[cgma-dev] buildbot failure in cgm-occ: failed test
    Jane Hu
    janejhu at gmail.com
    Tue Apr 19 13:31:34 CDT 2011
Hi, James
Tim wants to release CGM in merge-cubit12 branch, and then use this as trunk
later. This indicates that we don't need to support current CGM trunk later.
For now, can we build using OCC6.5 and merge-cubit12 for testing? and stop
testing in the CGM trunk? I am now only focusing on the branch. Thanks.
Jane
On Tue, Apr 19, 2011 at 1:20 PM, James Porter <jvporter at wisc.edu> wrote:
> Again, the buildbot tests only the trunk builds. The changes in the cubit12
> branch shouldn't have any effect on the state of trunk.
> I'm guessing the failures are due to r4735, but I haven't been following
> CGM closely.
> - Jim
> On 04/19/11, Jane Hu   wrote:
> > Hello,
> > Is this build with OCC6.5 and merge-cubit12 branch? I just checked out
> the whole merge-cubit12 branch and built with OCC6.5, and it passed all 12
> testcases.
> > Jane
> > On Tue, Apr 19, 2011 at 12:51 AM,  <cgma-dev at mcs.anl.gov <
> cgma-dev at mcs.anl.gov>> wrote:
> > > Fathom(http://gnep.mcs.anl.gov:8010/): cgm-occ(
> http://gnep.mcs.anl.gov:8010/builders/cgm-occ) build #452(
> http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/452)
> > > Results:failed test
> > > Buildslave:gnep
> > > Revision:None
> > > Reason:The Nightly scheduler named 'nightly' triggered this
> build
> > > Log Excerpt
> > > makept.cpp:423: warning: unused variable ‘new_face2’
> > > makept.cpp:519: warning: unused variable ‘num_loops’
> > > makept.cpp:612: warning: unused variable ‘new_edge’
> > > mv -f .deps/makept.Tpo .deps/makept.Po
> > > /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic
> -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o makept
> makept.o ../libcgm.la(http://libcgm.la) -lm
> > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o makept
> makept.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> ../.libs/libcgm.a
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTL.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEP209.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPAttr.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKSTEPBase.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKIGES.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKXSBase.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBinL.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKLCAF.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKCDF.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKHLR.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKOffset.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.
> > >  so /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFillet.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKFeat.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBool.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBO.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKPrim.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMesh.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKTopAlgo.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomAlgo.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKBRep.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKGeomBase.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG3d.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKG2d.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKMath.so
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKernel.so -lstdc++
> -lpthread -ldl -lm -Wl,-rpath -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE
> > >  6.3.0/gcc/lib -Wl,-rpath
> -Wl,/homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> > > g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../itaps
>  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC
> -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom
> -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet
> -I../geom/Cholla -I../geom/OCC -I.
> -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM
> -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2
> -DNDEBUG -MT r_w.o -MD -MP -MF .deps/r_w.Tpo -c -o r_w.o r_w.cpp
> > > mv -f .deps/r_w.Tpo .deps/r_w.Po
> -O2 -DNDEBUG -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib   -o r_w
> r_w.o ../libcgm.la(http://libcgm.la) -lm
> > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o r_w r_w.o
>  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib ../.libs/libcgm.a
> /homes/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib/libTKShHealing.so /ho
> > >  gcc/lib -Wl,-rpath
> -DNDEBUG -MT test_occ.o -MD -MP -MF .deps/test_occ.Tpo -c -o test_occ.o
> test_occ.cpp
> > > mv -f .deps/test_occ.Tpo .deps/test_occ.Po
> test_occ test_occ.o ../libcgm.la(http://libcgm.la) -lm
> > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o test_occ
> test_occ.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> ../.libs/libcgm.a
> > >  ing.so
> > >  CADE6.3.0/gcc/lib -Wl,-rpath
> -DNDEBUG -MT operation.o -MD -MP -MF .deps/operation.Tpo -c -o operation.o
> operation.cpp
> > > mv -f .deps/operation.Tpo .deps/operation.Po
> operation operation.o ../libcgm.la(http://libcgm.la) -lm
> > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o operation
> operation.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> ../.libs/libcgm.a
> > >  aling.so
> > >  ASCADE6.3.0/gcc/lib -Wl,-rpath
> -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H '-DTEST_ENGINE="OCC"'
>   -Wall -pipe -pedantic -O2 -DNDEBUG -MT brick_occ-brick.o -MD -MP -MF
> .deps/brick_occ-brick.Tpo -c -o brick_occ-brick.o `test -f
> 'brick.cpp' || echo './'`brick.cpp
> > > /usr/include/c++/4.4/bits/stl_algo.h: In function ‘int main(int,
> char**)’:
> > > /usr/include/c++/4.4/bits/stl_algo.h:194: warning: array subscript is
> above array bounds
> above array bounds
> > > mv -f .deps/brick_occ-brick.Tpo .deps/brick_occ-brick.Po
> brick_occ brick_occ-brick.o ../libcgm.la(http://libcgm.la) -lm
> > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick_occ
> brick_occ-brick.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> ../.libs/libcgm.a
> > >  TKShHealing.so
> > >  /OpenCASCADE6.3.0/gcc/lib -Wl,-rpath
> -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DTEST_OCC   -Wall -pipe
> -pedantic -O2 -DNDEBUG -MT merge_occ-merge_test.o -MD -MP -MF
> .deps/merge_occ-merge_test.Tpo -c -o merge_occ-merge_test.o `test -f
> 'merge_test.cpp' || echo './'`merge_test.cpp
> > > mv -f .deps/merge_occ-merge_test.Tpo .deps/merge_occ-merge_test.Po
> merge_occ merge_occ-merge_test.o ../libcgm.la(http://libcgm.la) -lm
> > > libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o merge_occ
> merge_occ-merge_test.o  -L/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/lib
> ../.libs/libcgm.a
> > >  b/libTKShHealing.so
> > >  y/OCC/OpenCASCADE6.3.0/gcc/lib -Wl,-rpath
> > >  ...make  check-TESTS
> > > make[3]: Entering directory
> `/disks/itaps-buildslave/cgm-occ/build/test'
> > > make[4]: Entering directory
> > >  [0;32mPASS [m: init
> > >  [0;32mPASS [m: sheet
> > >  [0;32mPASS [m: brick_facet
> > >  [0;32mPASS [m: merge_facet
> > > /bin/sh: line 1: 20802 Aborted                 "$tst" > modify.log-t
> 2>&1
> > >  [0;31mFAIL [m: modify
> > >  [0;32mPASS [m: subtract
> > >  [0;32mPASS [m: makept
> > >  [0;32mPASS [m: r_w
> > >  [0;32mPASS [m: test_occ
> > >  [0;32mPASS [m: operation
> > >  [0;32mPASS [m: brick_occ
> > >  [0;32mPASS [m: merge_occ
> > >  [0;31m=======================
> > > 1 of 12 tests failed
> > > See test/test-suite.log
> > >  [mmake[4]: *** [test-suite.log] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110419/e9b75359/attachment-0001.htm>
More information about the cgma-dev
