[cgma-dev] buildbot failure in cgm-occ: failed test
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Apr 19 13:44:24 CDT 2011
Actually, we should merge the branch code into the trunk now.
- tim
On 04/19/2011 01:31 PM, Jane Hu wrote:
> Hi, James
> Tim wants to release CGM in merge-cubit12 branch, and then use this as
> trunk later. This indicates that we don't need to support current CGM
> trunk later. For now, can we build using OCC6.5 and merge-cubit12 for
> testing? and stop testing in the CGM trunk? I am now only focusing on
> the branch. Thanks.
> Jane
> On Tue, Apr 19, 2011 at 1:20 PM, James Porter <jvporter at wisc.edu
> <mailto:jvporter at wisc.edu>> wrote:
>     Again, the buildbot tests only the trunk builds. The changes in the
>     cubit12 branch shouldn't have any effect on the state of trunk.
>     I'm guessing the failures are due to r4735, but I haven't been
>     following CGM closely.
>     - Jim
>     On 04/19/11, Jane Hu   wrote:
>      > Hello,
>      > Is this build with OCC6.5 and merge-cubit12 branch? I just
>     checked out the whole merge-cubit12 branch and built with OCC6.5,
>     and it passed all 12 testcases.
>      > Jane
>      > On Tue, Apr 19, 2011 at 12:51 AM, <cgma-dev at mcs.anl.gov
>     <mailto:cgma-dev at mcs.anl.gov> <cgma-dev at mcs.anl.gov
>     <mailto:cgma-dev at mcs.anl.gov>>> wrote:
>      > > Fathom(http://gnep.mcs.anl.gov:8010/):
>     cgm-occ(http://gnep.mcs.anl.gov:8010/builders/cgm-occ) build
>     #452(http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/452)
>      > > Results:failed test
>      > > Buildslave:gnep
>      > > Revision:None
>      > > Reason:The Nightly scheduler named 'nightly' triggered
>     this build
>      > > Log Excerpt
>      > > makept.cpp:423: warning: unused variable ‘new_face2’
>      > > makept.cpp:519: warning: unused variable ‘num_loops’
>      > > makept.cpp:612: warning: unused variable ‘new_edge’
>      > > mv -f .deps/makept.Tpo .deps/makept.Po
>      > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe
>     -pedantic -O2 -DNDEBUG
>     -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o makept
>     makept.o ../libcgm.la <http://libcgm.la>(http://libcgm.la) -lm
>      > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o makept
>     makept.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
>     ../.libs/libcgm.a
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.
>      > >  so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so
>     -lstdc++ -lpthread -ldl -lm -Wl,-rpath
>     -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE
>      > >  6.3.0/gcc/lib -Wl,-rpath
>     -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
>      > > g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps
>       -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC
>     -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom
>     -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet
>     -I../geom/Cholla -I../geom/OCC -I.
>     -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64
>     -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H
>     -Wall -pipe -pedantic -O2 -DNDEBUG -MT r_w.o -MD -MP -MF
>     .deps/r_w.Tpo -c -o r_w.o r_w.cpp
>      > > mv -f .deps/r_w.Tpo .deps/r_w.Po
>     -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o r_w r_w.o
>      > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o r_w
>     r_w.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
>     ../.libs/libcgm.a
>     /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.so /ho
>      > >  gcc/lib -Wl,-rpath
>     -Wall -pipe -pedantic -O2 -DNDEBUG -MT test_occ.o -MD -MP -MF
>     .deps/test_occ.Tpo -c -o test_occ.o test_occ.cpp
>      > > mv -f .deps/test_occ.Tpo .deps/test_occ.Po
>     -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o test_occ
>     test_occ.o ../libcgm.la <http://libcgm.la>(http://libcgm.la) -lm
>     test_occ test_occ.o
>     ../.libs/libcgm.a
>      > >  ing.so
>      > >  CADE6.3.0/gcc/lib -Wl,-rpath
>     -Wall -pipe -pedantic -O2 -DNDEBUG -MT operation.o -MD -MP -MF
>     .deps/operation.Tpo -c -o operation.o operation.cpp
>      > > mv -f .deps/operation.Tpo .deps/operation.Po
>     -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o operation
>     operation.o ../libcgm.la <http://libcgm.la>(http://libcgm.la) -lm
>     operation operation.o
>     ../.libs/libcgm.a
>      > >  aling.so
>      > >  ASCADE6.3.0/gcc/lib -Wl,-rpath
>     '-DTEST_ENGINE="OCC"'   -Wall -pipe -pedantic -O2 -DNDEBUG
>     -MT brick_occ-brick.o -MD -MP -MF .deps/brick_occ-brick.Tpo -c -o
>     brick_occ-brick.o `test -f 'brick.cpp' || echo
>     './'`brick.cpp
>      > > /usr/include/c++/4.4/bits/stl_algo.h: In function ‘int
>     main(int, char**)’:
>      > > /usr/include/c++/4.4/bits/stl_algo.h:194: warning: array
>     subscript is above array bounds
>      > > mv -f .deps/brick_occ-brick.Tpo .deps/brick_occ-brick.Po
>     -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o brick_occ
>     brick_occ-brick.o ../libcgm.la <http://libcgm.la>(http://libcgm.la) -lm
>     brick_occ brick_occ-brick.o
>     ../.libs/libcgm.a
>      > >  TKShHealing.so
>     -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC
>      > >  /OpenCASCADE6.3.0/gcc/lib -Wl,-rpath
>     -DTEST_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT
>     merge_occ-merge_test.o -MD -MP -MF .deps/merge_occ-merge_test.Tpo -c
>     -o merge_occ-merge_test.o `test -f 'merge_test.cpp' || echo
>     './'`merge_test.cpp
>      > > mv -f .deps/merge_occ-merge_test.Tpo .deps/merge_occ-merge_test.Po
>     -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o merge_occ
>     merge_occ-merge_test.o ../libcgm.la
>     merge_occ merge_occ-merge_test.o
>     ../.libs/libcgm.a
>      > >  b/libTKShHealing.so
>      > >  y/OCC/OpenCASCADE6.3.0/gcc/lib -Wl,-rpath
>      > >  ...make  check-TESTS
>      > > make[3]: Entering directory
>     `/disks/itaps-buildslave/cgm-occ/build/test'
>      > > make[4]: Entering directory
>      > >  [0;32mPASS [m: init
>      > >  [0;32mPASS [m: sheet
>      > >  [0;32mPASS [m: brick_facet
>      > >  [0;32mPASS [m: merge_facet
>      > > /bin/sh: line 1: 20802 Aborted "$tst" > modify.log-t 2>&1
>      > >  [0;31mFAIL [m: modify
>      > >  [0;32mPASS [m: subtract
>      > >  [0;32mPASS [m: makept
>      > >  [0;32mPASS [m: r_w
>      > >  [0;32mPASS [m: test_occ
>      > >  [0;32mPASS [m: operation
>      > >  [0;32mPASS [m: brick_occ
>      > >  [0;32mPASS [m: merge_occ
>      > >  [0;31m=======================
>      > > 1 of 12 tests failed
>      > > See test/test-suite.log
>      > >  [mmake[4]: *** [test-suite.log] Error 1
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
