[cgma-dev] .stp translator - Cubit license?
Hong-Jun Kim hongjun at mcs.anl.gov
Fri Sep 24 17:19:56 CDT 2010
It looks just license problem.
Hong-Jun
----- "Rajeev Jain" <jain at mcs.anl.gov> wrote:
> When I try to import a .stp file (attached) I see different behavior
> with different versions of Cubit. Is it something to do with 32bit /
> 64bit version? The messages that I get while importing are as follows:
> 10.2 build 28 (64 bit version) - Doesn't work
> CUBIT> import "/nfs/mcs-homes139/jain/Desktop/fuel.stp"
> Extension is .stp, guessing import type
> Geometry engine set to: ACIS Version 16.0.1.0
> ERROR: The STEP translator is not licensed for this installation
> ERROR: Errors importing STEP file
> 10.2 build 24 (32 bit version) - works & runs the meshing script
> CUBIT> import 'control.stp'
> Reading STEP file 'control.stp'...
> Read 2 ACIS Entities from the input file
> WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.1' is
> invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.1'
> WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.2' is
> invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.2'
> Rajeev
More information about the cgma-dev mailing list
