[cgma-dev] r4790 - cgm/trunk/itaps
    Tim Tautges
    tautges at mcs.anl.gov
    Mon May  2 19:41:03 CDT 2011
I personally would prefer a single function, with the facets arguments ignored if an edge is input.  I suspect others
may have other opinions, but I'd like to have a working version before we propose this to the ITAPS group.
And yes, there should be an iGeom instance as the first argument, I did forget that.
- tim
On 05/02/2011 02:15 PM, Jason Kraftcheck wrote:
> On 05/02/2011 02:08 PM, Tim Tautges wrote:
>> Maybe I need to be a bit more specific in my request that Jane implement
>> functions in iGeom to get facet information. The function signature I'm
>> looking for is:
>> iGeom_getFacets(iGeom_EntityHandle entity,
>>                  double dist_tolerance,
>>                  double **points, int *points_alloc, int *points_size,
>>                  int **facets, int *facets_alloc, int *facets_size)
> That should probably be:
> iGeom_getFacets(iGeom_Instance instance,  //<=====
> Also, for curves, I assume that the 'facets' arguments are unused?  Or do
> you prefer them to be populated with index pairs for edges?  Or is it
> RefFaces only?
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
