[cgma-dev] .stp translator - Cubit license?
Jason Kraftcheck
kraftche at cae.wisc.edu
Fri Sep 24 17:21:35 CDT 2010
On 09/24/2010 05:19 PM, Hong-Jun Kim wrote:
> It looks just license problem.
Not all versions of Cubit include STEP support. Presumably because it is
not available for all versions of ACIS.
- jason
> Hong-Jun
> ----- "Rajeev Jain" <jain at mcs.anl.gov> wrote:
>> When I try to import a .stp file (attached) I see different behavior
>> with different versions of Cubit. Is it something to do with 32bit /
>> 64bit version? The messages that I get while importing are as follows:
>> 10.2 build 28 (64 bit version) - Doesn't work
>> CUBIT> import "/nfs/mcs-homes139/jain/Desktop/fuel.stp"
>> Extension is .stp, guessing import type
>> Geometry engine set to: ACIS Version 16.0.1.0
>> ERROR: The STEP translator is not licensed for this installation
>> ERROR: Errors importing STEP file
>> 10.2 build 24 (32 bit version) - works & runs the meshing script
>> CUBIT> import 'control.stp'
>> Reading STEP file 'control.stp'...
>> Read 2 ACIS Entities from the input file
>> WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.1' is
>> invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.1'
>> WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.2' is
>> invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.2'
>> Rajeev
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
More information about the cgma-dev
