[cgma-dev] r4775 - in cgm/trunk: . cgm_apps/ccapi/geom	cgm_apps/cgm_cubit_acis cgm_apps/examples/driverc++	cgm_apps/examples/gomadrive geom geom/ACIS_SRC geom/ACIS_SRC/gtcAttrib geom/ACIS_SRC/gtcAttrib/incl	geom/Cholla geom/OCC geom/SolidWorks geom/facet	geom/facetbool geom/parallel geom/testing geom/testing/data geom/virtual init itaps test util util/OtherFiles
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Apr 26 14:39:34 CDT 2011
No, 10.2 should still be supported (Jane, can you check that too?)
- tim
On 04/26/2011 02:30 PM, Rajeev Jain wrote:
> Would this change mean that Cubit-10.2 is no longer supported?
> Rajeev
>     *From:* "jiangtao_ma at yahoo.com" <jiangtao_ma at yahoo.com>
>     *To:* cgma-dev at mcs.anl.gov
>     *Sent:* Tuesday, April 26, 2011 12:54 PM
>     *Subject:* [cgma-dev] r4775 - in cgm/trunk: . cgm_apps/ccapi/geom
>     util/OtherFiles
>     Author: janehu
>     Date: 2011-04-26 12:54:11 -0500 (Tue, 26 Apr 2011)
>     New Revision: 4775
>     Added:
>     cgm/trunk/KNOWN_ISSUES
>     cgm/trunk/geom/ACIS_SRC/AcisHistory.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisHistory.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisTopologyTool.hpp
>     cgm/trunk/geom/ACIS_SRC/attrib_history.cpp
>     cgm/trunk/geom/ACIS_SRC/attrib_history.hpp
>     cgm/trunk/geom/AutoMidsurfaceTool.cpp
>     cgm/trunk/geom/AutoMidsurfaceTool.hpp
>     cgm/trunk/geom/CGMHistory.cpp
>     cgm/trunk/geom/CGMHistory.hpp
>     cgm/trunk/geom/Cholla/ChollaVolume.cpp
>     cgm/trunk/geom/Cholla/ChollaVolume.hpp
>     cgm/trunk/geom/Cholla/FacetorUtil.cpp
>     cgm/trunk/geom/Cholla/FacetorUtil.hpp
>     cgm/trunk/geom/CubitCompat.cpp
>     cgm/trunk/geom/CubitCompat.h.in
>     cgm/trunk/geom/CubitCompat.hpp
>     cgm/trunk/geom/OCC/OCCHistory.cpp
>     cgm/trunk/geom/OCC/OCCHistory.hpp
>     cgm/trunk/geom/OCC/occ_attrib_history.hpp
>     cgm/trunk/geom/OCC/occ_patches_6.5
>     cgm/trunk/geom/PeriodicParamTool.cpp
>     cgm/trunk/geom/PeriodicParamTool.hpp
>     cgm/trunk/geom/testing/
>     cgm/trunk/geom/testing/AngleCalc.cpp
>     cgm/trunk/geom/testing/CMakeLists.txt
>     cgm/trunk/geom/testing/CreateGeometry.cpp
>     cgm/trunk/geom/testing/GraphicsData.cpp
>     cgm/trunk/geom/testing/Makefile.am
>     cgm/trunk/geom/testing/ReadIgesFile.cpp
>     cgm/trunk/geom/testing/TestConfig.h.in
>     cgm/trunk/geom/testing/TestUtilities.cpp
>     cgm/trunk/geom/testing/TestUtilities.hpp
>     cgm/trunk/geom/testing/cgm_test.cpp
>     cgm/trunk/geom/testing/cgm_test.hpp
>     cgm/trunk/geom/testing/cgm_test_script
>     cgm/trunk/geom/testing/data/
>     cgm/trunk/geom/testing/data/brick.iges
>     cgm/trunk/geom/testing/main.cpp
>     cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.cpp
>     cgm/trunk/geom/virtual/SplitCompositeSurfaceTool.hpp
>     cgm/trunk/test/Cylinder_1.brep
>     cgm/trunk/test/Cylinder_2.brep
>     cgm/trunk/util/CommandFeedback.hpp
>     cgm/trunk/util/CubitUndo.cpp
>     cgm/trunk/util/CubitUndo.hpp
>     cgm/trunk/util/ExternalCoordinateSystem.hpp
>     cgm/trunk/util/GlobalCommandFeedback.cpp
>     cgm/trunk/util/GlobalCommandFeedback.hpp
>     cgm/trunk/util/ManagedPtrVector.hpp
>     cgm/trunk/util/OrderedMap.hpp
>     cgm/trunk/util/OrderedSet.hpp
>     Removed:
>     Modified:
>     cgm/trunk/
>     cgm/trunk/Makefile.am
>     cgm/trunk/cgm_apps/ccapi/geom/GeometryTool_ccapi.cpp
>     cgm/trunk/cgm_apps/cgm_cubit_acis/main_cubit_acis.cpp
>     cgm/trunk/cgm_apps/examples/driverc++/mergechk.cpp
>     cgm/trunk/cgm_apps/examples/gomadrive/gm_cgm_c_interface.C
>     cgm/trunk/configure.ac
>     cgm/trunk/geom/
>     cgm/trunk/geom/ACIS_SRC/AcisBridge.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisDrawTool.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisEdgeTool.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisFacetManager.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisFacetManager.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisFeatureEngine.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisHealerTool.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisHealerTool.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisSurfaceTool.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisToolUtil.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisToolUtil.hpp
>     cgm/trunk/geom/ACIS_SRC/AcisTweakTool.cpp
>     cgm/trunk/geom/ACIS_SRC/AcisTweakTool.hpp
>     cgm/trunk/geom/ACIS_SRC/BodyACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/BodyACIS.hpp
>     cgm/trunk/geom/ACIS_SRC/CMakeLists.txt
>     cgm/trunk/geom/ACIS_SRC/CoEdgeACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/CurveACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/CurveACIS.hpp
>     cgm/trunk/geom/ACIS_SRC/LoopACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/LoopACIS.hpp
>     cgm/trunk/geom/ACIS_SRC/LumpACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/LumpACIS.hpp
>     cgm/trunk/geom/ACIS_SRC/Makefile.am
>     cgm/trunk/geom/ACIS_SRC/PointACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/ShellACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/SurfaceACIS.cpp
>     cgm/trunk/geom/ACIS_SRC/SurfaceACIS.hpp
>     cgm/trunk/geom/ACIS_SRC/UseACIS.cmake
>     cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.cpp
>     cgm/trunk/geom/ACIS_SRC/attrib_cubit_owner.hpp
>     cgm/trunk/geom/ACIS_SRC/attrib_snl.cpp
>     cgm/trunk/geom/ACIS_SRC/attrib_snl.hpp
>     cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.cpp
>     cgm/trunk/geom/ACIS_SRC/attrib_snl_simple.hpp
>     cgm/trunk/geom/ACIS_SRC/decl_none.h
>     cgm/trunk/geom/ACIS_SRC/gtcAttrib/CMakeLists.txt
>     cgm/trunk/geom/ACIS_SRC/gtcAttrib/Makefile
>     cgm/trunk/geom/ACIS_SRC/gtcAttrib/incl/attrib_gtc_export.h
>     cgm/trunk/geom/AllocMemManagersGeom.cpp
>     cgm/trunk/geom/AnalyticGeometryTool.cpp
>     cgm/trunk/geom/AnalyticGeometryTool.hpp
>     cgm/trunk/geom/BasicTopologyEntity.cpp
>     cgm/trunk/geom/BasicTopologyEntity.hpp
>     cgm/trunk/geom/Body.cpp
>     cgm/trunk/geom/Body.hpp
>     cgm/trunk/geom/BodySM.cpp
>     cgm/trunk/geom/BodySM.hpp
>     cgm/trunk/geom/BoundingBoxTool.cpp
>     cgm/trunk/geom/BoundingBoxTool.hpp
>     cgm/trunk/geom/BridgeManager.cpp
>     cgm/trunk/geom/BridgeManager.hpp
>     cgm/trunk/geom/CAActuateSet.cpp
>     cgm/trunk/geom/CAActuateSet.hpp
>     cgm/trunk/geom/CADeferredAttrib.cpp
>     cgm/trunk/geom/CADeferredAttrib.hpp
>     cgm/trunk/geom/CADefines.hpp
>     cgm/trunk/geom/CAEntityColor.cpp
>     cgm/trunk/geom/CAEntityColor.hpp
>     cgm/trunk/geom/CAEntityId.cpp
>     cgm/trunk/geom/CAEntityId.hpp
>     cgm/trunk/geom/CAEntityName.cpp
>     cgm/trunk/geom/CAEntityName.hpp
>     cgm/trunk/geom/CAGroup.cpp
>     cgm/trunk/geom/CAGroup.hpp
>     cgm/trunk/geom/CAMergePartner.cpp
>     cgm/trunk/geom/CAMergePartner.hpp
>     cgm/trunk/geom/CAMergeStatus.cpp
>     cgm/trunk/geom/CAMergeStatus.hpp
>     cgm/trunk/geom/CASourceFeature.cpp
>     cgm/trunk/geom/CASourceFeature.hpp
>     cgm/trunk/geom/CAUniqueId.cpp
>     cgm/trunk/geom/CAUniqueId.hpp
>     cgm/trunk/geom/CGMApp.cpp
>     cgm/trunk/geom/CGMApp.hpp
>     cgm/trunk/geom/CGMEngineDynamicLoader.cpp
>     cgm/trunk/geom/CGMEngineDynamicLoader.hpp
>     cgm/trunk/geom/CMakeLists.txt
>     cgm/trunk/geom/Chain.cpp
>     cgm/trunk/geom/Chain.hpp
>     cgm/trunk/geom/Cholla/CMakeLists.txt
>     cgm/trunk/geom/Cholla/Cholla.cpp
>     cgm/trunk/geom/Cholla/ChollaCurve.cpp
>     cgm/trunk/geom/Cholla/ChollaCurve.hpp
>     cgm/trunk/geom/Cholla/ChollaEngine.cpp
>     cgm/trunk/geom/Cholla/ChollaEngine.hpp
>     cgm/trunk/geom/Cholla/ChollaPoint.cpp
>     cgm/trunk/geom/Cholla/ChollaPoint.hpp
>     cgm/trunk/geom/Cholla/ChollaSurface.cpp
>     cgm/trunk/geom/Cholla/ChollaSurface.hpp
>     cgm/trunk/geom/Cholla/CubitFacet.cpp
>     cgm/trunk/geom/Cholla/CubitFacet.hpp
>     cgm/trunk/geom/Cholla/CubitFacetData.cpp
>     cgm/trunk/geom/Cholla/CubitFacetData.hpp
>     cgm/trunk/geom/Cholla/CubitFacetEdge.hpp
>     cgm/trunk/geom/Cholla/CurveFacetEvalTool.cpp
>     cgm/trunk/geom/Cholla/CurveFacetEvalTool.hpp
>     cgm/trunk/geom/Cholla/FacetDataUtil.cpp
>     cgm/trunk/geom/Cholla/FacetDataUtil.hpp
>     cgm/trunk/geom/Cholla/FacetEvalTool.cpp
>     cgm/trunk/geom/Cholla/FacetEvalTool.hpp
>     cgm/trunk/geom/Cholla/FacetorTool.cpp
>     cgm/trunk/geom/Cholla/FacetorTool.hpp
>     cgm/trunk/geom/Cholla/LoopParamTool.cpp
>     cgm/trunk/geom/Cholla/LoopParamTool.hpp
>     cgm/trunk/geom/Cholla/Makefile.am
>     cgm/trunk/geom/Cholla/TDGeomFacet.cpp
>     cgm/trunk/geom/Cholla/TDGeomFacet.hpp
>     cgm/trunk/geom/Cholla/debug.cpp
>     cgm/trunk/geom/Cholla/debug.hpp
>     cgm/trunk/geom/CoEdge.cpp
>     cgm/trunk/geom/CoEdge.hpp
>     cgm/trunk/geom/CoEdgeSM.cpp
>     cgm/trunk/geom/CoEdgeSM.hpp
>     cgm/trunk/geom/CoFace.cpp
>     cgm/trunk/geom/CoFace.hpp
>     cgm/trunk/geom/CoVertex.cpp
>     cgm/trunk/geom/CoVertex.hpp
>     cgm/trunk/geom/CoVolume.cpp
>     cgm/trunk/geom/CoVolume.hpp
>     cgm/trunk/geom/CollectionEntity.cpp
>     cgm/trunk/geom/CollectionEntity.hpp
>     cgm/trunk/geom/CompositeCombineEvent.hpp
>     cgm/trunk/geom/CubitAttrib.cpp
>     cgm/trunk/geom/CubitAttrib.hpp
>     cgm/trunk/geom/CubitAttribManager.cpp
>     cgm/trunk/geom/CubitAttribManager.hpp
>     cgm/trunk/geom/CubitAttribUser.cpp
>     cgm/trunk/geom/CubitAttribUser.hpp
>     cgm/trunk/geom/CubitEvaluator.hpp
>     cgm/trunk/geom/CubitGeomConfigure.h
>     cgm/trunk/geom/CubitGeomConfigure.h.in
>     cgm/trunk/geom/CubitPolygon.cpp
>     cgm/trunk/geom/CubitPolygon.hpp
>     cgm/trunk/geom/CubitSimpleAttrib.cpp
>     cgm/trunk/geom/CubitSimpleAttrib.hpp
>     cgm/trunk/geom/Curve.cpp
>     cgm/trunk/geom/Curve.hpp
>     cgm/trunk/geom/CurveOverlapFacet.cpp
>     cgm/trunk/geom/CurveOverlapFacet.hpp
>     cgm/trunk/geom/CurveSM.cpp
>     cgm/trunk/geom/CurveSM.hpp
>     cgm/trunk/geom/CylinderEvaluator.cpp
>     cgm/trunk/geom/CylinderEvaluator.hpp
>     cgm/trunk/geom/DAG.cpp
>     cgm/trunk/geom/DAG.hpp
>     cgm/trunk/geom/DagDrawingTool.cpp
>     cgm/trunk/geom/DagDrawingTool.hpp
>     cgm/trunk/geom/DagType.hpp
>     cgm/trunk/geom/GSaveOpen.cpp
>     cgm/trunk/geom/GSaveOpen.hpp
>     cgm/trunk/geom/GeomDataObserver.cpp
>     cgm/trunk/geom/GeomDataObserver.hpp
>     cgm/trunk/geom/GeomMeasureTool.cpp
>     cgm/trunk/geom/GeomMeasureTool.hpp
>     cgm/trunk/geom/GeomPoint.hpp
>     cgm/trunk/geom/GeomSeg.hpp
>     cgm/trunk/geom/GeometryEntity.cpp
>     cgm/trunk/geom/GeometryEntity.hpp
>     cgm/trunk/geom/GeometryFeatureEngine.cpp
>     cgm/trunk/geom/GeometryFeatureEngine.hpp
>     cgm/trunk/geom/GeometryFeatureTool.cpp
>     cgm/trunk/geom/GeometryFeatureTool.hpp
>     cgm/trunk/geom/GeometryHealerEngine.cpp
>     cgm/trunk/geom/GeometryHealerEngine.hpp
>     cgm/trunk/geom/GeometryHealerTool.cpp
>     cgm/trunk/geom/GeometryHealerTool.hpp
>     cgm/trunk/geom/GeometryModifyEngine.cpp
>     cgm/trunk/geom/GeometryModifyEngine.hpp
>     cgm/trunk/geom/GeometryModifyTool.cpp
>     cgm/trunk/geom/GeometryModifyTool.hpp
>     cgm/trunk/geom/GeometryQueryEngine.cpp
>     cgm/trunk/geom/GeometryQueryEngine.hpp
>     cgm/trunk/geom/GeometryQueryTool.cpp
>     cgm/trunk/geom/GeometryQueryTool.hpp
>     cgm/trunk/geom/GeometryUtil.cpp
>     cgm/trunk/geom/GeometryUtil.hpp
>     cgm/trunk/geom/GfxPreview.cpp
>     cgm/trunk/geom/GfxPreview.hpp
>     cgm/trunk/geom/GroupingEntity.cpp
>     cgm/trunk/geom/GroupingEntity.hpp
>     cgm/trunk/geom/IntermediateGeomEngine.hpp
>     cgm/trunk/geom/Loop.cpp
>     cgm/trunk/geom/Loop.hpp
>     cgm/trunk/geom/LoopSM.cpp
>     cgm/trunk/geom/LoopSM.hpp
>     cgm/trunk/geom/Lump.cpp
>     cgm/trunk/geom/Lump.hpp
>     cgm/trunk/geom/LumpSM.cpp
>     cgm/trunk/geom/LumpSM.hpp
>     cgm/trunk/geom/Makefile.am
>     cgm/trunk/geom/MedialTool2D.cpp
>     cgm/trunk/geom/MedialTool2D.hpp
>     cgm/trunk/geom/MedialTool3D.cpp
>     cgm/trunk/geom/MedialTool3D.hpp
>     cgm/trunk/geom/MergeTool.cpp
>     cgm/trunk/geom/MergeTool.hpp
>     cgm/trunk/geom/MergeToolAssistant.cpp
>     cgm/trunk/geom/MergeToolAssistant.hpp
>     cgm/trunk/geom/MidPlaneTool.cpp
>     cgm/trunk/geom/MidPlaneTool.hpp
>     cgm/trunk/geom/ModelEntity.cpp
>     cgm/trunk/geom/ModelEntity.hpp
>     cgm/trunk/geom/ModelQueryEngine.cpp
>     cgm/trunk/geom/ModelQueryEngine.hpp
>     cgm/trunk/geom/OCC/
>     cgm/trunk/geom/OCC/Makefile.am
>     cgm/trunk/geom/OCC/OCCAttribSet.cpp
>     cgm/trunk/geom/OCC/OCCBody.cpp
>     cgm/trunk/geom/OCC/OCCCurve.cpp
>     cgm/trunk/geom/OCC/OCCDrawTool.cpp
>     cgm/trunk/geom/OCC/OCCLoop.cpp
>     cgm/trunk/geom/OCC/OCCLoop.hpp
>     cgm/trunk/geom/OCC/OCCLump.cpp
>     cgm/trunk/geom/OCC/OCCLump.hpp
>     cgm/trunk/geom/OCC/OCCModifyEngine.cpp
>     cgm/trunk/geom/OCC/OCCModifyEngine.hpp
>     cgm/trunk/geom/OCC/OCCPoint.cpp
>     cgm/trunk/geom/OCC/OCCQueryEngine.cpp
>     cgm/trunk/geom/OCC/OCCQueryEngine.hpp
>     cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
>     cgm/trunk/geom/OCC/OCCShell.cpp
>     cgm/trunk/geom/OCC/OCCSurface.cpp
>     cgm/trunk/geom/OCC/OCCSurface.hpp
>     cgm/trunk/geom/OffsetSplitTool.cpp
>     cgm/trunk/geom/OffsetSplitTool.hpp
>     cgm/trunk/geom/OldUnmergeCode.cpp
>     cgm/trunk/geom/OldUnmergeCode.hpp
>     cgm/trunk/geom/Point.cpp
>     cgm/trunk/geom/Point.hpp
>     cgm/trunk/geom/PointSM.cpp
>     cgm/trunk/geom/PointSM.hpp
>     cgm/trunk/geom/RefCollection.cpp
>     cgm/trunk/geom/RefCollection.hpp
>     cgm/trunk/geom/RefEdge.cpp
>     cgm/trunk/geom/RefEdge.hpp
>     cgm/trunk/geom/RefEntity.cpp
>     cgm/trunk/geom/RefEntity.hpp
>     cgm/trunk/geom/RefEntityFactory.cpp
>     cgm/trunk/geom/RefEntityFactory.hpp
>     cgm/trunk/geom/RefEntityName.cpp
>     cgm/trunk/geom/RefEntityName.hpp
>     cgm/trunk/geom/RefEntityNameMap.hpp
>     cgm/trunk/geom/RefFace.cpp
>     cgm/trunk/geom/RefFace.hpp
>     cgm/trunk/geom/RefGroup.cpp
>     cgm/trunk/geom/RefGroup.hpp
>     cgm/trunk/geom/RefVertex.cpp
>     cgm/trunk/geom/RefVertex.hpp
>     cgm/trunk/geom/RefVolume.cpp
>     cgm/trunk/geom/RefVolume.hpp
>     cgm/trunk/geom/SenseEntity.cpp
>     cgm/trunk/geom/SenseEntity.hpp
>     cgm/trunk/geom/Shell.cpp
>     cgm/trunk/geom/Shell.hpp
>     cgm/trunk/geom/ShellSM.cpp
>     cgm/trunk/geom/ShellSM.hpp
>     cgm/trunk/geom/SolidWorks/
>     cgm/trunk/geom/SphereEvaluator.cpp
>     cgm/trunk/geom/SphereEvaluator.hpp
>     cgm/trunk/geom/SplitSurfaceTool.cpp
>     cgm/trunk/geom/SplitSurfaceTool.hpp
>     cgm/trunk/geom/SurfParamTool.cpp
>     cgm/trunk/geom/SurfParamTool.hpp
>     cgm/trunk/geom/Surface.cpp
>     cgm/trunk/geom/Surface.hpp
>     cgm/trunk/geom/SurfaceOverlapFacet.cpp
>     cgm/trunk/geom/SurfaceOverlapFacet.hpp
>     cgm/trunk/geom/SurfaceOverlapTool.cpp
>     cgm/trunk/geom/SurfaceOverlapTool.hpp
>     cgm/trunk/geom/SurfaceSM.cpp
>     cgm/trunk/geom/SurfaceSM.hpp
>     cgm/trunk/geom/TBOwner.hpp
>     cgm/trunk/geom/TBOwnerSet.hpp
>     cgm/trunk/geom/TDCAGE.cpp
>     cgm/trunk/geom/TDCAGE.hpp
>     cgm/trunk/geom/TDCompare.hpp
>     cgm/trunk/geom/TDSourceFeature.cpp
>     cgm/trunk/geom/TDSourceFeature.hpp
>     cgm/trunk/geom/TDSplitSurface.cpp
>     cgm/trunk/geom/TDSplitSurface.hpp
>     cgm/trunk/geom/TDSurfaceOverlap.cpp
>     cgm/trunk/geom/TDSurfaceOverlap.hpp
>     cgm/trunk/geom/TDUniqueId.cpp
>     cgm/trunk/geom/TDUniqueId.hpp
>     cgm/trunk/geom/TopologyBridge.cpp
>     cgm/trunk/geom/TopologyBridge.hpp
>     cgm/trunk/geom/TopologyEntity.cpp
>     cgm/trunk/geom/TopologyEntity.hpp
>     cgm/trunk/geom/UnMergeEvent.hpp
>     cgm/trunk/geom/facet/
>     cgm/trunk/geom/facet/FacetCurve.cpp
>     cgm/trunk/geom/facet/FacetLoop.cpp
>     cgm/trunk/geom/facet/FacetLoop.hpp
>     cgm/trunk/geom/facet/FacetModifyEngine.cpp
>     cgm/trunk/geom/facet/FacetModifyEngine.hpp
>     cgm/trunk/geom/facet/FacetParamTool.cpp
>     cgm/trunk/geom/facet/FacetParamTool.hpp
>     cgm/trunk/geom/facet/FacetQueryEngine.cpp
>     cgm/trunk/geom/facet/FacetQueryEngine.hpp
>     cgm/trunk/geom/facet/FacetboolInterface.cpp
>     cgm/trunk/geom/facetbool/
>     cgm/trunk/geom/facetbool/FBRetriangulate.cpp
>     cgm/trunk/geom/libcubit_geom.dsp
>     cgm/trunk/geom/parallel/
>     cgm/trunk/geom/parallel/CGMmpi.h
>     cgm/trunk/geom/parallel/CGMmpi_config.h.in
>     cgm/trunk/geom/virtual/CMakeLists.txt
>     cgm/trunk/geom/virtual/CollapseCurveTool.cpp
>     cgm/trunk/geom/virtual/CollapseCurveTool.hpp
>     cgm/trunk/geom/virtual/CompSurfFacets.cpp
>     cgm/trunk/geom/virtual/CompositeEngine.cpp
>     cgm/trunk/geom/virtual/CompositeEngine.hpp
>     cgm/trunk/geom/virtual/CompositeGeom.cpp
>     cgm/trunk/geom/virtual/CompositeGeom.hpp
>     cgm/trunk/geom/virtual/CompositeLoop.cpp
>     cgm/trunk/geom/virtual/CompositeLoop.hpp
>     cgm/trunk/geom/virtual/CompositeSurface.cpp
>     cgm/trunk/geom/virtual/CompositeSurface.hpp
>     cgm/trunk/geom/virtual/CompositeTool.cpp
>     cgm/trunk/geom/virtual/FacetProjectTool.cpp
>     cgm/trunk/geom/virtual/FacetProjectTool.hpp
>     cgm/trunk/geom/virtual/Faceter.cpp
>     cgm/trunk/geom/virtual/ImprintBoundaryTool.cpp
>     cgm/trunk/geom/virtual/Makefile.am
>     cgm/trunk/geom/virtual/PartSurfFacetTool.cpp
>     cgm/trunk/geom/virtual/PartitionEngine.cpp
>     cgm/trunk/geom/virtual/PartitionEngine.hpp
>     cgm/trunk/geom/virtual/PartitionLoop.cpp
>     cgm/trunk/geom/virtual/PartitionLoop.hpp
>     cgm/trunk/geom/virtual/PartitionSurface.cpp
>     cgm/trunk/geom/virtual/PartitionTool.cpp
>     cgm/trunk/geom/virtual/RemoveBlends.cpp
>     cgm/trunk/geom/virtual/SimplifyTool.cpp
>     cgm/trunk/geom/virtual/SimplifyTool.hpp
>     cgm/trunk/geom/virtual/SubCurve.cpp
>     cgm/trunk/geom/virtual/SubSurface.cpp
>     cgm/trunk/geom/virtual/VGLoopTool.cpp
>     cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
>     cgm/trunk/geom/virtual/VirtualQueryEngine.hpp
>     cgm/trunk/init/InitCGMA.cpp
>     cgm/trunk/itaps/iGeom_CGMA.cc
>     cgm/trunk/itaps/testgeom.cc
>     cgm/trunk/test/makept.cpp
>     cgm/trunk/test/merge_test.cpp
>     cgm/trunk/test/modify.cpp
>     cgm/trunk/test/operation.cpp
>     cgm/trunk/test/r_w.cpp
>     cgm/trunk/test/test_occ.cpp
>     cgm/trunk/test/webcut.cpp
>     cgm/trunk/util/AppUtil.cpp
>     cgm/trunk/util/AppUtil.hpp
>     cgm/trunk/util/ArrayBasedContainer.cpp
>     cgm/trunk/util/CMakeLists.txt
>     cgm/trunk/util/CastTo.hpp
>     cgm/trunk/util/CpuTimer.cpp
>     cgm/trunk/util/CpuTimer.hpp
>     cgm/trunk/util/CubitBox.cpp
>     cgm/trunk/util/CubitBox.hpp
>     cgm/trunk/util/CubitColorConstants.hpp
>     cgm/trunk/util/CubitCoordinateSystem.cpp
>     cgm/trunk/util/CubitDefines.h
>     cgm/trunk/util/CubitDynamicLoader.cpp
>     cgm/trunk/util/CubitEntity.cpp
>     cgm/trunk/util/CubitEventDefines.h
>     cgm/trunk/util/CubitFile.cpp
>     cgm/trunk/util/CubitFile.hpp
>     cgm/trunk/util/CubitFileFEModel.cpp
>     cgm/trunk/util/CubitFileFEModel.hpp
>     cgm/trunk/util/CubitFileIOWrapper.cpp
>     cgm/trunk/util/CubitFileIOWrapper.hpp
>     cgm/trunk/util/CubitFileMetaData.cpp
>     cgm/trunk/util/CubitFileUtil.cpp
>     cgm/trunk/util/CubitInputFile.hpp
>     cgm/trunk/util/CubitMatrix.cpp
>     cgm/trunk/util/CubitMessage.cpp
>     cgm/trunk/util/CubitMessage.hpp
>     cgm/trunk/util/CubitPlane.cpp
>     cgm/trunk/util/CubitPlane.hpp
>     cgm/trunk/util/CubitStack.cpp
>     cgm/trunk/util/CubitString.cpp
>     cgm/trunk/util/CubitString.hpp
>     cgm/trunk/util/CubitTransformMatrix.cpp
>     cgm/trunk/util/CubitTransformMatrix.hpp
>     cgm/trunk/util/CubitUtil.cpp
>     cgm/trunk/util/CubitUtil.hpp
>     cgm/trunk/util/CubitUtilConfigure.h.in
>     cgm/trunk/util/CubitVector.cpp
>     cgm/trunk/util/CubitVector.hpp
>     cgm/trunk/util/DIntArray.cpp
>     cgm/trunk/util/DLIList.cpp
>     cgm/trunk/util/DLIList.hpp
>     cgm/trunk/util/DLList.hpp
>     cgm/trunk/util/DynamicArray.cpp
>     cgm/trunk/util/DynamicArray.hpp
>     cgm/trunk/util/ElementType.h
>     cgm/trunk/util/GMem.cpp
>     cgm/trunk/util/GeometryDefines.h
>     cgm/trunk/util/GetLongOpt.hpp
>     cgm/trunk/util/GfxDebug.cpp
>     cgm/trunk/util/GfxDebug.hpp
>     cgm/trunk/util/IntersectionTool.cpp
>     cgm/trunk/util/IntersectionTool.hpp
>     cgm/trunk/util/KDDTree.cpp
>     cgm/trunk/util/Makefile.am
>     cgm/trunk/util/MemoryBlock.hpp
>     cgm/trunk/util/MemoryManager.cpp
>     cgm/trunk/util/MemoryManager.hpp
>     cgm/trunk/util/OctTree.cpp
>     cgm/trunk/util/OtherFiles/make.client
>     cgm/trunk/util/ParamTool.hpp
>     cgm/trunk/util/PlanarParamTool.cpp
>     cgm/trunk/util/PlanarParamTool.hpp
>     cgm/trunk/util/PriorityQueue.cpp
>     cgm/trunk/util/RTree.cpp
>     cgm/trunk/util/RTree.hpp
>     cgm/trunk/util/RandomMersenne.cpp
>     cgm/trunk/util/SDLList.cpp
>     cgm/trunk/util/SDLList.hpp
>     cgm/trunk/util/SettingHandler.cpp
>     cgm/trunk/util/SettingHandler.hpp
>     cgm/trunk/util/TextProgressTool.cpp
>     cgm/trunk/util/ToolData.cpp
>     cgm/trunk/util/ToolData.hpp
>     cgm/trunk/util/ToolDataUser.cpp
>     cgm/trunk/util/ToolDataUser.hpp
>     cgm/trunk/util/TtyProgressTool.cpp
>     Log:
>     Merge branch/merge-cubit12 to trunk, passed all testcases for
>     OCC6.3(build with /geom/OCC/occ_patches), OCC6.5(build with
>     /geom/OCC/occ_patches_6.5), acis17 as well as cubit12 builds.
>     Special note: When building with cubit12, current test code doesn't
>     do anything for geom/testing directory. Status is <All 0 tests passed>.
>     Property changes on: cgm/trunk
>     ___________________________________________________________________
>     Added: svn:mergeinfo
>     + /cgm/branches/cubit:1041-3427
>     /cgm/branches/merge-cubit12:3424-4774
>     Deleted: cgm/trunk/KNOWN_ISSUES
>     --- cgm/trunk/KNOWN_ISSUES 2011-04-23 05:15:17 UTC (rev 4774)
>     +++ cgm/trunk/KNOWN_ISSUES 2011-04-26 17:54:11 UTC (rev 4775)
>     @@ -1,27 +0,0 @@
>     -This is a list of the known issues with CGM on OCC.For more details
>     please see
>     -the online ticket system at the MOAB website:
>     - https://trac.mcs.anl.gov/projects/ITAPS/wiki
>     -ID Severity Summary/Details
>     -175 critical imprint special cases fail with crash.
>     -176 minor CGM memory leak
>     -178 major Unite function doesn't unite smoothly connected surfaces.
>     -179 major mcnp2cad test suite lat1-7 not working, needs debugging.
>     -180 major There are lots new functions or added functions to exsisting
>     - functions requirements to port OCC to cubit12.
>     -181 minor Lack of good cases for testing purpose.
>     -182 minor Dirty geometry/imported geometry is not tested for
>     read/repair yet
>     -183 minor Don't have proper tool to visualize the TopoDS_Shapes,
>     debugging
>     - process is long preparing for graphics to understand the issue
>     -185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2
>     spline
>     - surfaces.
>     Added: cgm/trunk/KNOWN_ISSUES
>     --- cgm/trunk/KNOWN_ISSUES (rev 0)
>     @@ -0,0 +1,27 @@
>     +This is a list of the known issues with CGM on OCC.For more details
>     please see
>     +the online ticket system at the MOAB website:
>     + https://trac.mcs.anl.gov/projects/ITAPS/wiki
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
