[cgma-dev] r4616 - in cgm/trunk: . m4
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Mon Mar 21 12:04:20 CDT 2011
I got some config errors, in CGM with occ;
Is anybody else getting those?
The file Standard_Version.hxx seems to be in the right place.
Iulian
checking for fstream... no
checking fstream.h usability... no
checking fstream.h presence... no
checking for fstream.h... no
checking limits.h usability... no
checking limits.h presence... yes
configure: WARNING: limits.h: present but cannot be compiled
configure: WARNING: limits.h:     check for missing prerequisite headers?
configure: WARNING: limits.h: see the Autoconf documentation
configure: WARNING: limits.h:     section "Present But Cannot Be Compiled"
configure: WARNING: limits.h: proceeding with the compiler's result
checking for limits.h... no
checking Standard_Version.hxx usability... no
checking Standard_Version.hxx presence... yes
configure: WARNING: Standard_Version.hxx: present but cannot be compiled
configure: WARNING: Standard_Version.hxx:     check for missing prerequisite headers?
configure: WARNING: Standard_Version.hxx: see the Autoconf documentation
configure: WARNING: Standard_Version.hxx:     section "Present But Cannot Be Compiled"
configure: WARNING: Standard_Version.hxx: proceeding with the compiler's result
checking for Standard_Version.hxx... no
configure: error: OpenCascade config error:Standard_Version.hxx not found
----- Original Message -----
> Author: kraftche
> Date: 2011-03-21 11:50:35 -0500 (Mon, 21 Mar 2011)
> New Revision: 4616
> Modified:
> cgm/trunk/configure.ac
> cgm/trunk/m4/compiler.m4
> Log:
> o Sync m4/compiler.m4 with MOAB version
> o Add --disable-fortran flag to force iGeom.h w/out Fortran name
> mangling
> Modified: cgm/trunk/configure.ac
> --- cgm/trunk/configure.ac 2011-03-20 09:18:34 UTC (rev 4615)
> +++ cgm/trunk/configure.ac 2011-03-21 16:50:35 UTC (rev 4616)
> @@ -10,8 +10,12 @@
> [AM_INIT_AUTOMAKE([foreign -Wall])])
> AC_DISABLE_SHARED
> +AC_ARG_ENABLE([fortran],[AC_HELP_STRING([--disable-fortran],
> + [No Fortran name mangling in ITAPS C headers])],
> + [ENABLE_FORTRAN=$enableval],[ENABLE_FORTRAN=yes])
> EXTRA_GNU_FLAGS="-Wall -pipe -pedantic"
> -FATHOM_CHECK_COMPILERS
> +FATHOM_CHECK_COMPILERS([yes],[yes],[$ENABLE_FORTRAN])
> AC_PROG_LIBTOOL
> LIBS="-lm"
> AC_PROG_SED
> @@ -21,14 +25,14 @@
> # Fortran Stuff for ITAPS C bindings
> -if test "x" != "x$FC"; then
> +if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FC"; then
> AC_FC_WRAPPERS
> fi
> # Create libtool script
> -# We need the libtool script both for the calls to the
> ITAPS_LIBTOOL_VAR
> +# We need the libtool script both for the calls to the
> FATHOM_LIBTOOL_VAR
> # macro and for us in testing for ACIS libraries. If we're using a
> newer
> # version of libtool, the script normally isn't generated until
> AC_OUTPUT
> # at the end of the configure script. Ask that it be created now
> instead.
> @@ -38,8 +42,8 @@
> # Extract libtool config
> -ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path],
> [CGM_CXX_LINKFLAGS])
> -ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
> +FATHOM_LIBTOOL_VAR( [CXX], [compiler_lib_search_path],
> +FATHOM_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
> AC_SUBST(CGM_CXX_LINKFLAGS)
> AC_SUBST(CGM_CXX_LIBS)
> Modified: cgm/trunk/m4/compiler.m4
> --- cgm/trunk/m4/compiler.m4 2011-03-20 09:18:34 UTC (rev 4615)
> +++ cgm/trunk/m4/compiler.m4 2011-03-21 16:50:35 UTC (rev 4616)
More information about the cgma-dev
