[cgma-dev] r4790 - cgm/trunk/itaps
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Mon May  2 14:15:48 CDT 2011
On 05/02/2011 02:08 PM, Tim Tautges wrote:
> Maybe I need to be a bit more specific in my request that Jane implement
> functions in iGeom to get facet information. The function signature I'm
> looking for is:
> iGeom_getFacets(iGeom_EntityHandle entity,
>                 double dist_tolerance,
>                 double **points, int *points_alloc, int *points_size,
>                 int **facets, int *facets_alloc, int *facets_size)
That should probably be:
iGeom_getFacets(iGeom_Instance instance,  // <=====
Also, for curves, I assume that the 'facets' arguments are unused?  Or do
you prefer them to be populated with index pairs for edges?  Or is it
RefFaces only?
- jason
More information about the cgma-dev
