[cgma-dev] Problem building CGM in shared mode
Robert Smith
smithrm at mcs.anl.gov
Thu May 6 16:32:38 CDT 2010
Yes it does. I did check that first.
On May 6, 2010, at 4:27 PM, Jason Kraftcheck wrote:
> Robert Smith wrote:
>> Is there some trick to getting CGM to build with --enable-shared?
>> This
>> also has Cubit turned on.
>> I tried running the configure as it is done on the buildbot server
>> and I
>> continually get an error when it tries to link libcgm.la. It says
>> that
>> '/bin/ld cannot find -lcubiti19'. That makes sense since there is
>> no -L
>> switch to point to the Cubit install directory in the link line
>> although
>> the libcubiti19.so file is included explicitly in the libtool
>> line. And
>> the output of the make is slightly different on my build than the
>> buildbot build.
>> Could this be a libtool mismatch? I'm on the ANL Linux cluster
>> running
>> 1.5.26.
> Does your LD_LIBRARY_PATH include the cubit bin directory?
> - jason
More information about the cgma-dev
