[cgma-dev] buildbot failure in cgm-occ: failed test
    James Porter
    jvporter at wisc.edu
    Tue Apr 19 13:47:50 CDT 2011
I think if we're at the point where trunk is basically "dead", now's the time to merge the cubit12 branch into trunk. It wouldn't disrupt any development (there are hardly any commits to CGM trunk), and it would be easier for people outside of the project to grab a working source repo, which I think is important.
That said, I totally understand the hesitation to run "svn merge" anywhere, ever. Merging in SVN is pretty much always a pain (but thankfully, it's rare in our projects).
- Jim
On 04/19/11, Jane Hu   wrote:
> Hi, James
> Tim wants to release CGM in merge-cubit12 branch, and then use this as trunk later. This indicates that we don't need to support current CGM trunk later. For now, can we build using OCC6.5 and merge-cubit12 for testing? and stop testing in the CGM trunk? I am now only focusing on the branch. Thanks.
> Jane
> On Tue, Apr 19, 2011 at 1:20 PM, James Porter <jvporter at wisc.edu <jvporter at wisc.edu>> wrote:
> > Again, the buildbot tests only the trunk builds. The changes in the cubit12 branch shouldn't have any effect on the state of trunk.
> > I'm guessing the failures are due to r4735, but I haven't been following CGM closely.
> > - Jim
> > > Hello,
> > > Is this build with OCC6.5 and merge-cubit12 branch? I just checked out the whole merge-cubit12 branch and built with OCC6.5, and it passed all 12 testcases.
> > > Jane
> > > On Tue, Apr 19, 2011 at 12:51 AM,  <cgma-dev at mcs.anl.gov <cgma-dev at mcs.anl.gov> <cgma-dev at mcs.anl.gov <cgma-dev at mcs.anl.gov>>> wrote:
> > > > Fathom(http://gnep.mcs.anl.gov:8010/): cgm-occ(http://gnep.mcs.anl.gov:8010/builders/cgm-occ) build #452(http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/452)
> > > > Results:failed test
> > > > Buildslave:gnep
> > > > Revision:None
> > > > Reason:The Nightly scheduler named 'nightly' triggered this build
> > > > Log Excerpt
> > > > makept.cpp:423: warning: unused variable ‘new_face2’
> > > > makept.cpp:519: warning: unused variable ‘num_loops’
> > > > makept.cpp:612: warning: unused variable ‘new_edge’
> > > > mv -f .deps/makept.Tpo .deps/makept.Po
> > > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o makept makept.o ../libcgm.la(http://libcgm.la)(http://libcgm.la) -lm
> > > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o makept makept.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.
> > > >  so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE
> > > >  6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> > > > g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT r_w.o -MD -MP -MF .deps/r_w.Tpo -c -o r_w.o r_w.cpp
> > > > mv -f .deps/r_w.Tpo .deps/r_w.Po
> > > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o r_w r_w.o ../libcgm.la(http://libcgm.la)(http://libcgm.la) -lm
> > > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o r_w r_w.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.so /ho
> > > >  mes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/
> > > > g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT test_occ.o -MD -MP -MF .deps/test_occ.Tpo -c -o test_occ.o test_occ.cpp
> > > > mv -f .deps/test_occ.Tpo .deps/test_occ.Po
> > > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o test_occ test_occ.o ../libcgm.la(http://libcgm.la)(http://libcgm.la) -lm
> > > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o test_occ test_occ.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHeal
> > > >  ing.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCAS
> > > >  CADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> > > > g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT operation.o -MD -MP -MF .deps/operation.Tpo -c -o operation.o operation.cpp
> > > > mv -f .deps/operation.Tpo .deps/operation.Po
> > > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o operation operation.o ../libcgm.la(http://libcgm.la)(http://libcgm.la) -lm
> > > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o operation operation.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHe
> > > >  aling.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenC
> > > >  ASCADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> > > > g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H '-DTEST_ENGINE="OCC"'   -Wall -pipe -pedantic -O2 -DNDEBUG -MT brick_occ-brick.o -MD -MP -MF .deps/brick_occ-brick.Tpo -c -o brick_occ-brick.o `test -f 'brick.cpp' || echo './'`brick.cpp
> > > > /usr/include/c++/4.4/bits/stl_algo.h: In function ‘int main(int, char**)’:
> > > > /usr/include/c++/4.4/bits/stl_algo.h:194: warning: array subscript is above array bounds
> > > > mv -f .deps/brick_occ-brick.Tpo .deps/brick_occ-brick.Po
> > > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o brick_occ brick_occ-brick.o ../libcgm.la(http://libcgm.la)(http://libcgm.la) -lm
> > > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick_occ brick_occ-brick.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/lib
> > > >  TKShHealing.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC
> > > >  /OpenCASCADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> > > > g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DTEST_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT merge_occ-merge_test.o -MD -MP -MF .deps/merge_occ-merge_test.Tpo -c -o merge_occ-merge_test.o `test -f 'merge_test.cpp' || echo './'`merge_test.cpp
> > > > mv -f .deps/merge_occ-merge_test.Tpo .deps/merge_occ-merge_test.Po
> > > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o merge_occ merge_occ-merge_test.o ../libcgm.la(http://libcgm.la)(http://libcgm.la) -lm
> > > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o merge_occ merge_occ-merge_test.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/li
> > > >  b/libTKShHealing.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++ -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdpart
> > > >  y/OCC/OpenCASCADE6.3.0/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> > > >  ...make  check-TESTS
> > > > make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/test'
> > > > make[4]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/test'
> > > >  [0;32mPASS [m: init
> > > >  [0;32mPASS [m: sheet
> > > >  [0;32mPASS [m: brick_facet
> > > >  [0;32mPASS [m: merge_facet
> > > > /bin/sh: line 1: 20802 Aborted                 "$tst" > modify.log-t 2>&1
> > > >  [0;31mFAIL [m: modify
> > > >  [0;32mPASS [m: subtract
> > > >  [0;32mPASS [m: makept
> > > >  [0;32mPASS [m: r_w
> > > >  [0;32mPASS [m: test_occ
> > > >  [0;32mPASS [m: operation
> > > >  [0;32mPASS [m: brick_occ
> > > >  [0;32mPASS [m: merge_occ
> > > >  [0;31m=======================
> > > > 1 of 12 tests failed
> > > > See test/test-suite.log
> > > >  [mmake[4]: *** [test-suite.log] Error 1
More information about the cgma-dev
