[cgma-dev] Problem building CGM in shared mode
Jason Kraftcheck
kraftche at cae.wisc.edu
Thu May 6 16:27:14 CDT 2010
Robert Smith wrote:
> Is there some trick to getting CGM to build with --enable-shared? This
> also has Cubit turned on.
> I tried running the configure as it is done on the buildbot server and I
> continually get an error when it tries to link libcgm.la. It says that
> '/bin/ld cannot find -lcubiti19'. That makes sense since there is no -L
> switch to point to the Cubit install directory in the link line although
> the libcubiti19.so file is included explicitly in the libtool line. And
> the output of the make is slightly different on my build than the
> buildbot build.
> Could this be a libtool mismatch? I'm on the ANL Linux cluster running
> 1.5.26.
Does your LD_LIBRARY_PATH include the cubit bin directory?
- jason
More information about the cgma-dev
