[cgma-dev] PyTAPS Multiple Geometry Load Failure
Rajeev Jain jain at mcs.anl.gov
Mon Apr 12 18:13:59 CDT 2010
For the files you have send, I don't see the seg fault in my 32-bit laptop which is python enabled!  Here is the o/p from the files:
rajeev at nix:~/FATHOM/other-files/stuart-cgmload$ python loadError.py
Read 10 ACIS Entities from the input file
ERROR: Attribute type -1 not recognized.
Constructed 10 Volumes: 1 to 10
Constructed 10 Volumes: 11 to 20
Rajeev
To: cgma-dev at mcs.anl.gov
Sent: Monday, April 12, 2010 12:39:47
Subject: [cgma-dev] PyTAPS Multiple Geometry Load Failure
Hi
I am attempting to load two different ACIS files in order to compare. I have found that a seg fault occurs when trying to load more than one file. I have tried both using multiple iGeom constructors for each file as well as one iGeom constructor and loading both files with that. Attached you will find a sample python script and an ACIS file that demonstrates the error by attempting to load 2 ACIS files (the same file in this case).
Thanks
Stuart Slattery
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100412/cf91a01f/attachment.htm>
More information about the cgma-dev mailing list
