[cgma-dev] testgeom failure with Cubit-12.2
    Rajeev Jain
    jain at mcs.anl.gov
    Wed Apr 13 13:39:43 CDT 2011
make check fails at testgeom when I use CGM merge-12 branch and cubit-12.2, my config line is: ./configure --enable-shared --prefix=/home/rajeev/lib/cgm12 --with-cubit=/home/rajeev/Cubit-12.2 --enable-debug
There are two failures (see below, test results from running testgeom):
1. Topology adjacency
2. Save EntSet
Let me know if you need more info.
rajeev at jain:~/cgm12/itaps$ gdb .libs/testgeom
GNU gdb (GDB) 7.1-ubuntu
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "i486-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /home/rajeev/cgm12/itaps/.libs/testgeom...done.
(gdb) r
Starting program: /home/rajeev/cgm12/itaps/.libs/testgeom
[Thread debugging using libthread_db enabled]
Using default input file: ./testgeom.sat
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad: Read 1 ACIS Entities from the input file
Constructed 1 Volume: 1
Model contents:
vertices: 36
edges: 60
faces: 33
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: ERROR: Problem to add entity set.
  Error code: 23
  Error desc: Problem adding entity to another set.
  At        : testgeom.cc:825
Failure
   topology adjacencies: Success
   construct: Created swept volume 3
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 10
Destroyed volume(s): 11
Updated volume(s): 12
Destroyed volume(s): 13
Success
   mesh size: Read 1 ACIS Entities from the input file
ERROR: Attribute type -1 not recognized.
ERROR: Failed to get intervals for curves
  Error code: 15
  Error desc: Tag does not exist
  At        : testgeom.cc:1309
Failure
   save entset:
Exported:   2 Volumes
Read 2 ACIS Entities from the input file
WARNING: Entity name 'Group 1' can't be used in commands.
         Additional name 'Group_1' assigned.
Constructed 2 Volumes: 2, 3
Success
   shutdown: Success
TSTT TEST SUMMARY:
   Number Tests:           11
   Number Successful:      9
   Number Not Implemented: 0
   Number Failed:          2
Program exited with code 02.
Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110413/bafaa88d/attachment.htm>
More information about the cgma-dev
