[cgma-dev] Problem building CGM in shared mode
Rajeev Jain jain at mcs.anl.gov
Thu May 6 16:32:39 CDT 2010
On 05/06/2010 04:26 PM, Robert Smith wrote:
> Is there some trick to getting CGM to build with --enable-shared?
> This also has Cubit turned on.
> I tried running the configure as it is done on the buildbot server and
> I continually get an error when it tries to link libcgm.la.  It says
> that '/bin/ld cannot find -lcubiti19'.  That makes sense since there
> is no -L switch to point to the Cubit install directory in the link
> line although the libcubiti19.so file is included explicitly in the
> libtool line.  And the output of the make is slightly different on my
> build than the buildbot build.
> Could this be a libtool mismatch?  I'm on the ANL Linux cluster
> running 1.5.26.
> --Bob
Adding LDFLAGS=-L/home/rajeev/cubit-32/bin LIBS=-lcubiti19 to the
configure script did the trick for cubit-32 using 32 bit ubuntu-10.04,
This can be found at http://trac.mcs.anl.gov/projects/ITAPS/ticket/158
More information about the cgma-dev mailing list
