[cgma-dev] .stp translator - Cubit license?
Rajeev Jain
jain at mcs.anl.gov
Fri Sep 24 17:14:26 CDT 2010
When I try to import a .stp file (attached) I see different behavior with
different versions of Cubit. Is it something to do with 32bit / 64bit version?
The messages that I get while importing are as follows:
10.2 build 28 (64 bit version) - Doesn't work
CUBIT> import "/nfs/mcs-homes139/jain/Desktop/fuel.stp"
Extension is .stp, guessing import type
Geometry engine set to: ACIS Version 16.0.1.0
ERROR: The STEP translator is not licensed for this installation
ERROR: Errors importing STEP file "/nfs/mcs-homes139/jain/Desktop/fuel.stp"
10.2 build 24 (32 bit version) - works & runs the meshing script
CUBIT> import 'control.stp'
Reading STEP file 'control.stp'...
Read 2 ACIS Entities from the input
file
WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.1' is invalid. Changed
to 'Open_CASCADE_STEP_translator_6.3_1.1'
WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.2' is invalid. Changed
to 'Open_CASCADE_STEP_translator_6.3_1.2'
Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100924/e007c13f/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100924/e007c13f/attachment-0001.obj>
More information about the cgma-dev
