpp
>> cgm/trunk/cgm_apps/cgm_cubit_acis/main_cubit_acis.cpp
>> cgm/trunk/cgm_apps/examples/driverc++/mergechk.cpp
>> cgm/trunk/cgm_apps/examples/gomadrive/gm_cgm_c_interface.C
>> cgm/trunk/configure.ac
>> cgm/trunk/geom/
>> cgm/trunk/geom/ACIS_SRC/AcisBridge.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisDrawTool.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisEdgeTool.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisFacetManager.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisFacetManager.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisHealerTool.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisHealerTool.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisToolUtil.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisToolUtil.hpp
>> cgm/trunk/geom/ACIS_SRC/AcisTweakTool.cpp
>> cgm/trunk/geom/ACIS_SRC/AcisTweakTool.hpp
>> cgm/trunk/geom/ACIS_SRC/BodyACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/BodyACIS.hpp
>> cgm/trunk/geom/ACIS_SRC/CMakeLists.txt
>> cgm/trunk/geom/ACIS_SRC/CoEdgeACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/CurveACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/CurveACIS.hpp
>> cgm/trunk/geom/ACIS_SRC/LoopACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/LoopACIS.hpp
>> cgm/trunk/geom/ACIS_SRC/LumpACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/LumpACIS.hpp
>> cgm/trunk/geom/ACIS_SRC/Makefile.am
>> cgm/trunk/geom/ACIS_SRC/PointACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/ShellACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/SurfaceACIS.cpp
>> cgm/trunk/geom/ACIS_SRC/SurfaceACIS.hpp
>> cgm/trunk/geom/ACIS_SRC/UseACIS.cmake
>> cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.cpp
>> cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.hpp
>> cgm/trunk/geom/ACIS_SRC/attrib_snl.cpp
>> cgm/trunk/geom/ACIS_SRC/attrib_snl.hpp
>> cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.cpp
>> cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.hpp
>> cgm/trunk/geom/ACIS_SRC/decl_none.h
>> cgm/trunk/geom/ACIS_SRC/gtcAttrib/CMakeLists.txt
>> cgm/trunk/geom/ACIS_SRC/gtcAttrib/Makefile
>> cgm/trunk/geom/ACIS_SRC/gtcAttrib/incl/attrib_gtc_export.h
>> cgm/trunk/geom/AllocMemManagersGeom.cpp
>> cgm/trunk/geom/AnalyticGeometryTool.cpp
>> cgm/trunk/geom/AnalyticGeometryTool.hpp
>> cgm/trunk/geom/BasicTopologyEntity.cpp
>> cgm/trunk/geom/BasicTopologyEntity.hpp
>> cgm/trunk/geom/Body.cpp
>> cgm/trunk/geom/Body.hpp
>> cgm/trunk/geom/BodySM.cpp
>> cgm/trunk/geom/BodySM.hpp
>> cgm/trunk/geom/BoundingBoxTool.cpp
>> cgm/trunk/geom/BoundingBoxTool.hpp
>> cgm/trunk/geom/BridgeManager.cpp
>> cgm/trunk/geom/BridgeManager.hpp
>> cgm/trunk/geom/CAActuateSet.cpp
>> cgm/trunk/geom/CAActuateSet.hpp
>> cgm/trunk/geom/CADeferredAttrib.cpp
>> cgm/trunk/geom/CADeferredAttrib.hpp
>> cgm/trunk/geom/CADefines.hpp
>> cgm/trunk/geom/CAEntityColor.cpp
>> cgm/trunk/geom/CAEntityColor.hpp
>> cgm/trunk/geom/CAEntityId.cpp
>> cgm/trunk/geom/CAEntityId.hpp
>> cgm/trunk/geom/CAEntityName.cpp
>> cgm/trunk/geom/CAEntityName.hpp
>> cgm/trunk/geom/CAGroup.cpp
>> cgm/trunk/geom/CAGroup.hpp
>> cgm/trunk/geom/CAMergePartner.cpp
>> cgm/trunk/geom/CAMergePartner.hpp
>> cgm/trunk/geom/CAMergeStatus.cpp
>> cgm/trunk/geom/CAMergeStatus.hpp
>> cgm/trunk/geom/CASourceFeature.cpp
>> cgm/trunk/geom/CASourceFeature.hpp
>> cgm/trunk/geom/CAUniqueId.cpp
>> cgm/trunk/geom/CAUniqueId.hpp
>> cgm/trunk/geom/CGMApp.cpp
>> cgm/trunk/geom/CGMApp.hpp
>> cgm/trunk/geom/CGMEngineDynamicLoader.cpp
>> cgm/trunk/geom/CGMEngineDynamicLoader.hpp
>> cgm/trunk/geom/CMakeLists.txt
>> cgm/trunk/geom/Chain.cpp
>> cgm/trunk/geom/Chain.hpp
>> cgm/trunk/geom/Cholla/CMakeLists.txt
>> cgm/trunk/geom/Cholla/Cholla.cpp
>> cgm/trunk/geom/Cholla/ChollaCurve.cpp
>> cgm/trunk/geom/Cholla/ChollaCurve.hpp
>> cgm/trunk/geom/Cholla/ChollaEngine.cpp
>> cgm/trunk/geom/Cholla/ChollaEngine.hpp
>> cgm/trunk/geom/Cholla/ChollaPoint.cpp
>> cgm/trunk/geom/Cholla/ChollaPoint.hpp
>> cgm/trunk/geom/Cholla/ChollaSurface.cpp
>> cgm/trunk/geom/Cholla/ChollaSurface.hpp
>> cgm/trunk/geom/Cholla/CubitFacet.cpp
>> cgm/trunk/geom/Cholla/CubitFacet.hpp
>> cgm/trunk/geom/Cholla/CubitFacetData.cpp
>> cgm/trunk/geom/Cholla/CubitFacetData.hpp
>> cgm/trunk/geom/Cholla/CubitFacetEdge.hpp
>> cgm/trunk/geom/Cholla/CurveFacetEvalTool.cpp
>> cgm/trunk/geom/Cholla/CurveFacetEvalTool.hpp
>> cgm/trunk/geom/Cholla/FacetDataUtil.cpp
>> cgm/trunk/geom/Cholla/FacetDataUtil.hpp
>> cgm/trunk/geom/Cholla/FacetEvalTool.cpp
>> cgm/trunk/geom/Cholla/FacetEvalTool.hpp
>> cgm/trunk/geom/Cholla/FacetorTool.cpp
>> cgm/trunk/geom/Cholla/FacetorTool.hpp
>> cgm/trunk/geom/Cholla/LoopParamTool.cpp
>> cgm/trunk/geom/Cholla/LoopParamTool.hpp
>> cgm/trunk/geom/Cholla/Makefile.am
>> cgm/trunk/geom/Cholla/TDGeomFacet.cpp
>> cgm/trunk/geom/Cholla/TDGeomFacet.hpp
>> cgm/trunk/geom/Cholla/debug.cpp
>> cgm/trunk/geom/Cholla/debug.hpp
>> cgm/trunk/geom/CoEdge.cpp
>> cgm/trunk/geom/CoEdge.hpp
>> cgm/trunk/geom/CoEdgeSM.cpp
>> cgm/trunk/geom/CoEdgeSM.hpp
>> cgm/trunk/geom/CoFace.cpp
>> cgm/trunk/geom/CoFace.hpp
>> cgm/trunk/geom/CoVertex.cpp
>> cgm/trunk/geom/CoVertex.hpp
>> cgm/trunk/geom/CoVolume.cpp
>> cgm/trunk/geom/CoVolume.hpp
>> cgm/trunk/geom/CollectionEntity.cpp
>> cgm/trunk/geom/CollectionEntity.hpp
>> cgm/trunk/geom/CompositeCombineEvent.hpp
>> cgm/trunk/geom/CubitAttrib.cpp
>> cgm/trunk/geom/CubitAttrib.hpp
>> cgm/trunk/geom/CubitAttribManager.cpp
>> cgm/trunk/geom/CubitAttribManager.hpp
>> cgm/trunk/geom/CubitAttribUser.cpp
>> cgm/trunk/geom/CubitAttribUser.hpp
>> cgm/trunk/geom/CubitEvaluator.hpp
>> cgm/trunk/geom/CubitGeomConfigure.h
>> cgm/trunk/geom/CubitGeomConfigure.h.in
>> cgm/trunk/geom/CubitPolygon.cpp
>> cgm/trunk/geom/CubitPolygon.hpp
>> cgm/trunk/geom/CubitSimpleAttrib.cpp
>> cgm/trunk/geom/CubitSimpleAttrib.hpp
>> cgm/trunk/geom/Curve.cpp
>> cgm/trunk/geom/Curve.hpp
>> cgm/trunk/geom/CurveOverlapFacet.cpp
>> cgm/trunk/geom/CurveOverlapFacet.hpp
>> cgm/trunk/geom/CurveSM.cpp
>> cgm/trunk/geom/CurveSM.hpp
>> cgm/trunk/geom/CylinderEvaluator.cpp
>> cgm/trunk/geom/CylinderEvaluator.hpp
>> cgm/trunk/geom/DAG.cpp
>> cgm/trunk/geom/DAG.hpp
>> cgm/trunk/geom/DagDrawingTool.cpp
>> cgm/trunk/geom/DagDrawingTool.hpp
>> cgm/trunk/geom/DagType.hpp
>> cgm/trunk/geom/GSaveOpen.cpp
>> cgm/trunk/geom/GSaveOpen.hpp
>> cgm/trunk/geom/GeomDataObserver.cpp
>> cgm/trunk/geom/GeomDataObserver.hpp
>> cgm/trunk/geom/GeomMeasureTool.cpp
>> cgm/trunk/geom/GeomMeasureTool.hpp
>> cgm/trunk/geom/GeomPoint.hpp
>> cgm/trunk/geom/GeomSeg.hpp
>> cgm/trunk/geom/GeometryEntity.cpp
>> cgm/trunk/geom/GeometryEntity.hpp
>> cgm/trunk/geom/GeometryFeatureEngine.cpp
>> cgm/trunk/geom/GeometryFeatureEngine.hpp
>> cgm/trunk/geom/GeometryFeatureTool.cpp
>> cgm/trunk/geom/GeometryFeatureTool.hpp
>> cgm/trunk/geom/GeometryHealerEngine.cpp
>> cgm/trunk/geom/GeometryHealerEngine.hpp
>> cgm/trunk/geom/GeometryHealerTool.cpp
>> cgm/trunk/geom/GeometryHealerTool.hpp
>> cgm/trunk/geom/GeometryModifyEngine.cpp
>> cgm/trunk/geom/GeometryModifyEngine.hpp
>> cgm/trunk/geom/GeometryModifyTool.cpp
>> cgm/trunk/geom/GeometryModifyTool.hpp
>> cgm/trunk/geom/GeometryQueryEngine.cpp
>> cgm/trunk/geom/GeometryQueryEngine.hpp
>> cgm/trunk/geom/GeometryQueryTool.cpp
>> cgm/trunk/geom/GeometryQueryTool.hpp
>> cgm/trunk/geom/GeometryUtil.cpp
>> cgm/trunk/geom/GeometryUtil.hpp
>> cgm/trunk/geom/GfxPreview.cpp
>> cgm/trunk/geom/GfxPreview.hpp
>> cgm/trunk/geom/GroupingEntity.cpp
>> cgm/trunk/geom/GroupingEntity.hpp
>> cgm/trunk/geom/IntermediateGeomEngine.hpp
>> cgm/trunk/geom/Loop.cpp
>> cgm/trunk/geom/Loop.hpp
>> cgm/trunk/geom/LoopSM.cpp
>> cgm/trunk/geom/LoopSM.hpp
>> cgm/trunk/geom/Lump.cpp
>> cgm/trunk/geom/Lump.hpp
>> cgm/trunk/geom/LumpSM.cpp
>> cgm/trunk/geom/LumpSM.hpp
>> cgm/trunk/geom/Makefile.am
>> cgm/trunk/geom/MedialTool2D.cpp
>> cgm/trunk/geom/MedialTool2D.hpp
>> cgm/trunk/geom/MedialTool3D.cpp
>> cgm/trunk/geom/MedialTool3D.hpp
>> cgm/trunk/geom/MergeTool.cpp
>> cgm/trunk/geom/MergeTool.hpp
>> cgm/trunk/geom/MergeToolAssistant.cpp
>> cgm/trunk/geom/MergeToolAssistant.hpp
>> cgm/trunk/geom/MidPlaneTool.cpp
>> cgm/trunk/geom/MidPlaneTool.hpp
>> cgm/trunk/geom/ModelEntity.cpp
>> cgm/trunk/geom/ModelEntity.hpp
>> cgm/trunk/geom/ModelQueryEngine.cpp
>> cgm/trunk/geom/ModelQueryEngine.hpp
>> cgm/trunk/geom/OCC/
>> cgm/trunk/geom/OCC/Makefile.am
>> cgm/trunk/geom/OCC/OCCAttribSet.cpp
>> cgm/trunk/geom/OCC/OCCBody.cpp
>> cgm/trunk/geom/OCC/OCCCurve.cpp
>> cgm/trunk/geom/OCC/OCCDrawTool.cpp
>> cgm/trunk/geom/OCC/OCCLoop.cpp
>> cgm/trunk/geom/OCC/OCCLoop.hpp
>> cgm/trunk/geom/OCC/OCCLump.cpp
>> cgm/trunk/geom/OCC/OCCLump.hpp
>> cgm/trunk/geom/OCC/OCCModifyEngine.cpp
>> cgm/trunk/geom/OCC/OCCModifyEngine.hpp
>> cgm/trunk/geom/OCC/OCCPoint.cpp
>> cgm/trunk/geom/OCC/OCCQueryEngine.cpp
>> cgm/trunk/geom/OCC/OCCQueryEngine.hpp
>> cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
>> cgm/trunk/geom/OCC/OCCShell.cpp
>> cgm/trunk/geom/OCC/OCCSurface.cpp
>> cgm/trunk/geom/OCC/OCCSurface.hpp
>> cgm/trunk/geom/OffsetSplitTool.cpp
>> cgm/trunk/geom/OffsetSplitTool.hpp
>> cgm/trunk/geom/OldUnmergeCode.cpp
>> cgm/trunk/geom/OldUnmergeCode.hpp
>> cgm/trunk/geom/Point.cpp
>> cgm/trunk/geom/Point.hpp
>> cgm/trunk/geom/PointSM.cpp
>> cgm/trunk/geom/PointSM.hpp
>> cgm/trunk/geom/RefCollection.cpp
>> cgm/trunk/geom/RefCollection.hpp
>> cgm/trunk/geom/RefEdge.cpp
>> cgm/trunk/geom/RefEdge.hpp
>> cgm/trunk/geom/RefEntity.cpp
>> cgm/trunk/geom/RefEntity.hpp
>> cgm/trunk/geom/RefEntityFactory.cpp
>> cgm/trunk/geom/RefEntityFactory.hpp
>> cgm/trunk/geom/RefEntityName.cpp
>> cgm/trunk/geom/RefEntityName.hpp
>> cgm/trunk/geom/RefEntityNameMap.hpp
>> cgm/trunk/geom/RefFace.cpp
>> cgm/trunk/geom/RefFace.hpp
>> cgm/trunk/geom/RefGroup.cpp
>> cgm/trunk/geom/RefGroup.hpp
>> cgm/trunk/geom/RefVertex.cpp
>> cgm/trunk/geom/RefVertex.hpp
>> cgm/trunk/geom/RefVolume.cpp
>> cgm/trunk/geom/RefVolume.hpp
>> cgm/trunk/geom/SenseEntity.cpp
>> cgm/trunk/geom/SenseEntity.hpp
>> cgm/trunk/geom/Shell.cpp
>> cgm/trunk/geom/Shell.hpp
>> cgm/trunk/geom/ShellSM.cpp
>> cgm/trunk/geom/ShellSM.hpp
>> cgm/trunk/geom/SolidWorks/
>> cgm/trunk/geom/SphereEvaluator.cpp
>> cgm/trunk/geom/SphereEvaluator.hpp
>> cgm/trunk/geom/SplitSurfaceTool.cpp
>> cgm/trunk/geom/SplitSurfaceTool.hpp
>> cgm/trunk/geom/SurfParamTool.cpp
>> cgm/trunk/geom/SurfParamTool.hpp
>> cgm/trunk/geom/Surface.cpp
>> cgm/trunk/geom/Surface.hpp
>> cgm/trunk/geom/SurfaceOverlapFacet.cpp
>> cgm/trunk/geom/SurfaceOverlapFacet.hpp
>> cgm/trunk/geom/SurfaceOverlapTool.cpp
>> cgm/trunk/geom/SurfaceOverlapTool.hpp
>> cgm/trunk/geom/SurfaceSM.cpp
>> cgm/trunk/geom/SurfaceSM.hpp
>> cgm/trunk/geom/TBOwner.hpp
>> cgm/trunk/geom/TBOwnerSet.hpp
>> cgm/trunk/geom/TDCAGE.cpp
>> cgm/trunk/geom/TDCAGE.hpp
>> cgm/trunk/geom/TDCompare.hpp
>> cgm/trunk/geom/TDSourceFeature.cpp
>> cgm/trunk/geom/TDSourceFeature.hpp
>> cgm/trunk/geom/TDSplitSurface.cpp
>> cgm/trunk/geom/TDSplitSurface.hpp
>> cgm/trunk/geom/TDSurfaceOverlap.cpp
>> cgm/trunk/geom/TDSurfaceOverlap.hpp
>> cgm/trunk/geom/TDUniqueId.cpp
>> cgm/trunk/geom/TDUniqueId.hpp
>> cgm/trunk/geom/TopologyBridge.cpp
>> cgm/trunk/geom/TopologyBridge.hpp
>> cgm/trunk/geom/TopologyEntity.cpp
>> cgm/trunk/geom/TopologyEntity.hpp
>> cgm/trunk/geom/UnMergeEvent.hpp
>> cgm/trunk/geom/facet/
>> cgm/trunk/geom/facet/FacetCurve.cpp
>> cgm/trunk/geom/facet/FacetLoop.cpp
>> cgm/trunk/geom/facet/FacetLoop.hpp
>> cgm/trunk/geom/facet/FacetModifyEngine.cpp
>> cgm/trunk/geom/facet/FacetModifyEngine.hpp
>> cgm/trunk/geom/facet/FacetParamTool.cpp
>> cgm/trunk/geom/facet/FacetParamTool.hpp
>> cgm/trunk/geom/facet/FacetQueryEngine.cpp
>> cgm/trunk/geom/facet/FacetQueryEngine.hpp
>> cgm/trunk/geom/facet/FacetboolInterface.cpp
>> cgm/trunk/geom/facetbool/
>> cgm/trunk/geom/facetbool/FBRetriangulate.cpp
>> cgm/trunk/geom/libcubit_geom.dsp
>> cgm/trunk/geom/parallel/
>> cgm/trunk/geom/parallel/CGMmpi.h
>> cgm/trunk/geom/parallel/CGMmpi_config.h.in
>> cgm/trunk/geom/virtual/CMakeLists.txt
>> cgm/trunk/geom/virtual/CollapseCurveTool.cpp
>> cgm/trunk/geom/virtual/CollapseCurveTool.hpp
>> cgm/trunk/geom/virtual/CompSurfFacets.cpp
>> cgm/trunk/geom/virtual/CompositeEngine.cpp
>> cgm/trunk/geom/virtual/CompositeEngine.hpp
>> cgm/trunk/geom/virtual/CompositeGeom.cpp
>> cgm/trunk/geom/virtual/CompositeGeom.hpp
>> cgm/trunk/geom/virtual/CompositeLoop.cpp
>> cgm/trunk/geom/virtual/CompositeLoop.hpp
>> cgm/trunk/geom/virtual/CompositeSurface.cpp
>> cgm/trunk/geom/virtual/CompositeSurface.hpp
>> cgm/trunk/geom/virtual/CompositeTool.cpp
>> cgm/trunk/geom/virtual/FacetProjectTool.cpp
>> cgm/trunk/geom/virtual/FacetProjectTool.hpp
>> cgm/trunk/geom/virtual/Faceter.cpp
>> cgm/trunk/geom/virtual/ImprintBoundaryTool.cpp
>> cgm/trunk/geom/virtual/Makefile.am
>> cgm/trunk/geom/virtual/PartSurfFacetTool.cpp
>> cgm/trunk/geom/virtual/PartitionEngine.cpp
>> cgm/trunk/geom/virtual/PartitionEngine.hpp
>> cgm/trunk/geom/virtual/PartitionLoop.cpp
>> cgm/trunk/geom/virtual/PartitionLoop.hpp
>> cgm/trunk/geom/virtual/PartitionSurface.cpp
>> cgm/trunk/geom/virtual/PartitionTool.cpp
>> cgm/trunk/geom/virtual/RemoveBlends.cpp
>> cgm/trunk/geom/virtual/SimplifyTool.cpp
>> cgm/trunk/geom/virtual/SimplifyTool.hpp
>> cgm/trunk/geom/virtual/SubCurve.cpp
>> cgm/trunk/geom/virtual/SubSurface.cpp
>> cgm/trunk/geom/virtual/VGLoopTool.cpp
>> cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
>> cgm/trunk/geom/virtual/VirtualQueryEngine.hpp
>> cgm/trunk/init/InitCGMA.cpp
>> cgm/trunk/itaps/iGeom_CGMA.cc
>> cgm/trunk/itaps/testgeom.cc
>> cgm/trunk/test/makept.cpp
>> cgm/trunk/test/merge_test.cpp
>> cgm/trunk/test/modify.cpp
>> cgm/trunk/test/operation.cpp
>> cgm/trunk/test/r_w.cpp
>> cgm/trunk/test/test_occ.cpp
>> cgm/trunk/test/webcut.cpp
>> cgm/trunk/util/AppUtil.cpp
>> cgm/trunk/util/AppUtil.hpp
>> cgm/trunk/util/ArrayBasedContainer.cpp
>> cgm/trunk/util/CMakeLists.txt
>> cgm/trunk/util/CastTo.hpp
>> cgm/trunk/util/CpuTimer.cpp
>> cgm/trunk/util/CpuTimer.hpp
>> cgm/trunk/util/CubitBox.cpp
>> cgm/trunk/util/CubitBox.hpp
>> cgm/trunk/util/CubitColorConstants.hpp
>> cgm/trunk/util/CubitCoordinateSystem.cpp
>> cgm/trunk/util/CubitDefines.h
>> cgm/trunk/util/CubitDynamicLoader.cpp
>> cgm/trunk/util/CubitEntity.cpp
>> cgm/trunk/util/CubitEventDefines.h
>> cgm/trunk/util/CubitFile.cpp
>> cgm/trunk/util/CubitFile.hpp
>> cgm/trunk/util/CubitFileFEModel.cpp
>> cgm/trunk/util/CubitFileFEModel.hpp
>> cgm/trunk/util/CubitFileIOWrapper.cpp
>> cgm/trunk/util/CubitFileIOWrapper.hpp
>> cgm/trunk/util/CubitFileMetaData.cpp
>> cgm/trunk/util/CubitFileUtil.cpp
>> cgm/trunk/util/CubitInputFile.hpp
>> cgm/trunk/util/CubitMatrix.cpp
>> cgm/trunk/util/CubitMessage.cpp
>> cgm/trunk/util/CubitMessage.hpp
>> cgm/trunk/util/CubitPlane.cpp
>> cgm/trunk/util/CubitPlane.hpp
>> cgm/trunk/util/CubitStack.cpp
>> cgm/trunk/util/CubitString.cpp
>> cgm/trunk/util/CubitString.hpp
>> cgm/trunk/util/CubitTransformMatrix.cpp
>> cgm/trunk/util/CubitTransformMatrix.hpp
>> cgm/trunk/util/CubitUtil.cpp
>> cgm/trunk/util/CubitUtil.hpp
>> cgm/trunk/util/CubitUtilConfigure.h.in
>> cgm/trunk/util/CubitVector.cpp
>> cgm/trunk/util/CubitVector.hpp
>> cgm/trunk/util/DIntArray.cpp
>> cgm/trunk/util/DLIList.cpp
>> cgm/trunk/util/DLIList.hpp
>> cgm/trunk/util/DLList.hpp
>> cgm/trunk/util/DynamicArray.cpp
>> cgm/trunk/util/DynamicArray.hpp
>> cgm/trunk/util/ElementType.h
>> cgm/trunk/util/GMem.cpp
>> cgm/trunk/util/GeometryDefines.h
>> cgm/trunk/util/GetLongOpt.hpp
>> cgm/trunk/util/GfxDebug.cpp
>> cgm/trunk/util/GfxDebug.hpp
>> cgm/trunk/util/IntersectionTool.cpp
>> cgm/trunk/util/IntersectionTool.hpp
>> cgm/trunk/util/KDDTree.cpp
>> cgm/trunk/util/Makefile.am
>> cgm/trunk/util/MemoryBlock.hpp
>> cgm/trunk/util/MemoryManager.cpp
>> cgm/trunk/util/MemoryManager.hpp
>> cgm/trunk/util/OctTree.cpp
>> cgm/trunk/util/OtherFiles/make.client
>> cgm/trunk/util/ParamTool.hpp
>> cgm/trunk/util/PlanarParamTool.cpp
>> cgm/trunk/util/PlanarParamTool.hpp
>> cgm/trunk/util/PriorityQueue.cpp
>> cgm/trunk/util/RTree.cpp
>> cgm/trunk/util/RTree.hpp
>> cgm/trunk/util/RandomMersenne.cpp
>> cgm/trunk/util/SDLList.cpp
>> cgm/trunk/util/SDLList.hpp
>> cgm/trunk/util/SettingHandler.cpp
>> cgm/trunk/util/SettingHandler.hpp
>> cgm/trunk/util/TextProgressTool.cpp
>> cgm/trunk/util/ToolData.cpp
>> cgm/trunk/util/ToolData.hpp
>> cgm/trunk/util/ToolDataUser.cpp
>> cgm/trunk/util/ToolDataUser.hpp
>> cgm/trunk/util/TtyProgressTool.cpp
>> Log:
>> Merge branch/merge-cubit12 to trunk, passed all testcases for
>> OCC6.3(build with /geom/OCC/occ_patches), OCC6.5(build with
>> /geom/OCC/occ_patches_6.5), acis17 as well as cubit12 builds. Special
>> note: When building with cubit12, current test code doesn't do
>> anything for geom/testing directory. Status is<All 0 tests passed>.
>> Property changes on: cgm/trunk
>> ___________________________________________________________________
>> Added: svn:mergeinfo
>> + /cgm/branches/cubit:1041-3427
>> /cgm/branches/merge-cubit12:3424-4774
>> Deleted: cgm/trunk/KNOWN_ISSUES
>> --- cgm/trunk/KNOWN_ISSUES 2011-04-23 05:15:17 UTC (rev 4774)
>> +++ cgm/trunk/KNOWN_ISSUES 2011-04-26 17:54:11 UTC (rev 4775)
>> @@ -1,27 +0,0 @@
>> -This is a list of the known issues with CGM on OCC.For more details
>> please see
>> -the online ticket system at the MOAB website:
>> - https://trac.mcs.anl.gov/projects/ITAPS/wiki
>> -ID Severity Summary/Details
>> -175 critical imprint special cases fail with crash.
>> -176 minor CGM memory leak
>> -178 major Unite function doesn't unite smoothly connected surfaces.
>> -179 major mcnp2cad test suite lat1-7 not working, needs debugging.
>> -180 major There are lots new functions or added functions to
>> exsisting
>> - functions requirements to port OCC to cubit12.
>> -181 minor Lack of good cases for testing purpose.
>> -182 minor Dirty geometry/imported geometry is not tested for
>> read/repair yet
>> -183 minor Don't have proper tool to visualize the TopoDS_Shapes,
>> debugging
>> - process is long preparing for graphics to understand the issue
>> -185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2
>> spline
>> - surfaces.
>> Added: cgm/trunk/KNOWN_ISSUES
>> --- cgm/trunk/KNOWN_ISSUES (rev 0)
>> @@ -0,0 +1,27 @@
>> +This is a list of the known issues with CGM on OCC.For more details
>> please see
>> +the online ticket system at the MOAB website:
>> + https://trac.mcs.anl.gov/projects/ITAPS/wiki
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
