[cgma-dev] r4616 - in cgm/trunk: . m4
    kraftche at cae.wisc.edu
    Mon Mar 21 11:50:36 CDT 2011
Author: kraftche
Date: 2011-03-21 11:50:35 -0500 (Mon, 21 Mar 2011)
New Revision: 4616
Modified:
   cgm/trunk/configure.ac
   cgm/trunk/m4/compiler.m4
Log:
o Sync m4/compiler.m4 with MOAB version
o Add --disable-fortran flag to force iGeom.h w/out Fortran name mangling
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac	2011-03-20 09:18:34 UTC (rev 4615)
+++ cgm/trunk/configure.ac	2011-03-21 16:50:35 UTC (rev 4616)
@@ -10,8 +10,12 @@
  [AM_INIT_AUTOMAKE([foreign -Wall])])
 AC_DISABLE_SHARED
+AC_ARG_ENABLE([fortran],[AC_HELP_STRING([--disable-fortran],
+  [No Fortran name mangling in ITAPS C headers])],
+  [ENABLE_FORTRAN=$enableval],[ENABLE_FORTRAN=yes])
 EXTRA_GNU_FLAGS="-Wall -pipe -pedantic"
-FATHOM_CHECK_COMPILERS
+FATHOM_CHECK_COMPILERS([yes],[yes],[$ENABLE_FORTRAN])
 AC_PROG_LIBTOOL
 LIBS="-lm"
 AC_PROG_SED
@@ -21,14 +25,14 @@
 #                Fortran Stuff for ITAPS C bindings
-if test "x" != "x$FC"; then
+if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FC"; then
   AC_FC_WRAPPERS
 fi
 #                Create libtool script
-# We need the libtool script both for the calls to the ITAPS_LIBTOOL_VAR
+# We need the libtool script both for the calls to the FATHOM_LIBTOOL_VAR
 # macro and for us in testing for ACIS libraries.  If we're using a newer
 # version of libtool, the script normally isn't generated until AC_OUTPUT
 # at the end of the configure script.  Ask that it be created now instead.
@@ -38,8 +42,8 @@
 #                              Extract libtool config
-ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [CGM_CXX_LINKFLAGS])
-ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
+FATHOM_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [CGM_CXX_LINKFLAGS])
+FATHOM_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
 AC_SUBST(CGM_CXX_LINKFLAGS)
 AC_SUBST(CGM_CXX_LIBS)
Modified: cgm/trunk/m4/compiler.m4
--- cgm/trunk/m4/compiler.m4	2011-03-20 09:18:34 UTC (rev 4615)
+++ cgm/trunk/m4/compiler.m4	2011-03-21 16:50:35 UTC (rev 4616)
More information about the cgma-dev
