[cgma-dev] testgeom failure with Cubit-12.2
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Apr 13 14:11:29 CDT 2011
The failure of getting intervals is due to attribute changes, so for that one the test needs to be changed.  For the
other one, I'm not sure what the problem is.  Jane/Jason, have you seen this failure?
- tim
On 04/13/2011 01:39 PM, Rajeev Jain wrote:
> Hi,
> make check fails at testgeom when I use CGM merge-12 branch and
> cubit-12.2, my config line is: ./configure --enable-shared
> --prefix=/home/rajeev/lib/cgm12 --with-cubit=/home/rajeev/Cubit-12.2
> --enable-debug
> There are two failures (see below, test results from running testgeom):
> 1. Topology adjacency
> 2. Save EntSet
> Let me know if you need more info.
> rajeev at jain:~/cgm12/itaps$ gdb .libs/testgeom
> GNU gdb (GDB) 7.1-ubuntu
> Copyright (C) 2010 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later
> <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law. Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "i486-linux-gnu".
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>...
> Reading symbols from /home/rajeev/cgm12/itaps/.libs/testgeom...done.
> (gdb) r
> Starting program: /home/rajeev/cgm12/itaps/.libs/testgeom
> [Thread debugging using libthread_db enabled]
> Using default input file: ./testgeom.sat
> ITAPS GEOMETRY INTERFACE TEST PROGRAM:
> gLoad: Read 1 ACIS Entities from the input file
> Constructed 1 Volume: 1
> Model contents:
> vertices: 36
> edges: 60
> faces: 33
> regions: 1
> Success
> tags: Tags defined on model: GLOBAL_ID, NAME
> Success
> gentity sets: ERROR: Problem to add entity set.
> Error code: 23
> Error desc: Problem adding entity to another set.
> At : testgeom.cc:825
> Failure
> topology adjacencies: Success
> construct: Created swept volume 3
> Success
> primitives: Success
> transforms: Success
> booleans: Updated volume(s): 10
> Destroyed volume(s): 11
> Updated volume(s): 12
> Destroyed volume(s): 13
> Success
> mesh size: Read 1 ACIS Entities from the input file
> ERROR: Attribute type -1 not recognized.
> ERROR: Failed to get intervals for curves
> Error code: 15
> Error desc: Tag does not exist
> At : testgeom.cc:1309
> Failure
> save entset:
> Exported: 2 Volumes
> Read 2 ACIS Entities from the input file
> WARNING: Entity name 'Group 1' can't be used in commands.
> Additional name 'Group_1' assigned.
> Constructed 2 Volumes: 2, 3
> Success
> shutdown: Success
> TSTT TEST SUMMARY:
> Number Tests: 11
> Number Successful: 9
> Number Not Implemented: 0
> Number Failed: 2
> Program exited with code 02.
> Rajeev
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
